Old 06-01-2012, 09:01 AM   #71
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Yes, very much something we are planning on doing! The process is unfortunately pretty slow, so I can't even begin to estimate a time frame. Not this year at least but we are going to be pushing for it with Bilstein.
- Andrew
That is good news! Keep us updated if/when this materializes
Sccabrz192 is offline   Reply With Quote
Old 06-04-2012, 11:12 AM   #72
MTeator
First 86
Originally Posted by jdrxb9 View Post
Well, I won't be sourcing any alternate bolts, genuine OEM are in hand:
(sorry for the cell phone pic)
Two day turnaround was surprisingly quick!
Also, the car is at the dealership , but no pics of that yet (probably tomorrow).
With luck my bolts will be here tomorrow. Have wheels in hand.... waiting on the tires too, but those are tomorrow or Wed.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 06-05-2012, 08:38 PM   #73
simpleisbest
Senior Citizen
Drives: Scion FR-S
Has anyone with the new bolts figured out the maximum range of camber adjustment?
Time to start thinking about possible alignment configurations...
simpleisbest is offline   Reply With Quote
Old 06-05-2012, 09:26 PM   #74
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
I've not seen any experiences with the OEM bolts posted. I'm scheduled for the alignment rack Friday and will post up my results afterward unless someone beats me to it.
jdrxb9 is offline   Reply With Quote
Old 06-08-2012, 12:08 PM   #75
jdrxb9
jdrxb9's Avatar
Well, had the BRZ on the alignment rack this morning and installed the OEM camber adjustment bolts.
Stock upper attachment bolt right, OEM adjustment bolt left:
And here are the results:
Overall, I'm pleasantly surprised with the front. The stock alignment was at least slightly negative already. The bolts gave about a whole degree of additional camber. FYI, a quick check with both stock bolts loosened and camber maxed out showed -0.4 deg., so nut much there.
In the back, despite the FSM saying:
Inspect the toe-in and camber. If the values are not within the specified ranges, adjust the installation bolt holding the rear suspension member to the vehicle body, or the bolt holding the upper control arm and rear suspension arm so that the values fall within the specified ranges.
No adjustment other than the cammed bolt at the inboard end of the toe control link was evident to myself or two techs. So, rather than just start loosening every bolt, I decided to leave it as is. We'll see how the balance feels and go from there.
I've only driven it a couple miles, so I can't yet give any impressions on the driving feel with these settings.
Cheers!
Edit: All measurements are without driver weight.
The Following 3 Users Say Thank You to jdrxb9 For This Useful Post:
BRZranger (09-23-2012), Getagrip (06-18-2012), phm14 (06-13-2012)
Old 06-08-2012, 01:55 PM   #76
MTeator
First 86
Cool thanks. My bolts went on backorder :/
Old 06-08-2012, 06:30 PM   #77
simpleisbest
Senior Citizen
Drives: Scion FR-S
Cheers!
Thank you soo much! Great info! I was expecting much less available neg camber. Still not great, but better than I expected.
Old 06-09-2012, 07:50 PM   #78
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Ran in Cstock today. This car is no where near being c-stock maybe d stock. 350zs doing 56s today on rcomps we were doing 61s. With rs3s even with rcomps I don't see us catching up.
feldy is offline   Reply With Quote
Old 06-09-2012, 09:52 PM   #79
des
des's Avatar
Originally Posted by feldy View Post
Ran in Cstock today. This car is no wear nearing being c-stock maybe d stock. 350zs doing 56s today on rcomps we were doing 61s. With rs3s Even with rcomps I don't see us catching up.
Very different experience here in SF today -- a second off the C-Stock winner on Hoosiers and on the same tenth as an MSR-package Miata on Dunlops, both driven by talented veterans.
The FRS -- even on the oversize Dunlops I chose -- slaloms as well as or better than any stock car I've ever driven, including RX-8s, S2000s and Miatas.
Wheel width will be a problem but otherwise car was right in there. Hope you keep plugging away.
des is offline   Reply With Quote
Old 06-09-2012, 10:32 PM   #80
feldy
feldy's Avatar
How low on fuel did you run it? I was having other problems as well today. Going from a FWD car in autocross to this. I spun it drove it slow ect. But my co-driver is a quick driver and he was still 4-5 seconds slower then the 350z today on rcomps. I did take the auto thinking it would be nice not to miss shift in turnarounds ect. It was fighting going back into first when we wanted it to. Couldnt launch the car even with the nannies off. Had torque converter stall at 2k rpms. I spun it in the finish on my 2nd run. I had never spun in the finish before so I got a tad discourged. I was 2 seconds behind my co-driver who has a stx prepped RX8. And he was the one 4 seconds behind the z.
Old 06-10-2012, 01:18 PM   #81
Vanguard
Drives: Ford F-150 (not for long)
So it appears you have an automatic. I don't care what others might say in regards to the auto being really good compared to the manual...it will NEVER be as quick in an autocross setting.
I started autocross in an AT Saturn Sky Redline and thought I was quick. Once I finally drove a manual, I realized that you will be at least a second faster on a 40second course with a stick. Torque converters always asking you "are you sure you want to accelerate now?" coupled with being in the wrong gear will add up to being 5 seconds slower than a 350z on rcomps.
Des has it right...keep plugging away and you'll close that gap quick.
Vanguard is offline   Reply With Quote
Old 06-10-2012, 01:42 PM   #82
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
actually in sport mode the ecu forces the car in the smallest gear possible when you are pressing it downshifting into corners as you brake, and throttle response is instant, the auto isnt something you would normally find in a 25k car period, its got the same sport tech as the ISF and LFA when it comes to sport mode
you never know, try with better tires, maybe its not the tires for a technical course you need, i noticed in the frs needs a slightly bigger rear sway bar for low speed stuff
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 06-10-2012, 01:49 PM   #83
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Subscribing to follow this thread. I am trying to get into a BRZ now and I plan on running a lot of local events in stock. We have multiple autocross groups and one doesn't allow rcomps in stock so I will be doing R-S3s (also so I can do roadcourse days as rcompstires would likely overheat quickly in 20 minute sessions at Daytona and Sebring).
As for the camber bolts (Im new to a lot of this), what do I call and ask for? Will Toyota know what I mean if I just call and ask for camber bolts? Or does someone have the part number I can call and ask for?
Thanks guys!
Kido1986 is offline   Reply With Quote
Old 06-10-2012, 02:10 PM   #84
des
des's Avatar
If you're still on stock tires, don't make any judgments. On real tires, the car isn't tail-happy, and you can get on the gas much earlier.
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FORMULA D Round 1 Long Beach 2012 Discussion Thread Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 0 04-08-2012 02:43 AM
GT5 Stock GT86 Competition - March 2012 Deslock Off-Topic Lounge [WARNING: NO POLITICS] 34 04-01-2012 07:39 AM
2012 Mercedes A-Class Revealed ZetaVI Other Vehicles & General Automotive Discussions 12 03-06-2012 02:15 PM
GT5 Stock GT86 Competition - February 2012 Deslock Scion FR-S / Toyota 86 GT86 General Forum 100 03-01-2012 07:14 AM
