Drives: FRS
Windows freezing in the winter.
Has anyone had the problem of the windows not going back up. After opening and closing the door in the winter ??
Drives: Subaru BRZ Sport Tech Satin White
Try Aerospace 303 protectant on the rubber door seals. The windows do freeze if water gets between the glass and the seals.
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
We stand on guard for thee...
Drives: 13 White MT FR-S
What did the blue screen say? Probably a driver issue.
Drives: 2013 Scion FR-S (Raven) MT
I've ready a lot of people have had this problem during the winter (especially us canadians)
Apparently you can disable that feature...I saw a pretty easy DIY where you just put tape around the door sensor that tells the car when the door is open (also disables the door chime)
My Car Journal: Raven FR-S w/ TRD Flavour ![]() Click for my AVIC Z150BH Head Unit DIY Install ![]() |
Drives: 2013 DGM BRZ Ltd
Drives: Ultramarine FR-S (MT)
Yea, happened a few times. This winter, i'm going to try putting Aerospace and maybe disabling it.
Also, for those who don't know: If your windows aren't going up and down and your window buttons are flashing, hold them all the way up past the click (or down, I forget) for a few seconds until they stop flashing to reset them. IIRC You will need to go to the passenger side to reset that side.
Thupercharged
I would check that the window will clear the body/trim when you disable to coupe auto-down feature.
I had an E36 with the same problem, and if you tried to fool the sensor the glass would just slam into the body/trim. Going to try the product mentioned in the thread...
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#10 |
Registered you sir
Drives: 99 impreza coupe
Subie guys have been treating their frameless window seals (and everything else plastic) with aero 303 for years. It might take a few applications if your are already saturated but it will eventually stop the problem. good luck
| Windows freezing in the winter. | Garstang | CANADA | 26 | 11-15-2013 11:14 AM |
| summer or all-season tires? freezing temps? | rainmonkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 04-07-2013 02:11 PM |
| Alright to tint windows in winter (cold)? | Chinadian | CANADA | 19 | 03-21-2013 03:31 PM |
| Windows freezing? | L3P47 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 12-22-2012 01:49 PM |
| Windows 8 | Khalis | Off-Topic Lounge [WARNING: NO POLITICS] | 33 | 10-17-2012 11:20 PM |
