Drives: asphalt fr-s
63,000 and throwout bearing ruined everything
I have the extended 5 year 100,000 warranty and they wont cover any of it. the throwout bearing failed and destroyed flywheel, clutch, pressure plate, fork and pilot sleeve . its bull shit. I drive a 1000 miles a week and worried since I have one of the higher mileage cars on here we will see issues coming up. so I have to pay $2530.14 to fix...oh but they will pay for a #$@$% rental car!
| The Following User Says Thank You to riironman For This Useful Post: | strat61caster (10-23-2015) |
#2 | |
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | hmong337 (10-23-2015), JEDI (10-31-2015), raven1231 (10-23-2015), SkAsphalt (11-18-2015), strat61caster (10-23-2015) |
#3 | |
#4 | |
Is yours a 13? I have already gone past your mileage with my 14 and have not had an issue yet but it is such a common problem on here I think it is just a matter of time (unless they changed something for the14 MY).
#5 |
yes a 13. you have over 63,000?
#6 |
Not by much but a little. I work in 3 different cities then where I live and spend 14 hours a week just driving from plant to plant.
#7 |
so far only thing that has failed me is battery, tail lights full of water and the usual oil leak on valve cover. and now this.
| The Following User Says Thank You to riironman For This Useful Post: | Tcoat (10-23-2015) |
#8 |
All the reason to upgrade! Sorry to hear it though man.
I never buy extended warranties because the things that actually wear down aren't covered, so, unless you haven something very abnormal happen you're paying out of pocket anyway. Guess that's how they make money though, just the same as any insurance.
| The Following User Says Thank You to raven1231 For This Useful Post: | Tcoat (10-23-2015) |
#9 |
All I have had was a squeaky window and they fixed that right up.
| The Following User Says Thank You to Tcoat For This Useful Post: | BloodyshoedFR-S (07-06-2018) |
#10 | |
| The Following 2 Users Say Thank You to riironman For This Useful Post: | raven1231 (10-23-2015), strat61caster (10-23-2015) |
#11 | |
[quote=riironman;2429602]
#12 | |
Drives: Scion FR-S, Ultramarine
I remember debating if I should pay for a B.S. diagnostic when my ignition coil failed, but I later found out that it wasnt covered under warranty, so im glad I didnt. I kept on asking them if it would be covered if it turned out to be a bad ignition coil, and they never gave me an answer. anyways, good luck man! I hope everything turns out for the better Im at 70,300 miles in my AT, and so far I have only had a failed ignition coil which I replaced myself, but my battery is going too. Ill leave my lights on for a couple minutes while pumping gas, and my car wont start lol |
#13 |
DANG! .........that sucks .........
![]() May I ask when your car was built ... ?? Do you have any power (SC/TC) mods ...?? Do you track the car ... ?? humfrz |
#14 |
Drives: 2015 CWP BRZ Limited
Batteries going bad sounds about right. With as many electronics as cars have these days, we can probably expect this to be the new normal - batteries needing replacement after only a few years.
| The Following User Says Thank You to jawn For This Useful Post: | FRSBRZGT86FAN (11-14-2015) |
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 02:17 AM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 08:08 PM |
| Release Bearing or Pilot Bearing | Cal3000 | Engine, Exhaust, Transmission | 11 | 01-27-2015 10:39 PM |
| Friday Ruined... | mbh1101 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 07-20-2013 01:58 PM |
| How do you know that your day is already ruined? | IloveBaldEagles | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 12-03-2012 09:58 AM |
