Old 11-08-2015, 05:35 AM   #1
Diz86x
Drives: GT86 Nur spec
Late rpms
When i push the pedal to the max it lags at 7k rpm. Anyone know a solution or whats the reason ? Help
Diz86x is offline   Reply With Quote
Old 11-08-2015, 10:04 AM   #2
In what gear? At what speed? Sitting at a stop in neutral? What are the circumstances and what do you mean it "lags"?
You question is totally unanswerable with the info you have provided.
Freeman (11-08-2015), humfrz (11-08-2015), mizzta21 (11-08-2015), Wayno (11-08-2015)
Old 11-08-2015, 04:54 PM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Diz86x View Post
I don't understand how this is related to your "late rpms" issue.
The Following 5 Users Say Thank You to Captain Snooze For This Useful Post:
cdrazic93 (11-08-2015), DocWalt (11-08-2015), Fakk (11-10-2015), kch (11-09-2015), Ultramaroon (11-08-2015)
Old 11-08-2015, 05:16 PM   #4
In his defense that line does contain as much valuable information about his issue as the rest of the post.
Captain Snooze (11-08-2015), cdrazic93 (11-08-2015), DocWalt (11-08-2015), kch (11-09-2015), Ultramaroon (11-08-2015), wparsons (11-08-2015)
Old 11-08-2015, 05:53 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Honey, I think we might be having a family sooner than we thought... my rpms are late.
Originally Posted by humfrz
I'm old and lazy
The Following 5 Users Say Thank You to Clipdat For This Useful Post:
Captain Snooze (11-08-2015), GotBRZ1691 (11-08-2015), jawn (11-08-2015), JB86'd (11-08-2015), wparsons (11-08-2015)
Old 11-08-2015, 05:59 PM   #6
jvincent
jvincent's Avatar
I am good at deciphering cryptic noob.
I think the OP is talking about the fuel cut / rev limiter. On the stock ECU program it is very intrusive and kicks in really hard. If you are running on OFT tune it is much more gradual.
Old 11-08-2015, 06:05 PM   #7
ryoma
ryoma's Avatar
the solution is to shift to the next gear lol
The Following User Says Thank You to ryoma For This Useful Post:
Clipdat (11-08-2015)
Old 11-08-2015, 06:42 PM   #8
JB86'd
JB86'd's Avatar
Drives: JAWS
well this engine stock starts to lose power at 7k, AND has a hard rev limiter at 7400..I set my shift light/beep to 7100 and call it a day
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Old 11-08-2015, 08:55 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Well, even if this engine produces less power at higher rpms, it makes sense to not gear up too quick to get most out of car & engine:
Just 10% less power & torque at top rpms than that of at peak is way more powerful at lower gear due different gearing ratio in transmission then too hastily switched gear up at lower rpms and less favorable gearing ratio of next gear. I'd gear up sooner only on 1st, when redline nears so fast, that it's easy to hit hard rev limit and loose some acceleration due stagger from ecu cutting power in very abrupt way.
Old 11-08-2015, 11:19 PM   #10
I think you're right about the situation being related to the rev limiter.
I would suggest to the OP that he set the shift light to about 6,500 rpms ..... that way, the engine will most likely get shifted before it hits the fuel cutoff point.
Personally, I set mine at 6,000 rpms ........ cause it takes me a while to see the light and react ......
Clipdat (11-09-2015)
Rattling in 2nd or 3rd at low rpms BigFatFlip Engine, Exhaust, Transmission 54 09-07-2015 08:54 PM
RPMs for best 0-60 MurderRider Scion FR-S / Toyota 86 GT86 General Forum 8 07-19-2014 12:29 PM
Turbo RPMs Fabron757 Forced Induction 11 04-02-2013 04:35 PM
Where are your RPMS Dragon86 CANADA 13 07-26-2012 10:43 AM
RPMS!! Spencer Strayer Engine, Exhaust, Transmission 82 09-15-2011 09:51 AM
