#15 |
Drives: 2013 Asphalt FRS
Call Your Tuner!!! They Will Know!!!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following 2 Users Say Thank You to FRS Justin For This Useful Post: | kch (11-17-2015), strat61caster (11-17-2015) |
#16 | |
Drives: Asphalt frs
Sent from my SM-N920T using Tapatalk |
#17 |
Drives: Asphalt frs
Yeah already talked to Zach at delicious and he recommended me staying with the 12:5. But kind of hesitant, was running tune by them and over boosted. Didn't know it didn't have over boost protection and the last thing I'd want is to spend even more money. Already have to do a rebuild now don't want to have to deal with it again.
| The Following User Says Thank You to SoCal80six For This Useful Post: | John Rambo (02-17-2016) |
#18 | |
I Love custom Turbo kits
Drives: Limited BRZ
This thread is about forged internals designed to withstand way more than 20 psi of boost/ 500 whp/ 400 wtq. All E85 does is give you a huge detonation free window. As long as you don't knock, the forged internals designed to take much more than 500 whp/ 20 psi will be just fine. Heck, I am running stock unopened motor E85 552 whp for almost two years now. There's really no need to increase lag and hurt the out of boost performance of the engine going with lower compression as long as you plan on having the knock resistance of E85 when going with the full boost (20 psi) map.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | DriftinFRS (11-18-2015) |
#19 | |
Drives: Limited BRZ
Best of both worlds, no need to compromise.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | CxG (11-18-2015) |
#20 | |
Drives: Asphalt frs
#21 |
Dismember
Drives: 2013 Red Scion FR-S
I strongly suggest 6:1 and half a dozen of the other.
Problem with a delicious tune is you apparently don't know what you are getting. More your fault than theirs but sealed tunes are sealed. Go talk to somebody who does the total package. Including building the engine and tuning.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | SoCal80six (11-18-2015) |
#22 |
Drives: Rb25 neo brz
We have done a couple of FA20 builds this year, including mine. on my personal car i also run the MAP turbo kit (which is fantastic) but i am running a 3076. For my setup we went with a 11:1 compression ratio which worked out great for us
Best regards, -phil |
| The Following User Says Thank You to -Phil For This Useful Post: | SoCal80six (11-18-2015) |
#23 | |
I truly feel its not the tune, they don't just work one day and change the next, it has to be mechanical. Also do what I do and get a stand alone boost controller /protector that lets you control the boost and everything about it. I run a AMS 2000 Pro and love it!!!!!!!!! Call Jeremy at Outfront Motorsports in Buena Park tell him I sent ya and to give you that big brother hook up on a motor and then cal Ian at MAP and tell him hook you up on a boost controller turbo smart isn't that expensive and work good. Mark at Spencer Fab runs one and likes it I believe Outfront stocks them too.
| The Following 2 Users Say Thank You to FRS Justin For This Useful Post: | CxG (11-18-2015), SoCal80six (11-18-2015) |
#24 |
Drives: 2JZ FRS
I've never had an issue with my ecutek setup. Closed loop boost control and boost cut, standard Mac valve with push loc hoses/fittings. I melted the rubber wastegate line back when I had my avo kit and the ecutek boost cut worked flawlessly
#25 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
What about for a built motor running a supercharger, what compression ratio would be good? I was looking at 10:1 compression.
| Crawford Built Short Block | texasbound972 | Engine, Exhaust, Transmission | 26 | 05-15-2015 03:39 PM |
| Porsche Patents a Variable Compression Ratio | Captain Snooze | Other Vehicles & General Automotive Discussions | 7 | 04-30-2015 11:21 PM |
| WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 01:26 AM |
| Built B18B Short Block | C130NAV | Miscellaneous | 0 | 01-04-2014 12:15 PM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
