View Poll Results: Favorite clutch?
ACT 35 38.46%
Exedy 28 30.77%
Southbend 13 14.29%
Clutch Masters 6 6.59%
Other (please specify) 9 9.89%
Voters: 91. You may not vote on this poll
Old 09-12-2015, 01:22 PM   #1
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Favorite clutch?
Hey guys I am looking for a clutch to hold over 265lb ft, but want something close to "stock feeling," minimal noises, streetable, ect.
Seems like most guys prefer ACT 6 puck from my research, other swear by Clutch Masters (Fx 300), or Exedy Stage 2, and even Southbend Stage 3 endurance was recommended.
Here was a thread a few years back.
http://www.ft86club.com/forums/showt...t=29863&page=2
What are you all running and what are the preferences? Please post what you think with a poll and details, thanks!
Readytoxplod is offline   Reply With Quote
Old 09-12-2015, 01:38 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
OS Giken GTS1CD. Feels very close to stock.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 09-13-2015, 12:59 AM   #3
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
I have a OS Giken TR2C, its has a pretty short engagement range(really sensitive) vs stock. Its overkill for the car though, no 1st gear lockout however.
R2RO is offline   Reply With Quote
Old 09-13-2015, 02:07 AM   #4
Fastbrew
Drives: 2014 Pearl White BRZ
SB Stage 3 endurance with a Stage 2 flywheel. I love my setup. Follow the break in to the T. It's a long time but it is worth it. No chatter. No jerkiness. No trouble in stop and go or on hills. I am running 350HP (278 lb ft tq) now and it is a champ. I am a fan for life.
Fastbrew is offline   Reply With Quote
The Following 2 Users Say Thank You to Fastbrew For This Useful Post:
chaoskaze (11-26-2015), Tcoat (09-13-2015)
Old 09-13-2015, 03:07 AM   #5
ACT HD-SS.
Nice smooth engagement, slightly heavier pedal feel.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
clayrush (09-13-2015), Sportsguy83 (09-13-2015), xkalelx (11-11-2015)
Old 09-13-2015, 07:59 AM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've searched, I couldn't find the answer, will the FA20DIT clutch work in our cars?
Old 09-13-2015, 08:47 AM   #7
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
No, they use the same clutch as the previous WRX if I remember correctly. They will not fit ours. The discs may be similar or shared with certain other models especially for aftermarkets, but not the full clutch assemblies.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Calum (09-13-2015)
Old 09-13-2015, 09:49 AM   #8
mrk1
Drives: Sterling BRZ Ltd
Action Stage 2 is a great choice and price. I have a south bend now and it's so so. Also when I last checked south bend had discontinued the clutchs for our cars
My south bend will come out this winter for a Action Stage 2
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 09-13-2015, 12:04 PM   #9
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Were there not issues with the Excedy clutches in the past? Or have those issues been resolved now? The last time I read up on Excedy was a couple months ago.
Alltezza is offline   Reply With Quote
Old 09-13-2015, 03:38 PM   #10
wootwoot
Drives: FRS
I have an exedy stage two with 12lb fly wheel. I like it a lot.
wootwoot is offline   Reply With Quote
Old 09-13-2015, 04:17 PM   #11
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
This was for my celica. It failed in under 20k and I was about 100 torque under it's limit.
My newer ACT-TC2-HDG6 may be over kill but it feels awesome and I can only burn my clutch if I am trying.
clayrush is offline   Reply With Quote
Old 09-14-2015, 02:52 PM   #12
Readytoxplod
Tire Destroyer
Yeah people were having problems getting locked out of 1st, lots of chatter, and problems in general. Apparently they came out with a revised version that fixed these things a few months ago, (Exedy stage 2, 3 puck #15955) but it uses the stock flywheel, and a lightweight Exedy one is expensive so I am kinda iffy.
On another note I drove a twin with 305whp and an ACT 6 puck, pretty nice but basically an on off switch, a little chatter etc. Pedal feel was slightly more than stock which I liked, but the catch point was tricky. Felt similar to a 400hp evo with some aftermarket clutch I drove last year. Seems like people get good and bad ones but I know they are coming out with a revised Streetlite at the end of September that should make it easier to drive.
Anyone else? what about flywheels?
Old 09-15-2015, 02:53 PM   #13
NW86
Drives: 2014 Firestorm FR-S
Have competition clutch stage 4 with sprung 6 puck and lightweight flywheel. Clutch pedal is stiffer than stock. Catch point is a little tricky and there is a little chatter. Overall i like it.
NW86 is offline   Reply With Quote
The Following User Says Thank You to NW86 For This Useful Post:
Readytoxplod (09-15-2015)
Old 09-15-2015, 09:12 PM   #14
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
ACT SB7-XTSS after 500 miles disengages and engages like factory but with a stiff pedal. No chatter
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following 2 Users Say Thank You to GsxrMe For This Useful Post:
CSG Mike (09-16-2015), Dream20b (11-17-2015)
FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? bren5279 Engine, Exhaust, Transmission 8 09-22-2015 10:36 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
