Drives: 2013 SWP BRZ
Jack stand points
Besides using the pinch rails, are there any other spots you can safely lower the car down onto jack stands? I've tried searching but all I get is jacking points which I know.
I was using the pinch welds but 1) don't like putting them there because my jack stands are flat and it rests on the weld 2) I just put side skirts on that now cover part of the weld so I will end up digging into the side skirt. |
Drives: SC RB FRS
for the front i place my jack stands on the loop where you tow the car from. the rears i use the pinch welds.
Drives: 2013 SWP BRZ Limited
DIY: Safely Jacking and Supporting your BRZ/FRS
EDIT: Sorry, coulda swore that the above link mentioned something about alternate pad locations.... Hrm... read them somewhere... |
Np... Bump anyone?
| BRZ OEM Navigation: Adding and using Alert Points | PMok | Electronics | Audio | NAV | Infotainment | 27 | 09-30-2014 11:37 AM |
| SpudHack - BRZ Tool for managing alert points | edocura | Electronics | Audio | NAV | Infotainment | 6 | 06-08-2013 11:48 PM |
| Jack/stand system | Mr.Corvus | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 03-31-2013 12:02 AM |
| protecting the pinch weld lifting points | midnitz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-08-2013 09:36 PM |
| Car Jacking up Points? | J-Money | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-21-2013 02:55 PM |
