Old 10-14-2015, 02:38 AM   #15
kbye
kbye's Avatar
Drives: 2014 FR-S
You are going about this the wrong way. If you are concerned about ride height you should swap your springs, not your wheels.
From 215/45/17 to 235/40/18 you are gaining a 10mm or 0.4in increase in height, but spending 4-5x more than simply swapping to an Eibach pro-kit and gaining back the same amount, but with better shock travel. Not to mention 18 inch rims are heavy.
kbye is offline   Reply With Quote
The Following User Says Thank You to kbye For This Useful Post:
Calum (10-14-2015)
Old 10-14-2015, 09:03 AM   #16
Cole
Not a troll
Cole's Avatar
I don't get why you want to lower the car, then complain about the car scraping, then want to get taller tires to compensate for the lowering. You can't have your cake and eat it too.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Tcoat (10-14-2015)
Old 10-14-2015, 09:49 AM   #17
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Lowering the car reduces the wheel gap as well as the ride height. I assume OP wants to know if larger diameter tires will allow raising the ride height back up a bit, without increasing wheel gap.
The answer is yes, at the expense of increased weight, less tire to body clearance, and decreasing acceleration.
murdoc is offline   Reply With Quote
Old 10-14-2015, 10:26 AM   #18
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Mikeez View Post
I am not sure if this is a wheel/tire related topic... Although, my main concern is lowering springs.
I bought Lowering Springs from Tein. I got the Tein-S. It drops the car 1,3" and I am afraid of scrapping lol...
I am wondering if installing 18" wheels raises the car .5 inch? Or in other words, does it raise the car up a little.
I don't want to scrape (DO NOT suggest me not to install lowering springs)
Thanks
You do not want to 'raise' your car with bigger wheels. Increasing overall diameter of your wheels + tires .5" will throw off your speedo, and probably your ABS system.
I'm not suggesting you not install lowering springs, but if you're worried about scraping you probably bought the *wrong* springs. There are lowering springs out there that lower your less - RCE might be a good candidate because I think they lower around .7". Then you have the others, swift, eibach pro, etc that lower around 1". Honestly I currently have Eibach Sportlines which lower about 1.2-1.3" and I have no problems with scraping (but ymmv).
p.s. - you're an engineering student?!
Old 10-14-2015, 07:19 PM   #19
Mikeez
Engineering Student
Drives: Scion FR-S 2015
You my friend are smart. I do want to reduce the ugly wheel gap. I do know the overall of the car will be lowered and there will be around 3.5" clearance on the ground.
I know that 18" wheel will increase the ride height slightly, not noticeable and you confirmed it. Thank you.
murdoc understood my concerns, .. All the information you've given I know. Speed will change around 4-5 km/h which is not a problem. ABS does not get affect... And I can always pump the brakes.
1" and 1.3" does not make a difference in my eyes =p! Also the springs compression ratio seems to be stiff enough so if I go slow.. I am good. I think!
I think of changing my springs....but I just bought the tein s.. so I'm not willing to just buy new one
Yes, in Software not Mechanical ... Although I do a very good job in mechanical.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 10-14-2015, 09:05 PM   #20
Cole
Not a troll
Cole's Avatar
Ah, so you can gain millimetres of clearance. Makes tons of sense to spend 3-600 on springs to get rid of whee gap, then spend 1-2k on tires to raise it by millimetres. Why not have just got springs that lower less?
Old 10-14-2015, 10:26 PM   #21
murdoc
murdoc's Avatar
Because OP is a genius and already bought the springs before making this thread.
Idk what to tell you, the answers are all obvious if you do research, some people just forget that that usually comes before buying.
Old 10-15-2015, 02:42 AM   #22
Mikeez
Engineering Student
The car is raised few millimeters that's good enough for me hahaha!
Genius me ! I will sell my springs and buy a less aggressive drop.
Old 10-15-2015, 09:24 AM   #23
adamg
Drives: brz
aggressive drop
adamg is offline   Reply With Quote
Old 10-15-2015, 09:46 AM   #24
murdoc
murdoc's Avatar
Good man.
Old 10-22-2015, 11:23 PM   #25
Mikeez
Engineering Student
Okay soooooo, I decided to go yolo.... LOL! Yes I do change my opinions. I will install the springs. However, will I rub against my fender with the Tein-S Springs?? I have bumpy roads... and I am setting up 18x9.0 wheels!?
Old 10-23-2015, 02:30 PM   #26
adamg
Drives: brz
bruh what's your offset
Old 10-23-2015, 03:38 PM   #27
Mikeez
Engineering Student
Et33
Old 10-23-2015, 04:21 PM   #28
Estey
Drives: Scion FR-S, Ultramarine
Et33
youre good in relation to the springs, but I would worry about rubbing against the fender, although you shouldnt with that drop.
Estey is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 17x9.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-31-2019 04:22 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 04:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x7.5 +47 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-31-2012 04:17 PM
