Old 10-23-2015, 02:38 PM   #15
riironman
riironman's Avatar
Drives: asphalt fr-s
DANG! .........that sucks .........
May I ask when your car was built ... ??
Do you have any power (SC/TC) mods ...??
Do you track the car ... ??
no extra power mods . just cosmetics. I bought in December of 2012. I drive about 1000 miles a week.
riironman is offline   Reply With Quote
The Following User Says Thank You to riironman For This Useful Post:
humfrz (10-23-2015)
Old 10-23-2015, 02:57 PM   #16
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
There is a whole number of threads here about this issue along with the squeaky clutch which I think is related. I'm at 64k and I have been hearing the squeaky clutch so hopefully I will not have the same issue but seems like a matter of time. Toyota needs to recall this shit already.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 10-23-2015, 03:15 PM   #17
kevman_101
Drives: 2013 Scion FRS
I would trailer it home and install an aftermarket clutch, light weight flywheel and the rest.
Probably cost a ton less too. But for the other parts... that I don`t know how much work and difficult it is.
kevman_101 is offline   Reply With Quote
The Following User Says Thank You to kevman_101 For This Useful Post:
why? (10-31-2015)
Old 10-23-2015, 03:33 PM   #18
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
^ +1
GotBRZ1691 is offline   Reply With Quote
Old 10-23-2015, 03:42 PM   #19
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Was there any sign of a problem before it happened? Any weird noise? Was everything normal without any weird noise and it broke all of a sudden?
Old 10-23-2015, 04:08 PM   #20
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by riironman View Post
I have the extended 5 year 100,000 warranty and they wont cover any of it.
Not saying Subaru will be better, but their extended warranty covers most wear & tear items.
http://www.subaru.com/owners/resourc...ity/index.html
As is the case with most of these things, you need to read the fine print before you buy.
-alex
Old 10-23-2015, 04:09 PM   #21
Estey
Drives: Scion FR-S, Ultramarine
Batteries going bad sounds about right. With as many electronics as cars have these days, we can probably expect this to be the new normal - batteries needing replacement after only a few years.
Yeah definitely. Its a little sooner than I expected, but its to be expected nonetheless.
Estey is offline   Reply With Quote
Old 10-23-2015, 04:32 PM   #22
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I have already gone past your mileage with my 14 and have not had an issue yet but it is such a common problem on here I think it is just a matter of time (unless they changed something for the14 MY).
I just crossed 80k on my 13 and no issues with mine either. I've been contemplating changing the bearing, clutch, etc at 100k before my luck runs out.
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
Tcoat (10-23-2015)
Old 10-23-2015, 04:53 PM   #23
That is my loose plan at this point. If I start to hear weird things I may move that up but so far so good.
Old 10-23-2015, 06:50 PM   #24
yaser.salameh
Drives: Argento FR-S 2013
Ok since I'm in the middle of doing a clutch/flywheel/bearing replacement I thought I would chime in. Currently just below 100k miles. Was at the track and throw out bearing decided to melt so I ordered all new parts. Forgot to order new throw out bearing clips since mine melted so waiting on that little part. Name:  ImageUploadedByTapatalk1445640508.853645.jpg
Size:  245.1 KBName:  ImageUploadedByTapatalk1445640524.053936.jpg
Size:  312.4 KBName:  ImageUploadedByTapatalk1445640531.720801.jpg
Size:  311.0 KBName:  ImageUploadedByTapatalk1445640546.638903.jpg
Size:  353.1 KBName:  ImageUploadedByTapatalk1445640556.887847.jpg
Size:  258.5 KBName:  ImageUploadedByTapatalk1445640565.689531.jpg
Size:  294.8 KBName:  ImageUploadedByTapatalk1445640582.940930.jpg
yaser.salameh is offline   Reply With Quote
The Following User Says Thank You to yaser.salameh For This Useful Post:
strat61caster (10-23-2015)
Old 10-23-2015, 07:06 PM   #25
riironman
riironman's Avatar
I wonder if the aftermarket high performance last longer than oem on a stock motor
Old 10-23-2015, 07:17 PM   #26
yaser.salameh
63,000 and throwout bearing ruined everything
Forgot to mention I have the sprinted intercooled supercharger kit for the last 25k ish miles
Old 10-23-2015, 07:40 PM   #27
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
I have the extended 5 year 100,000 warranty and they wont cover any of it. the throwout bearing failed and destroyed flywheel, clutch, pressure plate, fork and pilot sleeve . its bull shit. I drive a 1000 miles a week and worried since I have one of the higher mileage cars on here we will see issues coming up. so I have to pay $2530.14 to fix...oh but they will pay for a #$@$% rental car!
I am just curious. When you stop at a traffic light or stop sign, do you hold the clutch in the whole time you are waiting to go or do you shift to neutral and release the clutch then re-engage when it is time to go? I am not criticizing either method. I am just curious what method you used during the 63K miles you drove.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 10-23-2015, 07:45 PM   #28
riironman
riironman's Avatar
Originally Posted by yaser.salameh View Post
Ok since I'm in the middle of doing a clutch/flywheel/bearing replacement I thought I would chime in. Currently just below 100k miles. Was at the track and throw out bearing decided to melt so I ordered all new parts. Forgot to order new throw out bearing clips since mine melted so waiting on that little part. Attachment 123407Attachment 123408Attachment 123409Attachment 123410Attachment 123411Attachment 123412Attachment 123413
So i guess its common
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 02:17 AM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
Friday Ruined... mbh1101 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 07-20-2013 01:58 PM
How do you know that your day is already ruined? IloveBaldEagles Scion FR-S / Toyota 86 GT86 General Forum 4 12-03-2012 09:58 AM
