Drives: '13 Firestorm FR-S
Airbag light on only at night
So i have an aftermarket steering wheel and the resistors are in never had issues. Then installed hids which i dont see causing an issue but it started happening after they were installed. During the day the light isnt on once night comes and i start the car the light is on. Any help?
Club: Made Unequal (Natl. V.P.)
IG: novaft86 |
Drives: 2015 CWP BRZ Limited
How are your HIDs wired in? Relay or direct?
Direct
IG: novaft86 |
Barring a short, the only thing I can think of is that HIDs draw significantly lower amperage during operation than incandescent bulbs. This might be a CANBUS issue, and the ECU might be expecting a certain total amperage from the system. What resistance are your resistors?
Ive had the lights on during the day to check if that was why and no airbag light came on. Two 20 or 2 ohm cant remember
IG: novaft86 |
What brand/model HID kit is it? I would look into a CAN BUS ballast if possible as well if it plugged directly into the stock connector
Ill have to look at brand but it has a ballast that goes to the original plugs
IG: novaft86 |
Contract? /人◕ ‿‿ ◕人\
No hate or judgement here.
Did you buy it cheap from ebay? like under 50 dollar cheap? |
From a car show for 80
IG: novaft86 |
#10 |
Yeah, I'd swap for a CANBUS ballast, or check for a short. Maybe go back to stock for a bit, and see if it that resolves the issue. I think Diode Dynamics has a CANBUS ballast as part of their HID kit.
Asides from the airbag light, is there anything else that behaves a little wonky? |
#11 |
Everything else runs smooth just that issue at night
IG: novaft86 |
#12 |
#13 |
Drives: Toyota Highlander; Subaru BRZ (SWP)
Could your area be much more humid during the night? Maybe that's screwing up with some sort of component.
#14 | |
Disconnect the HIDs, and drive around a bit at night SAFELY in a parking lot without headlights and see if the airbag light returns
| BRZ seats installed into FRS... Airbag Light | Wpomp | Cosmetic Modification (Interior/Exterior/Lighting) | 39 | 03-27-2021 03:07 PM |
| Airbag Light | adamg | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 02-27-2015 11:21 AM |
| Airbag light on after mod install | SurfAndSand | Engine, Exhaust, Transmission | 1 | 10-23-2013 10:50 AM |
| Airbag Light Delete | Juurian | Electronics | Audio | NAV | Infotainment | 0 | 06-20-2013 08:37 PM |
| Airbag light | norcal_brz | Issues | Warranty | Recalls / TSB | 6 | 03-27-2013 02:59 PM |
