#15 |
Drives: 2014 FR-S
You are going about this the wrong way. If you are concerned about ride height you should swap your springs, not your wheels.
From 215/45/17 to 235/40/18 you are gaining a 10mm or 0.4in increase in height, but spending 4-5x more than simply swapping to an Eibach pro-kit and gaining back the same amount, but with better shock travel. Not to mention 18 inch rims are heavy. |
| The Following User Says Thank You to kbye For This Useful Post: | Calum (10-14-2015) |
#16 |
Not a troll
I don't get why you want to lower the car, then complain about the car scraping, then want to get taller tires to compensate for the lowering. You can't have your cake and eat it too.
| The Following User Says Thank You to Cole For This Useful Post: | Tcoat (10-14-2015) |
#17 | |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
The answer is yes, at the expense of increased weight, less tire to body clearance, and decreasing acceleration. |
#18 | |
Drives: 2013 FR-S Argento
I'm not suggesting you not install lowering springs, but if you're worried about scraping you probably bought the *wrong* springs. There are lowering springs out there that lower your less - RCE might be a good candidate because I think they lower around .7". Then you have the others, swift, eibach pro, etc that lower around 1". Honestly I currently have Eibach Sportlines which lower about 1.2-1.3" and I have no problems with scraping (but ymmv). p.s. - you're an engineering student?!
#19 | ||
Engineering Student
Drives: Scion FR-S 2015
I know that 18" wheel will increase the ride height slightly, not noticeable and you confirmed it. Thank you. Quote:
.. All the information you've given I know. Speed will change around 4-5 km/h which is not a problem. ABS does not get affect... And I can always pump the brakes.1" and 1.3" does not make a difference in my eyes =p! Also the springs compression ratio seems to be stiff enough so if I go slow.. I am good. I think! I think of changing my springs....but I just bought the tein s.. so I'm not willing to just buy new one Yes, in Software not Mechanical ... Although I do a very good job in mechanical.
There’s no time to stop for gas, we’re already late
#20 | |
Not a troll
#21 | |
Idk what to tell you, the answers are all obvious if you do research, some people just forget that that usually comes before buying. |
#22 | ||
Engineering Student
that's good enough for me hahaha!Quote:
Genius me ! I will sell my springs and buy a less aggressive drop.
#23 |
Drives: brz
#24 |
#25 |
Engineering Student
Okay soooooo, I decided to go yolo.... LOL! Yes I do change my opinions. I will install the springs. However, will I rub against my fender with the Tein-S Springs?? I have bumpy roads... and I am setting up 18x9.0 wheels!?
#26 |
Drives: brz
#27 |
Engineering Student
#28 |
Drives: Scion FR-S, Ultramarine
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 17x9.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 10-31-2019 04:22 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 | kimchangil424 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 01-03-2017 06:00 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 | Killerbee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 03-08-2014 04:49 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 02-25-2014 06:00 AM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x7.5 +47 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-31-2012 04:17 PM |
