Old 10-18-2015, 11:43 AM   #29
Nofim
Drives: Blue 2015 FR-S
Originally Posted by Impureclient View Post
The extra gas cost is about $20 every 1000 miles you are going from the 28 to 22 mpg. If you wait the 7K oil change interval, that is $140 extra in gas spent.
I would drain the oil and either watch them put the correct weight oil in or do it yourself.
Could it be the gas station pump is out of calibration?
Nofim is offline   Reply With Quote
Old 10-21-2015, 09:33 PM   #30
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by radroach View Post
I had my battery disconnected about a month ago. Before my averages were about 28, now it's 26.
Also winter fuel blends typically get worse mpg's compared to summer blends. They probably started phasing in the winter blends this month.
Yup, always starts to roll-out mid to late October
Old 10-21-2015, 09:49 PM   #31
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
When the car was new i would avg 29 mpg after the break-in .. nowadays i'm getting 22-23 mpg.
its really sad .. i did read something about ignition coils going bad which lowered mpg and engine smoothness:
Originally Posted by Deep Six View Post
Failing coil replaced, car runs up to redline with no issues anymore!
Wanted to share some additional perspective on this:
Cel started coming on more frequently during daily driving, 6000 rpm would activate it.
Gas mileage had dropped to below 23 mpg average
Car would hesitate and sputter (stalled once) as you pulled to a stop and seemed sluggish in general.
Strange fuel smell in the cabin especially with the fan on high. Possibly unburned fuel??
During the couple sessions that I ran with the cel there was a profound change in the traction / stability control. I had turned it off with the 5 second switch but it was really nuts whenever I had high rpm high g load corners. Motor cut and rear brakes grabbed to the extent that I nearly lost it.
With the new coil, all of these street issues are gone and it feels like I am running the E85 tune compared to how the car was running up till now. The power difference is enough to tell the difference. Even the exhaust note standing outside the car at idle sounds different.
It would appear that when a coil gets this bad, there are multiple symptoms present even if the cel is intermittent.
http://www.ft86club.com/forums/showthread.php?t=30879
I actually get the ignition coil CEL when im shifting at the 6-7k rpms with 3rd
ive been meaning to do it but been a bit preoccupied
Old 10-27-2015, 06:06 PM   #32
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Sh*tty Mileage Since Last Service
Originally Posted by KalbiCool88 View Post
I've been losing my mpg at the exact same time I got with my girlfriend - granted I've been progressively getting fat all at the same time. Coincidence?
Don't date girl effecting vehicle dynamic! Problem solve! Or maybe you are just hammering to see her everyday... Then rest my case.
WORKS BRZ/FR-S Service - Watch For Specials! WORKS Northern California 115 01-13-2017 04:40 PM
Gas mileage? Otterbrawten Northwest 28 04-27-2016 10:07 PM
Most mileage while FI Triumphrider Forced Induction 14 09-15-2014 08:27 AM
So what mileage are you getting? carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 76 01-22-2013 04:23 PM
how do you get the gas mileage in you sig? EvoXDD Scion FR-S / Toyota 86 GT86 General Forum 6 07-15-2012 02:22 PM
