Old 08-10-2015, 09:38 PM   #197
86Tony
Drives: 2015 AOZORA EDITION
I got it to shoot flames today it was sick
Sent from my SM-N910W8 using Tapatalk
86Tony is offline   Reply With Quote
Old 08-11-2015, 03:39 PM   #198
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
what are your mods?
Old 08-11-2015, 05:18 PM   #199
86Tony
Tomei uel catless front pipe greddy exhaust and oft
Old 08-12-2015, 02:56 AM   #200
86Tony
[ame="https://www.youtube.com/watch?v=JGn49Z6Onhw"]Brz shoot flames - YouTube[/ame]
The Following 2 Users Say Thank You to 86Tony For This Useful Post:
D_Thissen (10-27-2015), JoeHK (08-21-2015)
Old 10-26-2015, 05:25 AM   #201
steve99
Drives: FT86
Originally Posted by bee_are_zee View Post
The next tuning adventure should be to find out if we can get ghost cams at idle...
AFAIK cam vvt is not active at idle, i believe even if you put non zero values in vvt tables ecu will just use zero at idle. Limited oil pressure to drive vvt acuators may be part of reason.
you will have to do it the old fashoned way and grind the lobes
Old 01-02-2016, 09:47 AM   #202
KslayFRZ
KslayFRZ's Avatar
Drives: 2013 Frs asphalt
Originally Posted by KslayFRZ View Post
Back at it once I read through the updates
Sent from my SM-G900P using Tapatalk
KslayFRZ is offline   Reply With Quote
Old 01-02-2016, 01:16 PM   #203
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I feel like at minimum with this mod you should have a catless front pipe....
Old 01-02-2016, 02:34 PM   #204
FRSBRZGT86FAN
Originally Posted by Snyperiflex View Post
this is the ONLY table that I modified
What's the value in the 0.20 table? it's too pixelated for me to make out?
Old 01-02-2016, 03:24 PM   #205
Cole
Not a troll
Cole's Avatar
It's like -5.04. I tried inputting -5 this morning and it ended up switching to -5.04.
FWIW, before I had just the first like done, and it still crackled and popped.
Cole is offline   Reply With Quote
Old 01-02-2016, 04:26 PM   #206
FRSBRZGT86FAN
Thanks! I have the one in the original post saved as snapcracklepop, and the one using the adjusted timing that @Snyperiflex used saved as snapcracklepop2 in my oft
Any OBD2 trouble codes need to be disabled for this as well?
Old 01-03-2016, 12:38 AM   #207
Snyperiflex
Snyperiflex's Avatar
Drives: Scion FR-S Release Series 1.0
I believe mine is -6.09, I just referenced one of the screenshots from an earlier post by someone else for that column. My values weren't any different from what was posted before
Snyperiflex is offline   Reply With Quote
Old 01-04-2016, 03:43 PM   #208
FRSBRZGT86FAN
So I just did a few runs with it for about an hour or two through some tunnels and back roads and such and here's my review my only exhaust mod is the berk dual tip muffler delete. It is very easy to control and it sounds quite good, it only really happens on the auto in manual mode when you decel/downshift and lightly tap or hold the gas pedal as the rpms come down. It also took around 30 minutes for it to really kick in and be quite loud and for me to easily control it by modulating the throttle. It's also louder under load. I assume that's due to the computer learning the new ROM as well as the fact the entire exhaust system was probably at a high temp at that point. As for sound it's still quite loud with just a muffler delete, it's novelty sort of wears off after a while because you do notice a fuel mileage drop and also occasional smell gas , in fact I had a full tank before my escapade of running through tunnels and such and it used between 1/4 to 1/2 a tank maybe a bit less. Also I still honestly believe it would be best at minimum to have a catless front pipe and a well packed muffler (or none at all in my case ) if you do this. I hate to think what's happening to the cats getting coated with fuel whenever this tune is run. Also if it does shoot flames it sure as hell will probably coat your bumper with soot or something at high speeds.
Bottom line it's easy to do, sounds good, and is good practice with romraider, but I'd be weary of what it would do long term to the car.
Old 01-06-2016, 10:29 AM   #209
rawafoo
Drives: Orange GT86
i love this tune, been using is for around 2 months now, N1 Catback Tomei Uel and catless front pipe and overpipe, The pops and crackles are LOUD sometimes gunshot sounds and backfires usualy, however today i heard a knock and immedietly pluged in my OFT and with a bit of throttle the knock correction which is always 0 became 1.3 for a second, so i might remove the tune for now, i just changed the timeing base exactly like the OP without any fuel enrichment or anything else
What do you guys think how bad can this be?
Forget the damage to the exhaust, im just saying how bad can this be to the engine itself?
Thanks guys
rawafoo is offline   Reply With Quote
Old 01-07-2016, 10:57 AM   #210
FRSBRZGT86FAN
Thanks guys
That's a good question, no one has a consensus as to the long term effects of this tune itself either. I personally put my car back to my original edited stg 1 93 octane tune, the novelty of popping and backfires has worn off completely
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
