Old 11-09-2015, 05:07 PM   #29
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by BRZoomTX View Post
Ah, damn... Sorry to hear that bud. Let us know once you've figured out what happened!
Will do
Sent from my SM-N920T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 11-09-2015, 06:52 PM   #30
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Dat China Express quality though...
OP blew his engine on a MAP turbo with a Delicious tune. It's not CXRacing's quality that's in question. OK, the CX turbo looks awful, but the LS mounts look just fine. Certainly a bit cheaper than what Vorshlag and weapons grade offer.
Old 11-09-2015, 07:09 PM   #31
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'm not suggesting in any way at all that the motor blowing had anything to do with CX racing... I'm just saying the mounts suggested are CX racing and they're well know for crappy quality, so if doing an LS swap which already entails tenths of thousands in itself, I'd go for something better quality out of the gate.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
wparsons (11-10-2015)
Old 11-09-2015, 07:36 PM   #32
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by SoCal80six View Post
Will be stripping it down in a few to see exactly what's going on with it.
As bad as this sounds but I really hope your crankcase is OK and only valve/rocker issue is found. Don't get frustrated. As long as this isn't your daily driver; You get to purchase a motor build stand, Forged Internals and a good old after work project is made! You had the setup for something great and now you have a good reason to make it awesome.
BTW,
I'm still waiting on the tear down report!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
SoCal80six (11-09-2015)
Old 11-09-2015, 08:46 PM   #33
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Couldn't find any damage to block don't think rod went through block at all. Found a little puddle of burnt oil by dump tube. And checked o2 sensors and they were full of oil. Will be taking off intake manifold to see if I can find any damage
Old 11-10-2015, 02:30 AM   #34
sw20kosh
Drives: 2013 Black FR-S
So oil in the exhaust system?
Old 11-10-2015, 06:13 AM   #35
FirestormFRS
Hit 19 psi on a few pulls before it blew but did the math and I hit approximately 16.82 psi on the run where it actually went out.
So you knew the car was way over boost and continued to do "pulls" until it blew? Most people would have stopped as soon as they seen the first log.
The boost protection may not have worked as intended, but the blown engine could have been easily avoided by parking the car until you could resolve the issue. My $.02.
FirestormFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to FirestormFRS For This Useful Post:
Tcoat (11-10-2015), wparsons (11-10-2015)
Old 11-10-2015, 07:14 AM   #36
GsxrMe
GsxrMe's Avatar
I'm really crossing my fingers for you. A bend valves that jammed a piston would be ideal.
2014 Subaru BRZ
Old 11-10-2015, 10:42 AM   #37
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Yes oil in exhaust.
Old 11-10-2015, 10:44 AM   #38
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
I parked and reflashed map to make sure the was no confusion with maps. Wasn't beating on it did only a 2nd gear pull.
Old 11-10-2015, 10:45 AM   #39
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
I'm hoping
Old 11-10-2015, 12:54 PM   #40
xxscaxx
Drives: 2013 SWP BRZ
Depending on how you want your map set up, boost cut may not be applied. I found this out after I had my map set up a certain way (I had a FnG flex fuel tune from delicious, and psi by ethanol content). Was told there wasn't any custom data tables left in ECUtek to have boost cut enabled.
I actually ended up overboosting as well, was suppose to be around 15 psi and shot up to about 22, but this was because of a miscommunication of how I should have my EBCS set up. After I took care of that I was still seeing overboost by about 3psi but nothing to the extent of what I did previously.
Not pointing fingers at anyone, just figured i'd share and pass along the information.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
raven1231 (11-10-2015)
Old 11-10-2015, 01:08 PM   #41
sw20kosh
No offense to anyone but you should really have over boost protection on a turbo car. All you need is a vacuum line to leak or pop off or a buggy/bad tune that doesn't have the ebcs settings calibrated correctly to get an overboost...
When I was turbo I remember hitting overboost protection many times.
The Following User Says Thank You to sw20kosh For This Useful Post:
xxscaxx (11-10-2015)
Old 11-10-2015, 01:47 PM   #42
xxscaxx
this 100%. Moreso the calibration of the EBCS being correct. I put AN fittings on all of my lines to prevent anything from popping off so I could rule that out and at the end of the day it was the ECBS calibration along with a few other things that were out of sync that were causing my issues. If OP didn't have it set on his map he may have been like me and assumed it was enabled (because I did after seeing it be a "standard" in the list of what comes on the tune). It was only until I overboosted and asked I was told it wasn't enabled.
SoCal80six (11-10-2015)
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
About to be boosted! willharp360 Forced Induction 18 06-04-2015 10:15 AM
Boosted! FRS-cotty Northwest 21 03-13-2015 10:02 PM
My Boosted BRZ protpibe Member's Car Journals 84 09-22-2014 03:26 PM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
