Old 11-16-2015, 04:37 PM   #225
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Originally Posted by philooo View Post
See the image attached about the tube bend for the headroom.
I am not sure we are talking about the same tube. My proposition is to add a 3rd bend, unless I am missing something
What tube size are you using ? it looks like a big diameter, any reason not to go for smaller tube with thicker walls ? hard to tell in the photo.
From my experience with wiring everything that had a yellow plug can be pulled out.
The audio/radio/amplifier wires are the main solution and take a little more time to identify and remove. But a clean interior is priceless
curious about forced induction
Ah, I see what you're saying. I don't think we would gain much from an additional bend there, it's already pretty tight up against the ceiling, and pushed as far outboard as it can go.
We're using 1.75" x 0.095" DOM. It's stiffer than 1.5" x 0.120" tubing for a given length, although it is slightly heavier. The main reason, though, is common tooling. This will allow us to make cages for heavier cars (over the 3200lb limit) out of 1.75" tubing using the same bender tooling, which is very expensive. So in short, it's for ease of production down the road.
Thanks for the tip on the zip ties. Those look slick.
Jake
GSpeed is offline   Reply With Quote
Old 11-16-2015, 04:41 PM   #226
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
http://www.ft86club.com/forums/showt...05#post2453205
Here's the thread on the cage design.
Old 11-16-2015, 09:39 PM   #227
jph11
Drives: Still deciding
Originally Posted by GSpeed View Post
Oh, and we're starting to piece together our forced induction plan. Stay tuned, we've got some exciting stuff coming up.
The question remains.... Did they solve the hear soak issue that we see with most FI systems (think Texas heat) or find a solution that would be good enough....
jph11 is offline   Reply With Quote
Old 11-18-2015, 08:36 PM   #228
Brayden_23
Drives: Asphalt 2015 FRS
Subbed. Love the details of this build. Even though I don't have plans to go full racecar, I still enjoy the data on the parts you do use to know what I should be looking for as I continue to add to my car.
Thank you for the time you have taken to compile all this information, and know it is very much appreciated!
Brayden_23 is offline   Reply With Quote
Old 11-19-2015, 04:03 PM   #229
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Can't say for sure yet, but it's a business decision as much as a technical one.
The Following User Says Thank You to GSpeed For This Useful Post:
stoked_on_spool (11-24-2015)
Old 11-19-2015, 04:39 PM   #230
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Favourite thread on forum. I'm nerding out so hard on all the data. Sub'd.
1Cor10:23 is offline   Reply With Quote
Old 11-20-2015, 03:20 PM   #231
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
also nerding out on the data, and that they are near me!
G-Man is offline   Reply With Quote
Old 11-20-2015, 04:47 PM   #232
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Thanks for the kind words, guys. Feel free to stop by the shop and check us out any time!
We got a little more work done on the cage design. The basic beam structure is pretty much there.
We also did some torsional analysis, which is detailed in the cage thread in the HPDE section.
http://www.ft86club.com/forums/showthread.php?t=97715
solidONE (11-20-2015)
Old 11-20-2015, 06:08 PM   #233
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
No 4130 tubing for the shop car?
Intent > Content
Old 11-20-2015, 06:21 PM   #234
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Negative. We saw more value in running larger diameter (1.75" x 0.095" vs. 1.5" x .120") mild steel DOM to increase stiffness. 4130 would be neat, but just not necessary for this car.
Old 11-21-2015, 05:02 PM   #235
Scracho
Drives: 2018 Subaru BRZ
Sub'd! Love the R&D
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following User Says Thank You to Scracho For This Useful Post:
GSpeed (11-23-2015)
Old 11-25-2015, 07:13 PM   #236
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Quick teaser before the holiday weekend.
The Following 6 Users Say Thank You to GSpeed For This Useful Post:
civicdrivr (11-29-2015), DocWalt (12-27-2015), mrk1 (11-25-2015), philooo (11-25-2015), stoked_on_spool (11-25-2015), Tristor (08-30-2018)
Old 11-25-2015, 10:09 PM   #237
philooo
Drives: 13' Scion FRS Track car
now that you are talking about seats
I just mounted a passenger seat today in my car... what a pain, I used the Planted plate to attach the seat to the OEM bolting point. And I also did not use slider to keep them as low as possible, but then the seat is too far to the front.
What are you going to use to mount the seats
The head clearance prohibit using sliders if you are above 6 feet tall.
Looking forward to your seat mounting options
philooo is offline   Reply With Quote
Old 11-25-2015, 10:54 PM   #238
N234
N234's Avatar
Drives:
You mean you mounted a passenger seat on the driver side?:confused:
N234 is offline   Reply With Quote
North East Track/AX - what did you sign up for? dp1 NY / NJ / CT / PA 42 10-18-2016 12:51 AM
Ohio Track Day - Nelson's Ledges 2015 mcquarrieg Great Lakes 24 08-04-2015 04:43 PM
Bar & Track - 2015 Subaru WRX Review FT-86 SpeedFactory FR-S / BRZ vs.... 71 05-26-2014 01:08 AM
