Old 11-18-2015, 01:51 PM   #281
Dr Speed
Drives: Red
Originally Posted by sw20kosh View Post
Lol people are hitting that with e85 and headers.
Right but what do you think all this extra work will gain? Was the 205 on E85 Tune with Header measured in SAE with a smoothing Factor 5 or was it STD.
I have seen a few of these cars tuned, and while I don't own a BRZ/FRS personally I have seen claims for the car I own where people front manufacturer claims, or present dyno sheets in STD. That's just not accurate.
I'm sure OP will have fun, and I'm tuned in to see final numbers.. but to air on the negative side a bit, I think this will be a lot of work for not a lot of go vs FI vs tune only especially when you look at time, costs and reliability. I have been down this road with other platforms and learned hard lessons... like 7rwhp from a set of cams and $2000 in new parts and hours and hours of my time and trapping .4mph faster with an identical e.t
Honestly 300cc's extra, pistons and a set of cams and ported heads on this engine I would bet might add 10-12hp. Its already making 100hp per liter OEM or about 78-80whp per liter measured at the wheels
FI is getting guys into the 220-230 range conservatively SAE... you might hit that lower number with a full N/A build.
Dr Speed is offline   Reply With Quote
Old 11-18-2015, 02:23 PM   #282
swarb
If he didn't think it was worth it, he wouldn't be doing it
time? he is not in a rush, or it doesn't seem like it.
Cost? his money.
Reliability? should all be there depending on how high rev limit is.
By your math, 100hp per liter, .3 liter would be 30hp.
160whp stock. 24whp gain(by your math)
Car dynos 155-165 completely stock. header/e85/tune pulls 195-205 or so.
205+ that magical 24hp. 229hp
it is going to be a full build, so your math works out. I suggest you look at more dyno sheets
response in bold
The Following 3 Users Say Thank You to swarb For This Useful Post:
celek (11-19-2015), CxG (11-18-2015), skye67 (07-04-2016)
Old 11-18-2015, 02:35 PM   #283
Dr Speed
Drives: Red
Originally Posted by swarb View Post
response in bold
You are right my math does work out. I've looked at a lot of dyno sheets. I'm not discrediting the OP. I just finished a full build on another platform similar to what he is doing.
Just adding my two cents.
Old 11-18-2015, 03:16 PM   #284
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
All that math didn't even account for the raised rev limit. Assuming he makes 200 Nm torque at crank from the 2.3L at 9000 RPM, we end up with 253 crank BHp, which is quite a lot. With porting and a proper tune, this number should be easy to hit at those revs, as the engine makes more or less 200 Nm stock.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
The Following 2 Users Say Thank You to 200hp/tonne For This Useful Post:
celek (11-19-2015), chaoskaze (11-18-2015)
Old 11-18-2015, 03:54 PM   #285
sato
sato's Avatar
Drives: Dodge Patitas
Isn't there a Mazda/Ford 2.3L engine (used in racing) that produced almost 300hp?
Sent using Tapatalk
sato is offline   Reply With Quote
Old 11-18-2015, 06:45 PM   #286
Snake
Drives: ADM Toyota 86 GT
http://www.cosworth.com/products/cra...ratec-engines/
280bhp for the top of the range 2.3ltr
Looks like they run dry sump, ITBs, 13:1 compression and 8500rpm limit.
Snake is offline   Reply With Quote
The Following User Says Thank You to Snake For This Useful Post:
Kronos (11-18-2015)
Old 11-18-2015, 09:27 PM   #287
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
@celek What type of gearing are you planning on doing? Any sort of FD swap??
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 11-19-2015, 11:30 AM   #288
celek
Resident Gear Head
celek's Avatar
response in bold
Not to mention everything is exponential.
If all I did was increase displacement to 2.3 liters and left everything else stock you are looking at a 15% increase to a base 230 Crank HP All the other addons work with each other.
celek is offline   Reply With Quote
Old 11-19-2015, 11:32 AM   #289
celek
Resident Gear Head
celek's Avatar
Its been considered but I do not want to go too crazy as the increased TQ and Power may not be a good combination of a really high Final Drive like 5.7:1
Old 11-19-2015, 11:35 AM   #290
celek
Resident Gear Head
celek's Avatar
Hopefully the meeting with Piper Cams at PRI proves successful. The current Cam profile stock falls flat at 7000 RPM. there is really no reason to go higher unless you have boost. In a NA platform its different you dont want to struggle with acceleration to 9000RPM not making power when you could have shifted to a new gear and be going faster.
The Following User Says Thank You to celek For This Useful Post:
CxG (11-19-2015)
Old 11-19-2015, 02:04 PM   #291
200hp/tonne
Drives: Raven Fr-S
What does that mean? I don't think it would lose power at high rpms, just leave room on the table for longer duration cams to do a better job. Plus, there's always phasing from the AVCS to help you out...
Old 11-19-2015, 02:09 PM   #292
celek
Resident Gear Head
celek's Avatar
Yes the AVCS can help but if you look at the Dyno's people provide for our engine with the stock cams they start to flatten out at about 7k RPM. To support that higher RPM you need more lift and duration to bring enough air and fuel in.
https://www.google.com/search?q=brz+...zom40Gjy1oM%3A
Old 11-19-2015, 03:44 PM   #293
200hp/tonne
Drives: Raven Fr-S
It looks like the tune is severely gimped past 7000 rpm at full load. Crazy rich AFR, weird cam timings, retarded ignition, it's all there.
Old 11-19-2015, 05:04 PM   #294
mad_sb
Drives: 2013 Asphalt FR-S
He is talking about tuned results....
Lots of talented tuners have been working with this platform for a while now. The power is not locked away in the tuning (beyond 7500, NA). Yes there are some good gains up top with headers, E85, exhaust and tune but it drops off hard once you pass 7k with the stock heads and cams.
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
