Old 10-13-2015, 10:29 PM   #1
Novaft86
Drives: '13 Firestorm FR-S
Airbag light on only at night
So i have an aftermarket steering wheel and the resistors are in never had issues. Then installed hids which i dont see causing an issue but it started happening after they were installed. During the day the light isnt on once night comes and i start the car the light is on. Any help?
Club: Made Unequal (Natl. V.P.)
IG: novaft86
Novaft86 is offline   Reply With Quote
Old 10-13-2015, 10:33 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
How are your HIDs wired in? Relay or direct?
jawn is offline   Reply With Quote
Old 10-13-2015, 10:42 PM   #3
Novaft86
Direct
IG: novaft86
Old 10-13-2015, 11:01 PM   #4
jawn
jawn's Avatar
Barring a short, the only thing I can think of is that HIDs draw significantly lower amperage during operation than incandescent bulbs. This might be a CANBUS issue, and the ECU might be expecting a certain total amperage from the system. What resistance are your resistors?
Old 10-13-2015, 11:09 PM   #5
Novaft86
Ive had the lights on during the day to check if that was why and no airbag light came on. Two 20 or 2 ohm cant remember
IG: novaft86
Old 10-13-2015, 11:40 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
What brand/model HID kit is it? I would look into a CAN BUS ballast if possible as well if it plugged directly into the stock connector
Old 10-13-2015, 11:42 PM   #7
Novaft86
Ill have to look at brand but it has a ballast that goes to the original plugs
IG: novaft86
Old 10-13-2015, 11:46 PM   #8
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
No hate or judgement here.
Did you buy it cheap from ebay? like under 50 dollar cheap?
The Twins make me smile
Old 10-14-2015, 12:49 AM   #9
Novaft86
From a car show for 80
IG: novaft86
Old 10-14-2015, 01:12 AM   #10
jawn
jawn's Avatar
Yeah, I'd swap for a CANBUS ballast, or check for a short. Maybe go back to stock for a bit, and see if it that resolves the issue. I think Diode Dynamics has a CANBUS ballast as part of their HID kit.
Asides from the airbag light, is there anything else that behaves a little wonky?
Old 10-14-2015, 01:20 AM   #11
Novaft86
Everything else runs smooth just that issue at night
IG: novaft86
Old 10-14-2015, 02:21 AM   #12
................ During the day the light isnt on once night comes and i start the car the light is on. Any help?
Maybe the light is always ON ...... and you can just SEE it at night ......??
Old 10-14-2015, 03:10 AM   #13
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Could your area be much more humid during the night? Maybe that's screwing up with some sort of component.
carma143 is offline   Reply With Quote
Old 10-14-2015, 03:59 AM   #14
FRSBRZGT86FAN
Wattage would be nice if possible as well, possibility is that if its a 55 Watt its burning some things out and creating too much draw at night only when it runs the longest.
Disconnect the HIDs, and drive around a bit at night SAFELY in a parking lot without headlights and see if the airbag light returns
BRZ seats installed into FRS... Airbag Light Wpomp Cosmetic Modification (Interior/Exterior/Lighting) 39 03-27-2021 03:07 PM
Airbag Light adamg Cosmetic Modification (Interior/Exterior/Lighting) 3 02-27-2015 11:21 AM
Airbag light on after mod install SurfAndSand Engine, Exhaust, Transmission 1 10-23-2013 10:50 AM
Airbag Light Delete Juurian Electronics | Audio | NAV | Infotainment 0 06-20-2013 08:37 PM
Airbag light norcal_brz Issues | Warranty | Recalls / TSB 6 03-27-2013 02:59 PM
