Old 04-16-2013, 06:22 PM   #1
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
Retroquik kit bixenon + functional led 9005 drl bulbs?
Both my led drl bulbs burnt out for some reason and I was wondering if it could be from my bixenon setup??? anyone have a bixenon retrofit and running led drls? (the 9005 bulbs)
eddieEndo is offline   Reply With Quote
Old 04-16-2013, 06:27 PM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Yup.. I'm runnin retrofits and led DRL's.. So far no problems what so ever
Gixxersixxerman is offline   Reply With Quote
Old 04-16-2013, 06:30 PM   #3
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
damn they probably just burnt out then huh... there's no way to really mess up the splitter
Old 04-16-2013, 06:40 PM   #4
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
are you using the high beam splitter to get your leds to work??? I'm concerned as to whether this process could have shorted my bulbs out
Old 04-16-2013, 07:00 PM   #5
Gixxersixxerman
Yeah running the splitters from TRS.. Some bulbs do short out.. They run hot.. Very hot, and I've seen them melt the solder and short out
Old 04-17-2013, 12:16 AM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Cheap bulbs run hot. LEDs should NOT be hot
Old 04-17-2013, 12:20 AM   #7
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
the quality of the bulbs i use is not in question they were nicd!!!
Old 04-17-2013, 12:20 AM   #8
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
probably just a fluke im gonna try new bulbs
Old 04-17-2013, 01:24 AM   #9
Gixxersixxerman
Ive dealt with some really high end LED, and they run hot to, even with the proper heat sinks, they are still turning energy into light so making heat.. it needs to run as cool as possible, but when you make a 120 chip circuit in such a small package, they are going to get hot
Old 04-17-2013, 10:02 AM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I think the difference lies in what we mean by hot.
I know heat is produced. Just mean they should not run hotter than traditional bulbs or HID's if the unit is built properly.
Old 04-26-2013, 03:41 PM   #11
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Which LED did you use?? do you have picture of it?
Old 04-26-2013, 06:34 PM   #12
Gixxersixxerman
My LED's are from concept3led. A vender here on the site.. I believe he has his products in the group buy section..
Old 04-27-2013, 06:06 AM   #13
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
I am running the same retroquick kit and LED drls as well with no problems. I'm trying to remember where I got them...
FastLane1000 is offline   Reply With Quote
DIY Functional FR-S Fog Light Delete Grill thejevans DIY (Do-It-Yourself) Guides 18 02-15-2016 01:29 PM
Functional tire combo tintumz22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 02-06-2013 12:12 PM
Functional and Simple Plate Covers Wesley Cosmetic Modification (Interior/Exterior/Lighting) 2 01-13-2013 08:51 PM
86 Knee Pads Functional? wootwoot Cosmetic Modification (Interior/Exterior/Lighting) 13 08-12-2012 11:32 AM
