| View Poll Results: Favorite clutch? | |||
| ACT |
35 | 38.46% |
| Exedy |
28 | 30.77% |
| Southbend |
13 | 14.29% |
| Clutch Masters |
6 | 6.59% |
| Other (please specify) |
9 | 9.89% |
| Voters: 91. You may not vote on this poll | |||
#15 |
Drives: 2013 BRZ black
@wootwoot Hows that lightweight FW treating you while being boosted? Ive got one laying around and would love to throw it in but am told it turns the idle to shit.
#16 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | xkalelx (09-17-2015) |
#18 |
Drives: '13 BRZ | '04 E55
My south bend stage 1 disc is not very pleasurable for street driving. Clutch feel is like stock, not any stiffer. Engagement point is same as stock. But, I get bad shudder/vibration on release if I have to slip it any in stop/go traffic. This is the biggest kicker to this clutch setup, since I purchased it for DD duty, and specifically chose the "Daily" variant for OEM like engagement.
#19 |
Damn, Why didn't I know you stock these clutches @CSG Mike? I would have bought from you and saved a few bucks too.
| The Following User Says Thank You to xkalelx For This Useful Post: | CSG Mike (11-12-2015) |
#20 |
Drives: 2013 FR-S Whiteout MT
Whats the difference between ACT SB7 and SB8? All the specs look the same, ones like 2 lbs lighter. Please help!
When in doubt, throttle out!
#21 |
Drives: '15 FRS
| The Following User Says Thank You to VitViper For This Useful Post: | FRS Johnny (11-17-2015) |
#22 |
Y u do dis?
I'm using the Streetlite flywheel with my ACT clutch, love it.
SB7 XTSS
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
| The Following 2 Users Say Thank You to Dream20b For This Useful Post: | FRS Johnny (11-17-2015), Sleepyyysam (04-14-2019) |
#23 |
Drives: '15 FRS
The ACT w/ the HD PP held up to 452whp/350wtq on the dyno today. This clutch should be good for the vast majority of us.
#24 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I'm considering the Exedy Stage 1 for my supercharged frs, thoughts?
#25 |
WHOOOOOOA. I just slipped the hell out of my new ACT HDSS. I was just farting around on industrial roads today. Pulled hard through second gear. Then when I hit third gear, the tach just spiked to 7400rpm as I hit full boost almost immediately.
Tons of stinky smoke and not from the tires at all.I need to dyno my car to see what kind of numbers I am actually making. Stock block, 6758 EFR, e85, 12psi. I installed this HDSS about 10 days ago and been babying it. I feel like I did the break in period correct and am well beyond the 500 mile mark. What gives? I thought this clutch was rated at 270wtq, I shouldn't be anywhere close to that. Thoughts? |
#26 |
Drives: Late 2014 Subaru BRZ
To be honest my clutch wasn't right until after 1000 miles. The first 100 was fun. But I'm using the XTSS rated for much more but still disc not puck.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#27 |
@GsxrMe Hows the pedal feel and engagement on that XTSS? The pedal feel on my HDSS is maybe 30% stiffer than stock and the engagement is predicable albeit I need a few hundred more RPM to get a smooth takeoff.
#28 |
The Mechanic
Drives: Civic Turbo,FR-S
were did u buy your action clutch? i dont see many distributors
| FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? | bren5279 | Engine, Exhaust, Transmission | 8 | 09-22-2015 10:36 AM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
