#57 |
I buy the filter from a local Subie dealer the same day I do the oil change and use a cc for the purchase that way I have two ways to confirm the date. I figure as long as I have a firm purchase date and a consistent story I have a leg up if I need it.
#58 |
Drives: Lightning Red BRZ - Premium 6MT
I was able to get them to fix it!!! Thank God!
Brand new engine in a couple of days
Mods done (RED), Mods to come(BLACK): LED Swap, GReddy SP Elite Exhaust, Leather Seats, TSW 18x8.5 + 235/35, MOTIV Over & Catless Test pipe, EcuTek 93 Octane tune, PERRIN Lightweight Pulley, PERRIN Intake Inlet + drop-in filter,, e85 fuel map, 5axis Spoiler?, Borla UEL Headers? |
| The Following 5 Users Say Thank You to johatan25 For This Useful Post: | Dadhawk (11-06-2015), Lonewolf (11-06-2015), new2subaru (11-06-2015), Packofcrows (11-05-2015), Tcoat (11-05-2015) |
#59 |
Some guy on here said he takes a pic of the oil and filer receipt beside the odometer. Always thought that was a great idea.
#60 |
Drives: BRZ DGM Limited
#61 | |
Drives: Scion FRS
Did you say you had an OFT tune and the dealer did not detect it? Or the dealer did not care? I have been itching to flash mine with the OFT but only reason that kept me from doing it was I thought it would void my factory warranty on my 2013 FRS. Can you shed more light? |
#62 |
Drives: GT 86
An update on the FA motor that my friend built is a bit of a concern.
It was decided for various reasons that the timing cover needed to come off to check something after it had been fitted . Silastic had been applied to all surfaces including the main oil gallery from the block to the timing cover where the oil pump is located with the O'ring installed. On removal of the timing cover it was found that the mating surfaces between the block and the timing cover for the oil gallery did not meet as NONE of the silastic was squished out from the mating surfaces if that makes sense. It could be seen that the O'ring was only just contacting on one side by a hairline so this could be another point for oil starvation as the oil pump could possibly suck air at this point . Will try to get some pics up if people are interested. |
#63 | |
I think I understand what you found but pics would be great |
#64 | |
Drives: 2013 WRB BRZ
#65 | |
Wait so you’re saying that common timing cover leak caused you to leak enough oil to spin a rod bearing? How often do you check your oil? I have this leak but it’s hardly enough to notice a loss between oil changes much less routine oil level checks. At the rate mine is leaking it would probably take years to get to a critical level. |
#66 | |
"Originally Posted by sam69 An update on the FA motor that my friend built is a bit of a concern. It was decided for various reasons that the timing cover needed to come off to check something after it had been fitted . Silastic had been applied to all surfaces including the main oil gallery from the block to the timing cover where the oil pump is located with the O'ring installed. On removal of the timing cover it was found that the mating surfaces between the block and the timing cover for the oil gallery did not meet as NONE of the silastic was squished out from the mating surfaces if that makes sense. It could be seen that the O'ring was only just contacting on one side by a hairline so this could be another point for oil starvation as the oil pump could possibly suck air at this point . Will try to get some pics up if people are interested." At least it did to me ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Shibby (01-31-2018) |
#67 | |
#68 | |
Oh okay I’ve gotcha. Eventually I will pull my cover and repack it. Its just not leaking enough to motivate me to go through the hassle yet. I hate doing FIPG’s. Cleaning up the old mess is a pain, applying it is a pain. Bump it on install and you get to redo part of it. Ugh. At least doing it myself I will have the peace of mind knowing someone didn’t blob massive quantities of packing on it. |
#69 | |
Drives: .
Around 1500 km after the last time they "fixed" it - I was driving along, and got the dreaded bearing knock noise.
"Some will follow your footsteps, easier than they will your advice."
#70 |
I'm thinking that if I ever get a timing cover leak, I'm just going to tape a sponge over the leak and change it every now and then ...........
![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | 22R (02-05-2018), strat61caster (02-01-2018) |
| STOCK MOTOR 3k | Anthony7515 | Engine, Exhaust, Bolt-Ons | 16 | 11-25-2014 03:48 PM |
| Stock Motor | Cross | Want-To-Buy Requests | 2 | 08-01-2014 06:47 PM |
| Spun out and hit a curb... | JohnAyySays | Issues | Warranty | Recalls / TSB | 54 | 12-09-2013 10:59 AM |
| Avoided deer, spun out, alignment needed? | gatorbushmen | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-28-2013 11:14 AM |
| Spun out now a CEL | Noob4Life | Issues | Warranty | Recalls / TSB | 10 | 03-30-2013 11:02 PM |
