Old 10-26-2015, 11:30 PM   #1
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Light steering wheel feel after coilovers? - yes it's aligned
Anyone experience a lighter steering wheel feel after installing coilovers?
Tein flex z - lowered about 1.8" - 4 clicks back from full stiff, and fairly close to stock alignment specs, nothing fancy.
The steering wheel feels really light and floaty though. My buddy just installed the same coils in his car and he has noticed the same thing.
What gives?!
BDotG is offline   Reply With Quote
The Following User Says Thank You to BDotG For This Useful Post:
ajcarson11 (01-19-2016)
Old 10-27-2015, 12:19 AM   #2
shellslinger
Drives: Whiteout FRS
Interesting I did not experience this. Hopefully someone can chime in real soon
shellslinger is offline   Reply With Quote
Old 10-27-2015, 12:41 AM   #3
8R6
8R6's Avatar
Drives: FRS
is your car lowered evenly from front to rear? are you still at 0deg front camber? the rears will naturally camber in around -2.5ish with that amount of drop, but the front needs to have negative camber dialed in manually by the tophats on your teins.
8R6 is offline   Reply With Quote
Old 10-27-2015, 01:57 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
what is "close to stock alignment specs'?
Old 10-27-2015, 10:24 AM   #5
BDotG
BDotG's Avatar
I think it is pretty much as close to factory specs in the front and back for alignment, think if I dial the front camber in a bit negative it will take care of this?
Old 10-27-2015, 10:26 AM   #6
BDotG
BDotG's Avatar
When they did the alignment they just brought it as close to whatever the factory specs were for alignment. So removing as much camber, toe etc whatever that was excess from the drop/install.
Old 10-27-2015, 11:38 AM   #7
8R6
8R6's Avatar
Drives: FRS
but unless you have adjustable rear lca's, you cant just add/remove camber in the rear. the rear naturally gains more negative camber the lower you go.
im just wondering if it might be a setup of 0 camber up front, and -2.x camber in the rear. and maybe thats why the steering feels all light? i dunno though, just a guess. im no suspension expert :o
Old 10-27-2015, 11:46 AM   #8
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
"Factory alignment specs" are suuuuuuuper loose. When we bought our car, first thing we did was put it on a laser alignment machine. (Not trying to brag, just pointing out it's accurate and reliable). The front left camber was +0.24°, and the front right camber was -0.27°. Yep, one was in, and one was out. And technically, that was within "factory spec."
I'd get it checked out by a real race shop that will do a good alignment. 99% of drivers don't really care if the alignment isn't perfect, so most NTB-style alignment shops don't have techs that do tight alignment specs. Usually.
GSpeed is offline   Reply With Quote
The Following 4 Users Say Thank You to GSpeed For This Useful Post:
BDotG (10-27-2015), CSG Mike (10-27-2015), Elkton86er (04-07-2016), wparsons (09-07-2016)
Old 10-27-2015, 12:03 PM   #9
BDotG
BDotG's Avatar
I have adjustable rear LCAs. I cant find my alignment sheet but im pretty sure im at like -0.8 in the rear or something like that.
Old 10-27-2015, 05:08 PM   #10
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
subscribed since i have same coilover but yet to install
Old 01-19-2016, 09:53 PM   #11
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Same 'light steering' feeling. Running -2.6 camber in front and -2.5 camber in rear with Flex Z.
Sorry to revive old thread... but the Flex Z is relatively new, so still relevant!
ajcarson11 is offline   Reply With Quote
Old 01-20-2016, 12:10 AM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What are the caster numbers?
ineedyourdiddly
Old 01-20-2016, 12:26 AM   #13
twag4
Drives: frs
I had that problem after lowering and adding 17x9 +35 wheels. Fixed it with the Whiteline anti-dive/caster correction kit #kca 434. Worked great returning positive steering feel and quicker and better return to center after a turn.
twag4 is offline   Reply With Quote
Old 01-20-2016, 12:52 AM   #14
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Did you check the tire pressure? Did you use a digital tire gauge? I just couldn't resist a digital tire gauge joke.
Tires do make a difference to the steering feel on this car for me: BF Goodrich Rival 225/45R17 - weighty feel; Yokohama Advan V105 225/45R17 - good, mostly neutral; Bridgestone Blizzak WS80 205/55R16 - light and too quick, doesn't easily track straight. It seems that many things will affect the steering feel for this car.
Subscribed, as I am interested in the same suspension options as listed hear and would like to see some good recommendations that have actually been tried and work.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
coilovers, light, steering
ABS and Slip Light on after steering wheel re-install Yamajee Issues | Warranty | Recalls / TSB 11 03-29-2017 12:56 PM
Best Steering Wheel Column for Feel - Rake and Reach brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-21-2015 09:24 PM
OEM Steering Wheel Reinstall...Light Still On? dizzario Electronics | Audio | NAV | Infotainment 13 06-22-2014 09:23 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
