Old 10-27-2015, 09:52 AM   #253
Here2rock
Drives: 86 GTS
Originally Posted by JamesssSmith View Post
His car is lowered using eibach sportline springs, instead of using coilovers
Sent from my Nexus 6 using Tapatalk
Ok thank you. What is the safe no risk drop with BRZ? I noticed the official springs offered by Subaru only translates to a drop of only 15mm and that does not seem a lot for $999 AUD. I am planning to get the 18" rims, do they close the gap betwee the tyre and fender? Does increasing the tyre size mean closing the gap? Sorry i am not good with mechanical stuff.
Here2rock is offline   Reply With Quote
Old 10-27-2015, 07:19 PM   #254
einrejosh
einrejosh's Avatar
Drives: 2014 Scion FR-S
Roughly an inch. Anything more would reduce shock travel and would make ride quality drop
einrejosh is offline   Reply With Quote
Old 10-28-2015, 04:04 AM   #255
Here2rock
Drives: 86 GTS
What do I need to achieve this?
Old 10-28-2015, 05:51 AM   #256
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
If you mean a drop of more than an inch without affecting suspension
stroke (travel) you'll need to look at coil overs or an air set up (both of which mean a complete swap out of suspension struts).
I recommend you review the sticky posts under this forum and the suspension one to get a feel for what is possible, what is practical, and what steps are required to achieve what you want with your car.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 10-28-2015, 09:25 AM   #257
Here2rock
Drives: 86 GTS
Too much info for a newbie, I want to keep everything close to the stock feel and suspension. I am happy to lower it by an inch, it is purely for aesthetic purposes. What quality springs are recommended without changing the factory dynamics of the car too much.
I want to get the WORK Emotion CR2P wheels in 18", will that work with 1 inch lowered? What specs should I be looking atm I notice different offset etc. in 18" range. It is all too confusing. What are the recommended tyres for that set up, without causing the speedo meter errors?
Old 10-28-2015, 09:27 PM   #258
Metabrz
001 of 012
Metabrz's Avatar
If you cant be bothered looking for information yourself you're not going to get much response on here.
I'll say again, read the sticky posts - they will tell you everything you need to make an informed decision.
Old 10-31-2015, 05:16 PM   #259
JamesssSmith
Drives: '15 BRZ
Instagram: jimmyjimmyjimmy_
JamesssSmith is offline   Reply With Quote
The Following 2 Users Say Thank You to JamesssSmith For This Useful Post:
kpamir (10-31-2015), Metabrz (11-01-2015)
Old 10-31-2015, 05:29 PM   #260
86Hiro
Thats clean, Good Job
86Hiro is offline   Reply With Quote
The Following User Says Thank You to 86Hiro For This Useful Post:
JamesssSmith (10-31-2015)
Old 10-31-2015, 07:57 PM   #261
kpamir
Drives: 2015 halo white fr-s
Originally Posted by mmmcambelsoup View Post
Finally getting some legit shots.
Man these looks so nice in the SBC!
kpamir is offline   Reply With Quote
The Following User Says Thank You to kpamir For This Useful Post:
mmmcambelsoup (11-04-2015)
Old 02-02-2016, 05:10 AM   #262
brz11b
Drives: United States
Man that looks good. What are the wheel and tire specs and what suspension are you running?
brz11b is offline   Reply With Quote
Old 02-02-2016, 05:16 AM   #263
brz11b
I just received my 18x9.5 +38 today. For those of you guys running 265/35 what coils and lca are you using? I am trying to find the right coils to not only fit this setup but also go low enough to look good and get rid of most of the wheel gap. I have been hearing great things about tien flex z's but heard they might not go low enough. I don't really want to spend $2k just on coils. Car will be 80% very spirited DD and 20% track. I looking into running like a 255/40 to help fill in the gap without having to go super low but i read that its going to throw the speedo off a lot so I am thinking about staying 265/35
Old 02-02-2016, 08:39 PM   #264
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Name:  2016-02-02 16.11.25.jpg
It depends how low you prefer it. Here's my car at max low on tein flex z and cusco lca w/ 235/40 tires to get a rough idea. Personally I think it'd look better if I had stance lcas as they lower the rear an extra 0.5" - which would bring the rear as tucked as the front. I think the 265/35 is better choice as 255/40 is going to have a monstrous sidewall and feel sluggish.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
brz11b (02-03-2016)
Old 02-03-2016, 12:32 AM   #265
brz11b
Originally Posted by tyler_win_photo View Post
Attachment 130431
That actually looks really good, I just want to go low enough to get rid of most of the wheel gap which you accomplished with the flex z's. Yeah I kept looking into it and I'm deffintly going with 265/35 not 255/40. Your maxed out on front and rears? Which stance lca's the v1 of v2?
Old 02-03-2016, 01:18 AM   #266
tyler_win_photo
Yup maxed out front and rear. Just did some quick research and v1 lowers about 20mm and v2 is supposed to lower 60mm. Having that large range of adjustment is always nice to have. On top of that you'll also get more shock travel, something that is especially valuable if you plan to go low.
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 05:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
