Old 10-23-2015, 09:36 AM   #1
paulca
Drives: Toyota GT86 Coupe Red (UK)
Unstable idle when A/C cuts out
My car has developed an unstable idle when the aircon cuts out. Here are the symptoms.
AirCon OFF: 650rpm stable as a rock.
AirCon ON:
- Compressor pump off: 650rpm stable as a rock
- Compressor kicks in: 800rpm stable
- Compressor knocks off: idle drops to 500rpm or below, engine labours, shakes, then stablizes again to 650rpm. Sometimes the load sensor panics and revs the car to 1000rpm in response to the idle drop, but usually it doesn't. Has caused me to stall the car twice now and it's annoying.
If I rev the car with the Air Con off to 800rpm and the release the pedal it settles down normally to 650rpm. It is only when the A/C pump stops that the idle falls too low.
Any ideas? It's really, really annoying as without the aircon the windows steam up pretty quickly here at this time of year, but with it on, the pump cycles on for 2 or 3 seconds 4 or 5 times a minute. I have taken to turning it OFF while waiting in traffic, but that is not a solution.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 10-23-2015, 10:12 AM   #2
AirCon ON:
This is not unusual for a small displacement engine since the compressor does take a fair bit of power to kick in. The surprising part is that you just noticed it. I have had several cars that did this and it is never an issue and there is nothing that can be done about it.
Old 10-23-2015, 10:23 AM   #3
paulca
Yea, but it's not when the compressor kicks IN, the load sensor covers that nicely and the engine revs up to 800rpm. It is when it cut out that the revs fall too far and the engine shakes.
It used to do it a little bit on the odd occasion in the dead of winter when the window heater, lights, fan and everything else was on.
Recently its doing it all the time now.
The Following User Says Thank You to paulca For This Useful Post:
Tcoat (10-23-2015)
Old 10-23-2015, 10:39 AM   #4
steve99
Drives: FT86
AirCon ON:
What is your rom calid hopefully its A01G or A02G if not see if dealer will update ecu rom if your on older 700G or 900G rom (assuming manual transmission)
if you have access to a tuning device it can be fixed. better than stock rom update by increasing base idle to 700 rpm and adjusting the port/direct injection tables to run full direct injection at idle instead of a port/direct split.
Old 10-23-2015, 11:33 AM   #5
Ahhh I didn't catch that. Reading impaired this morning I guess.
Old 10-23-2015, 02:11 PM   #6
thunderlights
Sometimes when the ac is on and im idling the revs keep bouncing between 650 and 800 over and over and over again. Same issue as you?
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
Old 10-23-2015, 02:17 PM   #7
Teseo
Drives: frs
I asked about this in my local dealer and they said to me: " we dont have such tools for fix it"
Old 10-24-2015, 03:38 AM   #8
paulca
That part is normal. The A/C compressor requires quite a lot of electrical power, so the engine load sensor adds a tiny notch of throttle to pick the revs up, otherwise the drain on the alternator would stall the engine, potentially.
My issue is when the A/C cuts out and the revs return to 650rpm they dip much lower causing the engine to vibrate.
On my way home last night it had a tffy fit at a set of lights. Revs dropped to below 500, then the car lurched and the revs jumped to 1000, then fell back to 500, then jumped to 1000 again, did it three or four times in a row before settling again, just before the A/C kicked in again and it all started over. Thankfully it's not normally that bad.
Old 10-24-2015, 03:41 AM   #9
paulca
If it was a firmware issue it would have done it from the start, wouldn't it? I recall it doing it once or twice before when I had a lot of electrical equipment on; A/C, window heaters, lights, wipers, HiFi, but it started doing this consistently since I tracked the car.
One easy fix might be to have the ECU reset. Maybe it has learned some bad habits on the track.
The other thing I'm considering, as the symptoms are very close, is clutch drag... but then again, it does this when it's in neutral, so that's out.
Old 10-24-2015, 08:22 AM   #10
steve99
Drives: FT86
Yes you would assume if it was early firmware problem would be more consistent, but maybe it only show up under certian circumstances. like ambient temperature conditions , certain fuels, A/C and heavy electrical loads lights on ect.
I dont think ECU reset will help as ECU continually learns .
Old 10-24-2015, 08:51 AM   #11
LS1M
Drives: 2015 BRZ
Did you try cleaning your MAF sensor?
LS1M is offline   Reply With Quote
Old 10-24-2015, 10:08 AM   #12
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Happened to me with the car entirely stock and still does it after turbo. Just crack the windows and drive fast with the AC off.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-24-2015, 07:39 PM   #13
paulca
I like your style. Doesn't work in rush hour traffic unfortunately. Crack windows = cold. Closed windows = steam up. If the A/C is off.
It was going so well too, I'd figured out if you leave the climate control in AUTO mode with A/C on, it takes care of everything really well.
Now I have to turn the A/C off in slow traffic, if I want peace without laboring, and remember to turn it back on, before it steams up again. Not very auto really. But workable.
Old 10-24-2015, 08:20 PM   #14
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I was having this issue a while back before I had the dealer service a cam chain cover seal leak. I've notive the acc belt sometimes will slip on the compressor pulley while idling with AC on. After getting my car back from having the leak fixed it has stopped doing that completely. I'm assuming the belt tension was tighter after having been serviced than before.
Checking and tightening the belt tensioner may help.
Intent > Content
New front sway, a little unstable on left turns loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-20-2015 07:38 PM
Help, Audio cuts off with sub amp install. 2014 FR-S Waukeen Electronics | Audio | NAV | Infotainment 8 07-02-2014 04:29 PM
Unstable feeling Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2013 11:06 AM
AC cuts out at high revs. Cool feature? Superhatch BRZ First-Gen (2012+) — General Topics 9 06-28-2012 02:13 PM
Possible Final production cuts. Syldrin Scion FR-S / Toyota 86 GT86 General Forum 46 11-23-2011 09:02 PM
