Old 10-30-2015, 07:35 PM   #1
Iwannajag
Drives: 13 FR-S whiteout / blue w2w
DTC-70 vs .....
Has anyone compared this pad against others ? I am running 70 upfront and 60 in the rear. standard OEM rotors, and brake ducts. 2900lbs race weight, dedicated W2W FRS. Torque 700 fluid
The Carbotech XP20/24 see to have much high temp range, however I have no issues with the DTC 70/60 combination, but will need new pad for the season, so just wondering what else it out there.
Iwannajag is offline   Reply With Quote
Old 10-31-2015, 12:27 AM   #2
CSG Mike
CSG Mike's Avatar
How's your pad wear? Why the stagger?
Old 10-31-2015, 01:41 PM   #3
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Dedicated W2W?
Raybestos ST45 on all 4 corners for dry track, ST42 for Wet track.
PRO86 | WTCC | STL
Old 11-02-2015, 07:16 AM   #4
IPGJames
Drives: ...Cars...
I was just talking to someone at the track this past weekend about this....here is the traditional route i see everyone take....
Hawk HP+ on the car as a street/track car...then they put DTC-60 or DTC-70 on the car because they get more serious and Hawk has the market penetration...and then they find Porterfield, Raybestos, Carbotech, etc and use those and realize the Hawk stuff is not even in the ballpark compared to how good the other stuff is. I sell and believe in the Hawk products as a great entry level option. Easy to get and priced well, once you get more serious though there are better pad options.
i have traditionally run raybestos ST43's on my track cars with great success, currently have Ferrodo DS1.11 on my BRZ loving them
I would recommend you call the manufacturers and talk to the tech people there. They are all smart...they all understand pads, applications, etc...use their direct knowledge. Everyone is going to have different experiences with pads...I have a friend that hates the ST43's that I really like but the ST42's work great for him...just different braking styles get the pads to work differently. Will be worth your time to talk directly to the sources though and worth you time to try a different compound.
IPGJames is offline   Reply With Quote
Old 11-05-2015, 10:58 PM   #5
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
Agree, had good time with Hawk during track day time, but once stepped into racing, it doesn't work well for me after some laps.
owenxguo is offline   Reply With Quote
Old 11-07-2015, 01:52 AM   #6
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I am running the AP Sprint kit and I am running the DTC-70 / DTC-60 combo as well. I have run EBC Yellow, Project Mu 999s, Carbone Lorainne's, etc... and I have found the Hawk's to be comparable. The 999s are definitely the smoothest, then the EBC Yellows. The CL's were the most on-off. Once the Hawks are warm, they are smooth and consistent. I may try the DTC-60 square and see if that helps to keep heat in them. Ultimately, the Hawks are almost free (about $50) for me with the NASA contingency and I cannot justify spending $300+ on a pair of pads. While the 999s are awesome, they are not twice as good as the Hawks and definitely not 6x better. Honestly, if you can find Pagid RS19 pads for our car, they would be better than any of these options.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following User Says Thank You to zdr93523 For This Useful Post:
Pat (11-07-2015)
Old 11-07-2015, 02:42 PM   #7
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
The major problem for me with Hawk is brake fade, I'v used DTC70 on my s2000 with Wilwood and Stoptech ST40 setup, both have soft paddle issue after certain laps, I thought it might be fluid or something else at first place because Hawk claimed DTC70 as the their top product in competition line, so I changed fluid from Motul 660 to Endless and bleed again and again, never fixed. Then I tried same pads on my friend's Toyota Yaris race car with AP 5000+ calipers, and it happens all the time, that car weighs only 900kg. So at the end i figured it was really the pad, now I had Wilwood front and rear kit on my BRZ with Wilwood H compound, never have any issue so far.
Old 11-07-2015, 11:25 PM   #8
zdr93523
zdr93523's Avatar
I am running TT now but I may change my opinion once I start competing in the race group. So far, I have had no issues with fade. I would imagine the track would make quite a difference on how brake heavy it is.
www.makesmodels.com
www.camautomag.com
Old 11-07-2015, 11:53 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Anyone seriously fast ever take the PFC 08 out?
Old 11-08-2015, 01:46 AM   #10
rice_classic
Put me in that camp. Fellow racer with identical race car loved the 43's while I hated them. The reason.. inconsistency. They were brilliant when they worked right but sometimes they would have uneven transfer layer issues or neglect putting down a layer at all and eat the rotors alive. Doing a 30 minute race with your steering wheel shuddering sucks and then when you find out half your rotor face is missing as well that sucks too.
The ST45 is the "new 43". They grab like the 43 at all temp ranges and will work even if you brake late through the 7th level of Dante's Inferno and on top of all that, they have the buttery delicious transfer layer consistency of the 42. If "Jesus the carpenter" came back as "Jesus the racing brake pad manufacturer", the ST45 is the brake pad he would create. They turn braking atheists into devout late-brakers by the end of the race.
You know the guy who said, "wait until you see God then brake." If he was using ST45's, he would have said, "Wait until you brake, then you'll see God!"
I found a picture of their performance characteristic...
Hallelujah, I made the corner!
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
zdr93523 (11-08-2015)
Old 11-08-2015, 04:09 PM   #11
zdr93523
zdr93523's Avatar
My Porsche has PFC's. They're great pads too. No issues.
www.makesmodels.com
www.camautomag.com
EAGLE5 (11-08-2015)
