Old 11-03-2015, 09:10 PM   #15
shern
Drives: 2015 fr-s
Yeah man everything came out fine, idk when i lift up the lever it twists slightly to the right, i had a shift knob stuck on there that wouldn't come out so i used a pipe wrench to get mor torque and it took a lot of pressure for it to come off so idk if i messed something small or i have to replace the whole thing
shern is offline   Reply With Quote
Old 11-03-2015, 11:16 PM   #16
Oh, it's fucked. The lever is not solid down lower. It's hollow with a slot that houses the return spring for the lockout mechanism. You twisted it.
It's worth $170 bucks to remove the whole thing and see if you can repair it.
Do NOT try to twist it back while it's installed. The pin in the shift linkage is the only thing that keeps it from rotating. You absolutely don't want to damage that.
Old 11-03-2015, 11:55 PM   #17
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
if under 35k gogo dealer forgot to mention
Old 11-04-2015, 02:53 AM   #18
shern
Drives: 2015 fr-s
i can always buy a used shifter right ?
Old 11-04-2015, 02:55 AM   #19
shern
Drives: 2015 fr-s
I can always buy a used shifter ? so what i messed up was the shifter not anything crazy serious
Old 11-04-2015, 02:58 AM   #20
Yeah. The pin in the shift linkage is pretty stout but don't take any more chances. I still say take it out and try twisting it back. I bet it will be ok.
rekt ☐ not rekt ☑
Old 11-04-2015, 03:00 AM   #21
shern
Drives: 2015 fr-s
Yeah. The pin in the shift linkage is pretty stout.
rekt ☐ not rekt ☑
Okay good cause i only have like 8k mikes on it an unfortunately this happen do you know how much a used stock shifter would cost?
Old 11-04-2015, 03:12 AM   #22
ryoma
ryoma's Avatar
take this chance and buy a short shifter lol
http://www.ft86speedfactory.com/kart...l#.Vjmv7vmrSHs
I can sell you my stock one for $50, but I need to see if I can find it first. it's somewhere in my garage. I'll look for it tomorrow. I'm in La Quinta
Old 11-04-2015, 03:23 AM   #23
There u go!
Old 11-04-2015, 12:40 PM   #24
shern
Drives: 2015 fr-s
There u go!
okay that sounds perfect I'm in palm desert !
Old 11-04-2015, 01:02 PM   #25
shern
Drives: 2015 fr-s
Okay man sounds good yeah i live in palm desert! hopefully you can find it my luck has been really bad with my car these past few weeks
Old 11-04-2015, 08:13 PM   #26
ryoma
ryoma's Avatar
is this everything you need?
you might need to regrease the botton joint, but there's some extra grease left that I didn't use on my kartboy.
Old 11-04-2015, 11:20 PM   #27
shern
Drives: 2015 fr-s
Yeah man thats everything that i need! is it easy to instal these? Ill pm you so you can shoot me a text
Stiff to engage 1st/reverse from a stop after clutch install mhiscott Engine, Exhaust, Transmission 94 07-19-2020 08:11 PM
wtb oem reverse lockout Vincenttam Want-To-Buy Requests 0 02-09-2015 06:41 AM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 09:47 PM
FS: raceseng reverse lockout red White0utFrs Interior Parts (Incl. Lighting) 3 04-12-2014 02:15 PM
