#16 |
Drives: Whiteout FR-S
There is a whole number of threads here about this issue along with the squeaky clutch which I think is related. I'm at 64k and I have been hearing the squeaky clutch so hopefully I will not have the same issue but seems like a matter of time. Toyota needs to recall this shit already.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#17 |
Drives: 2013 Scion FRS
I would trailer it home and install an aftermarket clutch, light weight flywheel and the rest.
Probably cost a ton less too. But for the other parts... that I don`t know how much work and difficult it is. |
| The Following User Says Thank You to kevman_101 For This Useful Post: | why? (10-31-2015) |
#18 |
Drives: 2014 Subaru BRZ Limited 6smt
^ +1
#19 |
Waited 5 years for this
Drives: '18 MX-5 Club
Was there any sign of a problem before it happened? Any weird noise? Was everything normal without any weird noise and it broke all of a sudden?
#20 | |
Drives: 2005 Toyota Camry
http://www.subaru.com/owners/resourc...ity/index.html As is the case with most of these things, you need to read the fine print before you buy. -alex |
#21 |
Drives: Scion FR-S, Ultramarine
Yeah definitely. Its a little sooner than I expected, but its to be expected nonetheless.
#22 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
I just crossed 80k on my 13 and no issues with mine either. I've been contemplating changing the bearing, clutch, etc at 100k before my luck runs out.
| The Following User Says Thank You to Scenic Driver For This Useful Post: | Tcoat (10-23-2015) |
#23 |
That is my loose plan at this point. If I start to hear weird things I may move that up but so far so good.
#24 |
Drives: Argento FR-S 2013
Ok since I'm in the middle of doing a clutch/flywheel/bearing replacement I thought I would chime in. Currently just below 100k miles. Was at the track and throw out bearing decided to melt so I ordered all new parts. Forgot to order new throw out bearing clips since mine melted so waiting on that little part.
| The Following User Says Thank You to yaser.salameh For This Useful Post: | strat61caster (10-23-2015) |
#25 |
Drives: asphalt fr-s
I wonder if the aftermarket high performance last longer than oem on a stock motor
#26 |
63,000 and throwout bearing ruined everything
Forgot to mention I have the sprinted intercooled supercharger kit for the last 25k ish miles
#27 | |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
So many modders have more cents than sense!
#28 | |
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 02:17 AM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 08:08 PM |
| Release Bearing or Pilot Bearing | Cal3000 | Engine, Exhaust, Transmission | 11 | 01-27-2015 10:39 PM |
| Friday Ruined... | mbh1101 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 07-20-2013 01:58 PM |
| How do you know that your day is already ruined? | IloveBaldEagles | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 12-03-2012 09:58 AM |
