Old 10-28-2015, 10:01 AM   #43
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by B-R-Z View Post
Here's pics. 2 microsd slots, 1 headphone aux jack, and 1 mini-usb. My unit is sold by Eonon but it is a Klyde on the inside--same as Joyous I believe. http://www.ft86club.com/forums/showthread.php?t=80493
Hey did you ever upgrade the bluetooth mic for this headunit? The standard mic is pretty bad for it.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 10-28-2015, 12:45 PM   #44
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
No but I'm literally ordering one today and going to do it
B-R-Z is offline   Reply With Quote
Old 10-28-2015, 02:05 PM   #45
brandonblt2
Oh nice what mic are you buying? Is it a plug and play one?
Old 10-28-2015, 07:13 PM   #46
B-R-Z
B-R-Z's Avatar
From what I've read, Parrot brand mics are good and a lot of people use them so I'm going with one of them. This fix is not plug-n-play, unfortunately. The stock mic is wired to the bluetooth board so you basically need to remove that then solder the new mic leads to the board.
Old 10-30-2015, 03:28 AM   #47
j_motion
Drives: 14 BRZ Red premium
If you want to use other music player such as Power amp , and have the face panel button FF and FW to work.
The easiest way i found is to install this with out reprogram the keymap
https://play.google.com/store/apps/d...cservice&hl=en
Yes, it say is for RK3066, but it work on my RK3188.
After you install go in and select your preference media player and your are good to go.
It will probably with with other player, i have only tried it on Poweramp.
j_motion is offline   Reply With Quote
Old 10-30-2015, 12:41 PM   #48
joop1987
Drives: 2013 FRS, Raven, Auto
Anyone reprogram the buttons? I'm using the Malask rooted ROM, installed mtc-keys-2.5.apk but I cannot find the mtc-keys.ini file to edit.
joop1987 is offline   Reply With Quote
Old 10-30-2015, 02:50 PM   #49
B-R-Z
B-R-Z's Avatar
I believe you select that in the system settings using password 126.
Old 11-08-2015, 11:49 AM   #50
Firesnake
Firesnake's Avatar
Drives: Whiteout
Has anyone upgraded to Android 5 yet?
http://www.carjoying.com/Joying-blog/12.html
Firesnake is offline   Reply With Quote
Old 12-11-2015, 09:49 AM   #51
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Took the plunge and got the Joying unit from amazon. Thanks for all the info guys!!
eurominican e u r o m i n i c a n
eurominican is offline   Reply With Quote
Old 12-11-2015, 10:41 AM   #52
eurominican
Where are you guys putting the GPS antenna and the microphone?
Sent from my SM-N920P using Tapatalk
The Following User Says Thank You to eurominican For This Useful Post:
starbot (12-15-2015)
Old 12-11-2015, 10:46 AM   #53
B-R-Z
B-R-Z's Avatar
Behind the radio to the right there is a metal surface, I put the GPS on that and reception is perfect. I haven't installed a external mic yet, that is going to be a project in the near future.
The Following User Says Thank You to B-R-Z For This Useful Post:
eurominican (12-11-2015)
Old 12-11-2015, 10:48 AM   #54
eurominican
My understanding is that the head unit comes with an external mic does it have one in the front of the unit so you don't have to use the wired one?
Old 12-11-2015, 06:11 PM   #55
B-R-Z
B-R-Z's Avatar
As far as I know, the mic used for bluetooth/phone calls is built into the unit itself and is on the front of the unit (little hole) and doesn't support an external mic out of the box. People have disconnected the original mic and soldered leads to the bluetooth circuit board to make it use an external mic.
Old 12-14-2015, 09:47 AM   #56
eurominican
This could be a stupid question but here I go: The video in the op shows the equalizer and it doesn't seem like you can set it up that the stock speakers only play mids and Highs and leave all the low to aftermarket subwoofer. Can you do that on this HU?
Also, the attached picture shows the HU I bought comes with an external mic. Is this one the same HU in the OP and that has integrated mic in the front of it? https://www.amazon.com/gp/aw/d/B00XJ2IHHE
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
