#253 |
Drives: 86 GTS
Ok thank you. What is the safe no risk drop with BRZ? I noticed the official springs offered by Subaru only translates to a drop of only 15mm and that does not seem a lot for $999 AUD. I am planning to get the 18" rims, do they close the gap betwee the tyre and fender? Does increasing the tyre size mean closing the gap? Sorry i am not good with mechanical stuff.
#254 | |
Drives: 2014 Scion FR-S
Roughly an inch. Anything more would reduce shock travel and would make ride quality drop Sent from my iPhone using Tapatalk
#255 |
Drives: 86 GTS
#256 |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
If you mean a drop of more than an inch without affecting suspension
stroke (travel) you'll need to look at coil overs or an air set up (both of which mean a complete swap out of suspension struts). I recommend you review the sticky posts under this forum and the suspension one to get a feel for what is possible, what is practical, and what steps are required to achieve what you want with your car.
BRZ001: Peace Love and Wheelies @metabrz on IG
#257 | |
Drives: 86 GTS
I want to get the WORK Emotion CR2P wheels in 18", will that work with 1 inch lowered? What specs should I be looking atm I notice different offset etc. in 18" range. It is all too confusing. What are the recommended tyres for that set up, without causing the speedo meter errors? |
#258 | |
001 of 012
If you cant be bothered looking for information yourself you're not going to get much response on here. I'll say again, read the sticky posts - they will tell you everything you need to make an informed decision.
#259 |
Drives: '15 BRZ
![]() Sent from my Nexus 6 using Tapatalk
Instagram: jimmyjimmyjimmy_
#260 |
Thats clean, Good Job
| The Following User Says Thank You to 86Hiro For This Useful Post: | JamesssSmith (10-31-2015) |
#261 |
Drives: 2015 halo white fr-s
| The Following User Says Thank You to kpamir For This Useful Post: | mmmcambelsoup (11-04-2015) |
#262 |
Drives: United States
#263 |
I just received my 18x9.5 +38 today. For those of you guys running 265/35 what coils and lca are you using? I am trying to find the right coils to not only fit this setup but also go low enough to look good and get rid of most of the wheel gap. I have been hearing great things about tien flex z's but heard they might not go low enough. I don't really want to spend $2k just on coils. Car will be 80% very spirited DD and 20% track. I looking into running like a 255/40 to help fill in the gap without having to go super low but i read that its going to throw the speedo off a lot so I am thinking about staying 265/35
#264 | |
Drives: 2014 Scion FRS (Asphalt)
It depends how low you prefer it. Here's my car at max low on tein flex z and cusco lca w/ 235/40 tires to get a rough idea. Personally I think it'd look better if I had stance lcas as they lower the rear an extra 0.5" - which would bring the rear as tucked as the front. I think the 265/35 is better choice as 255/40 is going to have a monstrous sidewall and feel sluggish. |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | brz11b (02-02-2016) |
#265 | |
#266 | |
| Tags |
| ft-86 speedfactory |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 06:31 AM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 11:34 AM |
| WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 | Touge Factory | Wheels and Tires | 2 | 02-05-2013 04:53 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
