Old 10-14-2015, 06:29 AM   #15
steve99
Drives: FT86
Originally Posted by Novaft86 View Post
So i have an aftermarket steering wheel and the resistors are in never had issues. Then installed hids which i dont see causing an issue but it started happening after they were installed. During the day the light isnt on once night comes and i start the car the light is on. Any help?
It likely the hid , some aftermarket hid kits cause all sorts of weird problem as the electronics in them are poor quality and introduce electrical noise into the system upsetting the cars sensors or electronic control units..
disconnect hids and see if problem goes away.
Old 10-14-2015, 07:16 AM   #16
This^^ It is well documented that some of the aftermarket units cause BCU issues. These issues show symptoms ranging from total ECU failure to intermittent and seemingly absurd unrelated conditions. This is just another to add to the list.
Old 10-14-2015, 09:41 AM   #17
Novaft86
Drives: '13 Firestorm FR-S
Ill have to give that a try then ill post the results
Club: Made Unequal (Natl. V.P.)
IG: novaft86
Novaft86 is offline   Reply With Quote
The Following User Says Thank You to Novaft86 For This Useful Post:
Tcoat (10-14-2015)
Old 10-14-2015, 01:09 PM   #18
stevesnj
stevesnj's Avatar
Put the old lights back in and see if the light comes on. If not it's the HIDs...somehow
My 2016 Build thread
Old 10-14-2015, 01:13 PM   #19
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
It's not that mysterious. A ton of the accessories are wired via CANBUS, and a ton of the accessories are wired through the BCU. Electrical noise, differences in power consumption, differences in resistances, or shorts can do a number on these systems.
jawn is offline   Reply With Quote
The Following 2 Users Say Thank You to jawn For This Useful Post:
stevesnj (10-14-2015), Tcoat (10-15-2015)
Old 10-14-2015, 01:26 PM   #20
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
lesson of the day : get cheap stuff but not too cheap. :P
Old 10-15-2015, 12:13 AM   #21
Novaft86
Lessons learned indeed
IG: novaft86
Old 10-15-2015, 07:14 PM   #22
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Can you take photos of the ballasts and such so we can see its specs?? I recommend getting a CANBUS HID kit from diode dynamics they have quality parts that are worth the $150, if my OLMs ever have an issue that's what I'll go to
Old 11-01-2015, 07:08 PM   #23
Novaft86
Well after some time i think i finally figured what it was. And im pretty sure it only happens when it gets below a certain temperature outside more than likely causing a resistor pin to shrink somewhat and not be in full contact
IG: novaft86
Old 11-01-2015, 07:51 PM   #24
FRSBRZGT86FAN
Good fix
Old 11-01-2015, 09:35 PM   #25
White64Goat
Ask George Costanza about shrinkage.............
Old 11-02-2015, 04:29 PM   #26
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if you mount your ballast very close to ABS, it causes light to be on.
BRZ seats installed into FRS... Airbag Light Wpomp Cosmetic Modification (Interior/Exterior/Lighting) 39 03-27-2021 03:07 PM
Airbag Light adamg Cosmetic Modification (Interior/Exterior/Lighting) 3 02-27-2015 11:21 AM
Airbag light on after mod install SurfAndSand Engine, Exhaust, Transmission 1 10-23-2013 10:50 AM
Airbag Light Delete Juurian Electronics | Audio | NAV | Infotainment 0 06-20-2013 08:37 PM
Airbag light norcal_brz Issues | Warranty | Recalls / TSB 6 03-27-2013 02:59 PM
