Old 11-07-2015, 09:29 PM   #925
JB86'd
JB86'd's Avatar
Drives: JAWS
@oldgunfan it'll get even better after about 50 miles once the throttle position and fuel trims are completely learned
JB86'd is offline   Reply With Quote
Old 11-07-2015, 09:40 PM   #926
ninedice
ninedice's Avatar
Drives: Series 10 #177 M/T
Any news on that Tune Bot feature?
ninedice is offline   Reply With Quote
Old 11-07-2015, 10:13 PM   #927
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Cool, Hell I could tell a difference when i pulled out of the driveway
oldgunfan is offline   Reply With Quote
The Following User Says Thank You to oldgunfan For This Useful Post:
Strife26 (11-07-2015)
Old 11-09-2015, 03:57 AM   #928
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Heres an OFT question:
Say I wanted to get a kraftwerks blower. Would I be able to use OFT to flash the tune to my ECU? Could the tune be uploaded to the device like normal?
riboyster is offline   Reply With Quote
Old 11-09-2015, 05:11 AM   #929
steve99
Drives: FT86
the oft like tactrix or ecutek flashes a complete rom or tune to the ecu.
You problem will be getting someone to tune the car for the kraftworks supercharger, the oft guys have only done the vortech sc kit and the sbd and oft 350 turbo kits.
if the kraftworks kit is arround 10psi boost thenit possible to do with opensource and if shiv adopts ztans speed density work then higher boosts likely possible.
however many tuner wont work with opensource as they cannot protect their work, if you can get car to shiv it should not be a problem or another tuner prepared to work with opensource
Old 11-09-2015, 10:37 AM   #930
riboyster
riboyster's Avatar
Don't they ship the base tune with the sc?
ScreamingElectron - SnakeShit
Old 11-09-2015, 11:56 AM   #931
_gt86_user
Inactive
Drives: .
Yeah they do, but a locked file for ecutek not oft
_gt86_user is offline   Reply With Quote
Old 11-09-2015, 12:39 PM   #932
Gringosteve
Drives: UK Spec GT86
I was wondering if the throttle blip feature ecuTek has is likely to be implemented soon?
Gringosteve is offline   Reply With Quote
Old 11-09-2015, 04:50 PM   #933
steve99
Drives: FT86
Very unlikely that type if thing requires a code patch to rom not just changing existing tables in rom
Gringosteve (11-09-2015)
Old 11-09-2015, 04:51 PM   #934
Gringosteve
Thanks, makes sense
Old 11-09-2015, 10:44 PM   #935
riboyster
riboyster's Avatar
So I understand that I can't view/edit it. But is it not able to be uploaded like any other file to the tablet, then flashed? One can drag and drop locked files around on a computer, after all.
Old 11-10-2015, 12:16 AM   #936
steve99
Drives: FT86
Hmmm unfortunately not, you have been spoiled by open source /OFT.
Ecutek is a good system but its very locked down
Ecutek tunes are delivered encrypted so if the tuner locks them which in this case they do, then you cannot view edit or even view the tune. all you can do is flash it.
When you flash the tune with ecutek it also changes the ecu seed keys so no other system other than ecutek can read or write to your ecu. Ecutek knows the tune written is locked so you wount just be able to read it out edit it or view it.
The tune is also locked to youe licience which is locked to your car. The licience is non transferable, the tune is non transferable in most cases.
The only way to get control of your ecu again is to flash an ecutek "stock rom"
You also need to buy an ecutek licience about $300 and an ecutek cable to be able to flash tunes yourself cable about $400.
If you going to switch to ecutek, make sure you flash your stock tune to the car BEFORE , you flash anything with ecutek, then you will be able to sell your OFT.
Once you flash with ecutek or a tuner flashes your car with ecutek you will no longer be able to use the OFT for anything but logging.
Old 11-10-2015, 12:58 AM   #937
riboyster
riboyster's Avatar
Wow that's lame. 50% of the reason I got OFT was because I thought it would flash ecutek files. Oh well, hopefully Shiv and the guys decide to get a kraftwerks blower. Or it looks like I'll be waiting till my move to Montana and limping my car to Cali every weekend.
I'm all for speed density, as sketchy as it is. I suppose I'll always prefer raw data over calculated stuff, but it'll work in the meantime.
Old 11-10-2015, 02:05 AM   #938
Kodename47
Kodename47's Avatar
Drives: UK GT86
That's not true, tunes are licensed to the dongle not the ECU/car.
.: Stealth 86 :.
Kodename 47 DJ:
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
