Old 11-18-2015, 09:10 PM   #15
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by JazzleSAURUS View Post
Please comment on customer service thinking that a melting harness is acceptable.
Thanks!
To clarify- this was indeed a huge mistake by our service rep. We went over this issue earlier today to ensure that all of our staff understand that there was a mistake made here. We will of course be correcting the issue for the OP, and we are investigating our harnesses here to determine whether there is any defect. We currently believe that the crimp failed over time, leading to a weak point where heat could build up. We're analyzing each connector we have on the shelf to ensure that there are no problems with them.
Thanks,
Paul
Owner, Diode Dynamics
Originally Posted by zc06_kisstherain View Post
I remember asking DD about foglights for people who has premium (only BRZ limited comes with fog light), they dont bother reply back to me even asked for 2 times.
We answer every email and PM we get, so it's very likely that our reply was sent to your spam folder. If it was on social media, my apologies, as we do miss some things on those platforms from time to time just due to the nature of FB and Instagram. I'm sorry you had a poor experience, but please feel free to call if you'd like any more info: 314-205-3033. Thanks!
John C.
Diode Dynamics
The Following 3 Users Say Thank You to Diode Dynamics For This Useful Post:
ichitaka05 (11-19-2015), JazzleSAURUS (11-19-2015), zc06_kisstherain (11-20-2015)
Old 11-18-2015, 09:31 PM   #16
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by N1rve View Post
What other harnesses out there? LOL Other than OEM...
I have the auer fog kit which includes what I believe is a Toyota oem harness.
But i have a morimoto harness for my headlights and it's amazing quality.
https://www.theretrofitsource.com/co...l#.Vk00Q0SCOnM
Old 11-18-2015, 10:00 PM   #17
Originally Posted by BirdTRD View Post
This is the reason why you should NEVER replace a fuse with one of higher rating (unless you hold an Electrical Engineering degree, but sometimes they’re even worse!) The entire circuit is designed for safe operation, including the choice of fuse to protect it, so changing any component in that circuit can have a potentially negative impact.
Oh, darn ....... putting a .22 cal shell casing in a fuse slot or a penny behind a blown fuse in the fuse box was so handy ......
The Following 4 Users Say Thank You to humfrz For This Useful Post:
BirdTRD (11-19-2015), Cole (11-19-2015), HunterGreene (11-19-2015), Tcoat (11-19-2015)
Old 11-19-2015, 08:08 AM   #18
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
I feel like this must be an isolated incident because many people have this kit including myself and i thought the initial quality of the harness and everything in the kit was great!
Cockatoo is offline   Reply With Quote
Old 11-19-2015, 08:33 AM   #19
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
The good 'ol 1/4-20 no-blow?
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
humfrz (11-19-2015)
Old 11-19-2015, 10:22 AM   #20
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Is there a reason there's no seal on the crimped wiring? It's pretty clear that the copper isn't clean like it should be, and the inside of the connector as seen here should be spotless.
Old 11-19-2015, 01:55 PM   #21
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
That could possibly be due to the fire.
N1rve
Old 11-19-2015, 02:04 PM   #22
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Are there rubber seals on the other wires?
Old 11-19-2015, 02:27 PM   #23
Diode Dynamics
That is our belief as well. We have not identified any bad connections or crimps in our inventory right now. It's clear that the failure here was caused by either:
1) a wire coming loose from a crimp, which in turn overheated.
2) a defect in the bulb, which caused increased resistance and heat in powering the bulb.
Again- we're happy to assist anyone who runs into any problem with our products, and will always replace any defective item that is under warranty.
Thanks,
Paul
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Old 11-19-2015, 02:36 PM   #24
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Thanks,
Paul
Nick and Paul;
Thanks for being so actively involved and seeing this issue through.
I've been a DD fan for a while now, and it's great to see you guys sorting out issues actively. It shows why it's worth paying the premium over the cheaper Amazon or eBay units.
JazzleSAURUS is offline   Reply With Quote
Old 11-19-2015, 02:36 PM   #25
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Sad to see something go wrong with aftermarket parts, but looks like DD is fixing this issue. I, myself have DD's foglights and don't have any issue, but I'll double check mine to be safe. How quickly they're taking care of this issue, I'll prob keep buying their products as well. DD, keep up bring the great product for our cars!
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
Diode Dynamics (11-19-2015), JazzleSAURUS (11-19-2015)
Old 11-19-2015, 05:01 PM   #26
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
DD, are you putting the weather seals on the wires or not? I don't see them in the pics.
Old 11-19-2015, 06:42 PM   #27
Diode Dynamics
Yes, all of our harnesses use properly-sized and crimped seals for applicable terminals.
John C.
Diode Dynamics
DocWalt (11-19-2015)
Old 11-20-2015, 01:52 AM   #28
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
fk thats 3rd time I hear this...now im not sure whether to buy them...
Review: Diode Dynamic FRS Always-On Module N1rve Cosmetic Modification (Interior/Exterior/Lighting) 43 03-14-2016 02:35 PM
Help!! Diode Dynamic drls are melting?? Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 51 07-10-2015 10:49 AM
I got some diode dynamic lighting for my car!! Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 35 03-27-2015 01:58 PM
Passenger seat caught on fire PLZdontscream Issues | Warranty | Recalls / TSB 46 06-11-2014 12:57 PM
Anyone use diode dynamic fog lights with HiD? KamakazeProject Cosmetic Modification (Interior/Exterior/Lighting) 7 01-24-2014 03:41 AM
