Old 09-02-2015, 08:21 AM   #1
15limited
15limited's Avatar
OLM Bixenon Projector Foglights:Review
First off, hey everybody, joined the forum a few months ago shortly after picking up my BRZ and would like to thank anyone who has contributed to the forum.
After adding a couple small Perrin parts, drift button and transmission mount, I decided I was gunna add some 3k (yellow) foglights, eventually I decided on a set of OLM bixenon projector foglights from subispeed.com. They run anywhere between $185-$245 depending on options you'd like included, ie; high beam, all in one ballast, relay harness. They also ship in a variety of temperatures, from 3,000-8000 k.
I ordered them with an attached compact ballast which simply plugged into the back of the bulb which inserts into the glass housings. Being as the car came with factory foglights everything was plug & play so after removing a few fender lining clips, and a bolt or two I simply swapped out the stock housing and halogen bulb with the new glass housing and HID bulb.Name:  uploadfromtaptalk1441195471857.jpg
So now you probably want to see the finished product right? Well I ended up doing the install without power over the weekend due to local storm weather, but when I get home from work tonight I'll edit some into the post 😚
Note: On Subispeed's tutorial for install on a WRX they say you can do the swap by simply turning your wheel to make room but I found it would be easier to simply just jack the car up and take the wheel off. Name:  uploadfromtaptalk1441195441541.jpg
Size:  34.1 KB Being as this is my first post and review if anybody has any comments or suggestions for future posts that be greatly appreciated, thanks!
Sent from my 831C using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following 2 Users Say Thank You to 15limited For This Useful Post:
DAEMANO (10-31-2015)
Old 09-02-2015, 08:27 AM   #2
15limited
15limited's Avatar
Glass projectors and HID's with all in one ballasts
The Following User Says Thank You to 15limited For This Useful Post:
DAEMANO (09-02-2015)
Old 09-02-2015, 11:27 PM   #3
15limited
15limited's Avatar
Pictures don't really do these things justice, neither do my cell phone photography skilz , but they put out some light! Name:  uploadfromtaptalk1441250788365.jpg
When they're not on its hard to tell the difference between the factory housing.
Old 10-31-2015, 10:34 PM   #4
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
What is the point of having Bi-Xenon foglights? There's a low and high beam to your fogs?
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
The Following User Says Thank You to iLaw For This Useful Post:
jawn (10-31-2015)
Old 10-31-2015, 10:39 PM   #5
15limited
15limited's Avatar
I believe they have a flapper that flips up to make them "high beams"
15' BRZ Limited 6MT Ice Silver Metalic
Old 10-31-2015, 10:42 PM   #6
iLaw
iLaw's Avatar
Does that get activated with a switch? When would you use that?
iLaw
Old 10-31-2015, 10:44 PM   #7
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Looks clean, but I'd never want my fogs to have a high beam.
jawn is offline   Reply With Quote
Old 10-31-2015, 10:48 PM   #8
15limited
15limited's Avatar
I'm not sure, subispeed says you can splice high beam function in so maybe just when you activate your headlight high beams? I've never felt the need for that much light.
Thanks! Instal was super easy and I love the look.
DIY Custom Door LED Projector jobe1022 DIY (Do-It-Yourself) Guides 7 07-11-2015 01:40 PM
FS: FRS foglights whitefrs Exterior Parts (Aero, Lighting, Etc.) 11 04-28-2014 04:36 PM
Does anyone in the US with an FR-S have Foglights??? pituala Cosmetic Modification (Interior/Exterior/Lighting) 42 01-30-2014 11:15 AM
Retroquik kit bixenon + functional led 9005 drl bulbs? eddieEndo Cosmetic Modification (Interior/Exterior/Lighting) 12 04-27-2013 06:06 AM
