Old 11-17-2015, 08:19 AM   #1
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Freezing Windows?
This just dawned on me as I was scraping a layer of frost off my windows yesterday, and see that there's a nice big thick layer on it again this morning..
I broke the nylon slides on my BMW 325i on more than one occasion, trying to get the @#$# window unfrozen buy rocking the power window switch up and down. Good times, driving around w/a window only partially up in sub-0F weather, then eventually pulling the door panel to replace the slides. I got good at it, but it doesn't mean I looked forward to it. Eventually, I learned my lesson and just let'em stay frozen until they thawed.
NOW.. I noticed our cars have that neat little feature (translation... "stupid") that automatically rolls the window down a bit when the door opens, then rolls it back up when you shut the door, thereby REQUIRING that the window motor, slides, and track be stressed every time the window freezes, whether you want to stress'em or not.
I haven't been through a winter yet, but ours are serious and and this one's on its way. Anyone had any experience w/ frozen windows and had to deal w/ this automatic window cracking function? Any hints or advice?
Thanks..
Barry
MuseChaser is offline   Reply With Quote
Old 11-17-2015, 08:22 AM   #2
Loads of issues with the 13s and early 14s and freezing windows. Still some with the later ones but not as bad. There is a TSB for this that I had done last fall and I never had one single problem all winter. http://www.ft86club.com/forums/attac...1&d=1389643313
Old 11-17-2015, 08:24 AM   #3
stugray
Drives: 2013 GBS BRZ Limited
I use a credit card to scrape up ~1 inch above the wiper/seal each time I get in the car.
Old 11-23-2015, 10:56 AM   #4
Budda
Drives: BRZ Limited
We swedes put silicone on the window... sills? The rubber sealing around the Windows.
#BRZ
Budda is offline   Reply With Quote
Old 11-23-2015, 11:19 AM   #5
wheelhaus
wheelhaus's Avatar
I use a de-ice spray if the window is iced over, the yellow can from Prestone.
Old 11-23-2015, 11:24 AM   #6
Budda
Drives: BRZ Limited
Problem solved for me. Once I locked the car properly so the steering lock engaged, and then put it in on position the recalibration worked.
#BRZ
Old 11-24-2015, 12:38 PM   #7
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
FYI I had the window TSB done and my windows still froze this morning...
jermyzy is offline   Reply With Quote
Old 11-24-2015, 12:47 PM   #8
NLS8520
Drives: N/A
Try a product called 1z einszett gummi pflege rubber care stick, It should help with the issue.
[ame="https://www.youtube.com/watch?v=1TXP2F4CDrA"]Einszett Gummi Pflege Rubber Care Stick From MicksGarage.com - YouTube[/ame]
NLS8520 is offline   Reply With Quote
Old 11-24-2015, 12:53 PM   #9
Really? I had no issues at all last year. Except of course when there was solid ice on the window itself and then there would have been a problem no matter what the car was. The TSB works for water going down inside and freezing. There is no fix for surface ice on the glass freezing it shut.
Old 11-25-2015, 12:35 PM   #10
jermyzy
I park my car outside, so it could very likely be due to surface ice. After driving for about 5-10 minutes, it was able to open. However, in the summer when it's hot, my windows are making a loud "crack" noise every time I open the window, almost like the rubber is expanding and catching on the glass....
Old 11-25-2015, 12:40 PM   #11
I park mine outside as well and yes surface ice will freeze them up and there is nothing that can be done about that. My Lancer was even worse when it froze up with the surface stuff.
The crack noise is just the glass sticking to the rubber seal when it is warm. There is quite a bit of pressure pushing against the seal and when it get really warm it sticks a bit. This happens with all frameless windows (if they are sealed well that is) and is nothing to worry about.
Old 11-25-2015, 06:42 PM   #12
7 skulls
Drives: 2014 scion frs
Use dielectric grease on the window weatherstripping. Just a little smear, all along it, is all that's needed. Keeps the water out and no water, no frozen stuck windows.
7 skulls is offline   Reply With Quote
Old 01-11-2016, 01:10 PM   #13
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
I just dealt with this for the first time today... Went down/up okay when I got into it in the garage. By the time I drove to work, it froze over with the windchill. It was 45 deg F and rainy in Chicago on Saturday. Come Monday morning, 6 deg F! Luckily I work in a warehouse kept at 65 deg F, so I was able to pull in through an overhead door and let the FRS thaw out.
Weigaldo is offline   Reply With Quote
Painter's tape to keep doors / windows from freezing radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 03-12-2015 06:43 PM
Keep doors / windows from freezing? radroach BRZ First-Gen (2012+) — General Topics 1 03-04-2015 10:03 PM
Windows freezing in the winter. Garstang CANADA 26 11-15-2013 10:14 AM
Windows freezing in the winter. Garstang Scion FR-S / Toyota 86 GT86 General Forum 9 10-23-2013 07:07 PM
Windows freezing? L3P47 Scion FR-S / Toyota 86 GT86 General Forum 11 12-22-2012 12:49 PM
