Old 11-22-2015, 02:21 PM   #1
Scion1738
Drives: Scion Frs
Problem with car around 4K rpm
In first gear when I accelerate my car at around 4K to 5k the rpms rise very slowly then when I'm in second gear at the 4K range I feel as if the rpm meter bounces and I don't know how to explain it but my foot that's giving gas feels like less power is being sent to the engine.. My car has 30k miles and it has nothing done to it other than a intake and catback.. I have headers and everything and I was planning on putting it on today but ever since I started noticing this problem I'm sketched out about doing the parts I will be getting a tune for the headers and everything in less then two weeks ? But if anyone has the same problem or can explain what it is that would be awesome thanks =)
Scion1738 is offline   Reply With Quote
Old 11-22-2015, 03:13 PM   #2
pantdino
Drives: Firestorm 2013 FR-S
Sounds like the engine isn't making power above 4-5K. Could be mixture or ignition, both of which are electronically controlled in this car. The bouncing tach needle makes me think of a rev limiter, which is also part of the ECU in this car.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 11-22-2015, 03:33 PM   #3
How long have you owned the car?
Old 11-22-2015, 04:17 PM   #4
Scion1738
Drives: Scion Frs
A year and 4 months I'm the third owner
Old 11-22-2015, 04:20 PM   #5
Scion1738
Drives: Scion Frs
A ecutek stage 2 tune would it be able to fix this?
Old 11-22-2015, 04:22 PM   #6
pantdino
I gather this is a new problem.
I think the answer is "take the car to the dealer." Hopefully their computer will be able to discern the problem.
Old 11-23-2015, 01:20 AM   #7
I agree, especially if this is a new problem.
Have you changed gasoline suppliers lately .. ??
I'd suggest you get the engine "right" before you start in with the headers & stuff.
An aftermarket tune may straighten up the engine.
Old 11-23-2015, 01:38 AM   #8
I asked because I wanted to make sure you weren't just describing the dreaded torque dip.
You're not going to get any love from the dealer with the aftermarket parts and tune. Not talking warranty, I'm just saying they won't know how to deal with it. Even if they could reflash back to stock tune it would run like shit because of the bolt-ons.
Maybe an air leak downstream of the MAF? Accidentally filled with regular gas? That would practically bring it to its knees.
Old 11-23-2015, 05:05 AM   #9
steve99
Drives: FT86
If the power drops off substantially over 4k and it just wont rev past about 4500 its probably in limp home mode, is the check engine light on ??
read engine codes woth scanner
Old 11-23-2015, 10:23 AM   #10
stevesnj
stevesnj's Avatar
Sounds like an electrical issue, coil pack maybe. If you have a multi meter test it out. Also could be vacuum leak, airbox leak.
My 2016 Build thread
Old 11-23-2015, 02:46 PM   #11
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Sounds like the torque dip.
Or do you already know what torque dip is like for this car and still think this is something else?
Old 11-23-2015, 03:32 PM   #12
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Is it a bump or a momentary pause in the acceleration? Does it happen every time?
I have been having intermittent pauses in acceleration at right around 4k RPM for as long as I can remember. Been through multiple tunes N/A and turbo and it's still there. I have caught it in a log and it just looks like everything pauses for a few seconds, then continues as if nothing happened. It's not something that is repeatable with any certainty. It just happens sometimes. Wondering if it is the same thing.
Old 11-27-2015, 01:13 PM   #13
Scion1738
Drives: Scion Frs
It's hard to explain but it basically just slows down in acceleration as if gives no power. It sorta feels like passing the red line limit just not as bad. As soon as it gets to 5k it's normal again
Old 11-27-2015, 11:59 PM   #14
Was there a sudden change in performance, or is it possible that you noticed something that crept up slowly?
Seems silly but check your air filter.
First problem with the STX Brz Simmons Tracking / Autocross / HPDE / Drifting 94 06-23-2014 12:05 AM
Big Problem jpit Engine, Exhaust, Transmission 156 05-13-2014 08:21 PM
DRL problem benlaz88 Scion FR-S / Toyota 86 GT86 General Forum 23 09-19-2013 08:58 PM
E85 problem asher187 Engine, Exhaust, Transmission 4 08-27-2013 10:37 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
