Old 11-10-2015, 02:17 PM   #43
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by BRZoomTX View Post
Delicious Tung was your tune source? That is strange, considering they advertise as having boost cut in their tunes - http://www.ft86club.com/forums/showthread.php?t=52200
@DeliciousTuning - Any feedback regarding why a 7.5psi tune with boost cut would see 20psi?
Boost cut is an available feature within EcuTek, that is true. That post is in our general tuning thread, and should probably be updated to be more clear. As our typical Flash & Go tunes sit, there is physically not enough room in Custom Mapping to set up a boost cut. There is such little room available, in fact, that for turbo kits there isn't even room to add in our normal custom traction control mapping. We've asked for more room, and from what we've gotten back there simply isn't any available.
If there were, you're correct in that it would be very simple to set up and likely only take a table or two. With that said, we recommend that anyone wanting to do a boost cut simply setup something along the lines of an AEM Failsafe. I believe this was mentioned above as well, but a vac line or reference line popping off will cause these issues. OP's car was not overboosting on the last logs that I received, which would suggest that this is exactly what happened.
Sincerely,
Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
BRZoomTX (11-10-2015), u/Josh (11-10-2015)
Old 11-10-2015, 03:08 PM   #44
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by jsimon7777 View Post
Should've had a V8!
fixed
fumanchu1 is offline   Reply With Quote
Old 11-10-2015, 03:12 PM   #45
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Sincerely,
Zach
Appreciate the clarification. Definitely something that should be a little more clarified on the flash and go tunes I think. I've seen others with flash & go from you guys assuming they had boost cut in their tunes, which is why I commented regarding it.
Something like a wideband failsafe is definitely a lot more reliable in the long-run.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
Old 11-10-2015, 03:46 PM   #46
blueap2
Drives: '14 FR-S
@DeliciousTuning How would an AEM Failsafe be incorporated to add the boost cut feature in case of an overboost situation with your Flash and Go tunes?
blueap2 is offline   Reply With Quote
Old 11-10-2015, 06:38 PM   #47
DeliciousTuning
It would operate independently from the tune. From AEM's website:
"The gauge’s failsafe strategy is completely user definable, from something as simple as making the gauge flash to using the ground output to trigger a check engine light, to cut boost, retard timing, or even switch to a safety map using a standalone engine management system."
Sincerely,
Zach
Old 11-15-2015, 07:14 PM   #48
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Originally Posted by SoCal80six View Post
Yes I am tuned by delicious with ecutek .
Sent from my SM-N920T using Tapatalk
Same shit happened to me bro. I was on a 8 psi map when I overboosted and blew my block last December. I was also on the Delicious tune and was still on it up until I spun a rod bearing in my built Crawford short block. Switched to Church Performance and all is well. Oh and I was on e85 too. I feel your pain man. Good luck with whatever option you go with.
texasbound972 is offline   Reply With Quote
The Following User Says Thank You to texasbound972 For This Useful Post:
SoCal80six (11-15-2015)
Old 11-15-2015, 07:42 PM   #49
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Thanks bro cars going to the shop this week hoping I just blew a head gasket. Rods didn't break through block thank God so most likely will be building on to this block. What compression ratio did you end up going with?
SoCal80six is offline   Reply With Quote
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
About to be boosted! willharp360 Forced Induction 18 06-04-2015 10:15 AM
Boosted! FRS-cotty Northwest 21 03-13-2015 10:02 PM
My Boosted BRZ protpibe Member's Car Journals 84 09-22-2014 03:26 PM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
