Old 09-25-2015, 04:10 PM   #43
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
We've been playing around with a few different splitter ideas, trying to maximize what the rules allow us to do.
Plywood is always good for the mock up.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
DustinS (09-25-2015)
Old 10-08-2015, 08:50 AM   #44
Sorry for the lack of updates lately guys, we've been hard at work prepping the car for the 13 hour endurance race at VIR on the 24th.
Here's a picture of some quick and dirty bracing we made for the wing on the trunk.
Old 10-09-2015, 05:47 PM   #45
Tires! tires and wheels!
And then we're kicking around an idea for some Auxiliary lighting
JTOFJPN (10-09-2015)
Old 10-09-2015, 08:59 PM   #46
15limited
15limited's Avatar
I'm a fan of the bumper mounted lighting as apposed to the hood mount rally style car looks awesome regardless. How'd that koyorad fit? Stock location still?
Sent from my 831C using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 10-09-2015, 09:12 PM   #47
JTOFJPN
You're like the...
JTOFJPN's Avatar
Drives: '13 6MT FRS / '14 Ram 1500 Sport
Would love to see a couple photos of how much that light bar brightens up a road vs a photo of stock headlights, been thinking of doing this as well
2013 Whiteout 6MT FR-S
2014 Ram 1500 Sport
JTOFJPN Build Thread
JTOFJPN is offline   Reply With Quote
Old 10-09-2015, 09:43 PM   #48
We haven't gotten it out at night yet, however we did run that light bar on the Miata at it's last endurance event and all the drivers loved it. The one downside to this position is the amount of cutting required to the bumper cover and bumper beam to have it sit nice.
Old 10-26-2015, 11:22 AM   #49
Here's a quick comparison between the factory lights with high beams on and high beams plus our light bars. We'll post more from this weekends race tonight.
Old 10-27-2015, 03:50 PM   #50
Well here comes the post you have all been waiting for. First the good news, The car did great, we had no engine or transmission issues at all.
Some last minute things we changed before the race was a revision of the fuel gauge mounting. Since we have a saddlebag style fuel cell we weren't able to use the stock gauges, instead we have a left and a right gauge mounted in a slapped together fiberglass pod where the tweeter would have been.
We also put in the APR brake cooling ducts. The main reason for this was concern about pad wear at higher temps.
Endurance racing is not a cheap sport, these are some of the consumables we brought down for the test day and race.
After a long drive down to VIR we were ready first thing Friday morning for the test day
This was the best the car would look for a while.
There were a few interesting cars at the test day that we would have loved to see on track for the enduro
After Pete mowed the lawn we spent some time digging out all the grass
during night practice Pete took the car off again, this time with a glancing blow against a tire wall. Some quick work with a hammer and screwdriver knocked the fender right back out.
Race day! All lined up on the false grid getting ready for the flying start.
A few hours into the race we were forced off track and again ended up in the tire wall. Of course we can't give up there so out came the hammers.
Good as new
Looking fast... if a little dinged up out on track.
[IMG]https://lh3.googleusercontent.com/DbZ9tozsfVRdywAWOWw4zpDM0u1UADDOu6X2M3En7povyKLcJN DuQ0r6HTLWLPGdW-u8taiLut_HqLSMqloJtkFl18NWZ5y720NH0xSoqLjhauT0__dv DfUmNwxHokp4a0QvV3ta***acfyU1kyDmcRyYWLJUmwJQxlB2t tpntwnIDi3ZNJnXeAOFJvubSFMQ3Zptdv6gN6W1FsbEpY5zxoH rlHxCoSe0wupx0v42dU-rAO8IRwTH5gCNLUn8009m98c0fcNEgypG_lH3kXvs1KO2AHC29 Q2i8VRfAVxLrJaGpQPy34RlGaKdY0bkhkkzRrIeyHSvec4tQCY sR4qfFELATmPlCHkce2IayIgG8WZkziOHReUnI5yIsiMCzyZ-wQvM3zp2xqw-CUOklg-hF_SQ9OC0qA6rXzYAUEl6zSf6L3KazX7g5fHPHgR6pof0lehXN XctiTXwRGcQC2YbOTfDhWAjeW5b-YRaW2huzrRlED07Ci_ExOF9dIlntOcKk4RsEVpMbc7aXdBGjcm uOp6x1q3nUSXo8dubKJ3Kq8z=w1868-h1236-no[/IMG]
And then came the final blow, in a similar situation as the first crash Matt ended up off track and into the tire wall again, this time a little bit harder.
The light bar took a beating but still works! it survived all the damage and being dragged on it's face halfway around the track.
And there she is, all banged up after a heavy day of racing.
We were all very worried about oil pressure and temp during the long stints and it seems like we had no issues at all. We haven't torn down the engine to do a very detailed inspection this is just going off on how the car ran. The engine internally was bone stock, ran with our prototype oil cooler and Motul 300v 0W20 oil, nothing crazy was done to protect the engine.
We did have one differential failure. We believe this was mostly due to not having enough mileage on the diff to break it in. Unfortunately when it failed it got hot enough to smoke the adhesive that held the bushings together. This resulted in us making some plates to replace to hold the mangled bushings back together.
While the RR Racing brake package we had on there was fantastic, our pad selection was not. Unfortunately the BP-30 pads were just too aggressive for our tire and aero setup and resulted in a few flat spotted tires. Luckily this is an easy fix.
Overall on track the car felt very solid. While not running super competitive times in qualifying we were briefly third in class before the first crash.
The Following 4 Users Say Thank You to Gear_One_Performance For This Useful Post:
BatStig (10-27-2015), DustinS (10-27-2015), Hostile_Kittens (03-16-2016), MaximeT (10-27-2015)
Old 10-27-2015, 04:07 PM   #51
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Great stuff o:
I would love to drive around VIR.
How much time/miles do you get out of a set of Hoosier slick tires ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 10-27-2015, 04:14 PM   #52
We pulled them early because we weren't quite sure what kind of life span we would get out of them, but at 4 hours the first set came off with a little bit of life left. Less camber would have extended the life of the tires and not been detrimental to grip as well.
Old 10-27-2015, 04:17 PM   #53
MaximeT
MaximeT's Avatar
Nice. Thanks.
Old 10-29-2015, 10:40 PM   #54
puma
crew chief
puma's Avatar
Drives: Race car FR-S
wow, wish we had an endurance serie around here.
puma is offline   Reply With Quote
Old 10-30-2015, 11:32 AM   #55
Come on down! Give us some good 86 competition.
Old 10-30-2015, 12:46 PM   #56
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
That poor car But thats the life of a racecar haha! Awesome stuff!
Essex endurance brake kit. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-07-2016 01:32 PM
Stock Suspension Endurance JDogg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-14-2014 02:33 PM
24 Hour Endurance Race Reliability Wes B. Engine, Exhaust, Transmission 30 09-14-2012 12:50 PM
frs endurance race frs FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-26-2012 09:53 PM
