Old 11-07-2015, 06:43 PM   #1
Tekno Virus
Drives: 2015 Subaru BRZ Limited
"krrrnnnkkk" noise when the differential locks up?
HI guys, whenever I make a hard turn and the differential locks up I guess to divert the torque to the o the r wheel, it makes a KRRRRRNNNNNKKKTTTTT noise.
I was wondering if that was normal?
Sent from my E6683 using Tapatalk
Tekno Virus is offline   Reply With Quote
Old 11-07-2015, 06:48 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Not on my stock differential, does this happen with the traction and stability control on? Could possibly be electronic brake force distribution kicking in and independently braking the inner wheel to the corner
Old 11-07-2015, 06:51 PM   #3
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
you sure it's not traction control kicking in and braking one wheel? lol
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 3 Users Say Thank You to Aztec For This Useful Post:
FRSBRZGT86FAN (11-08-2015), soulreapersteve (11-08-2015), Ultramaroon (11-07-2015)
Old 11-07-2015, 07:27 PM   #4
Feel it, or hear it? For sharp turns at low speed, a little rumble in the butt is normal but get it checked if you actually hear anything.
Wait, how fast are you going? @Aztec has a point.
Old 11-07-2015, 08:03 PM   #5
Tekno Virus
It's probably traction control. (I've never driven a car with traction control or with that many features tbh).
Old 11-07-2015, 08:28 PM   #6
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Outside rear wheel?
ottoyu34 is offline   Reply With Quote
Old 11-07-2015, 08:50 PM   #7
stevesnj
stevesnj's Avatar
Go into pedal dance, see if it still does it.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tekno Virus (11-07-2015)
Old 11-07-2015, 09:13 PM   #8
When I first started driving mine, I found a big empty parking lot and experimented with the TC/VSC. It's worth getting to know how it responds, as well as how the car behaves when they're disabled.
It's a nice predictable RWD vehicle. If the nannies are kicking in on public roads, you're likely driving way outside the safe zone. Take it back a notch.
Old 11-07-2015, 09:24 PM   #9
Tekno Virus
Originally Posted by ottoyu34 View Post
Outside rear wheel?
Inside rear wheel
Thanks, I appreciate all the help. Y'all the best.
I just did a few trial runs on the way from the grocery store in this rainy weather, and the ABS (I had to put the window down and really tune in to found out it wasn't the diff) kicks in when the tail should slid out and at the point where I should be countersteering. Obviously, I didn't counter steer since the ABS redirected the car for me.
I have done inertial drift when you only need a little bit of counter steering and where the weight is evenly distributed. I think the key is keep the weight evenly distributed to not make the ABS kick in (or pull the fuse out).
Old 11-07-2015, 09:59 PM   #10
Inside rear wheel
Personally, I find the nannies quite annoying. ABS is a different thing altogether. You're talking about VSC - Vehicle Stability Control. Look for the Pedal Dance thread for more info but in summary:
Engine must be at normal operating temperature. Even a little cool will lock out the mode.
Within 30 seconds of starting the engine
1. pull handbrake 3 times and hold
2. push brake pedal 3 times and hold
3. repeat step 1
4. push brake pedal twice
This cuts all the vehicle stability functions except ABS.
Old 11-08-2015, 12:30 AM   #11
FRSBRZGT86FAN
Inside rear wheel
Nope, it's not really the ABS but rather a function derived from it called EBF as I said in my first post called Electronic brake force distribution, to disable it you simply do the Pedal Dance as someone else said. It will disable the EBF, all traction control, as well as the panic braking function, the only thing that will be on is ABS so you don't go full lock braking into a pole.
Old 11-08-2015, 04:21 AM   #12
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
The nannies kicking in, that's simply it.
I've been sliding around the past couple of days... lol
The Twins make me smile
Old 11-08-2015, 05:32 AM   #13
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
"krrrnnnkkk" ??? I think you need to top off the Krunk Juice in the Krunk reservoir.
Intent > Content
The Following 3 Users Say Thank You to solidONE For This Useful Post:
soulreapersteve (11-08-2015), stevesnj (11-08-2015), Tcoat (11-08-2015)
Old 11-08-2015, 11:49 AM   #14
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
sounds like auto brake [from nannies]. So give your poor car break.
The Following User Says Thank You to Packofcrows For This Useful Post:
Tekno Virus (11-08-2015)
Window making a loud "crack" noise - any ideas? jermyzy Issues | Warranty | Recalls / TSB 42 10-24-2024 12:02 AM
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
"Tink" noise, What torque spec do you use for rear axle nut? Vmax911 Engine, Exhaust, Transmission 7 09-15-2015 07:01 PM
"clacking" noise near tranny area? QckFR-S Issues | Warranty | Recalls / TSB 24 05-11-2014 12:33 AM
