#15 |
Drives: 15 BRZ LTD, 05 FXT
https://instagram.com/liftedbrz/
This car is fun! It's a pretty basic set of parts to get there, and definitely more down the rally path than off roader 4x4 path.
| The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post: | 6-Shift (10-14-2015), BigFatFlip (10-12-2015) |
#16 | |
Fart-noise maker
Drives: 2014 Scion FR-S
#17 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I'm not so sure a 3"-4" lift is possible. You certainly might get a similar lift with a combination of a spacer and taller tires like somebody else posted. As I mentioned earlier, your limiting factor will be the control arms and the rear multi-link suspension. The outback is lifted to begin with, so lifting it more might not be that big of a deal. I also have an outback and looked into lifting it with the Primitve kit. Because the outback has a multi link geometry rear suspension, lifting the rear involves subframe spacers. I would imagine that would be the same problem with our cars. Even if you were able to lift it that way, you would also need to do some other mods like toe link exensions, end link extensions, eccentric bolts or something to correct alignment, etc. Like anything else, if you're willing to pay, anything is possible! Either way, looking forward to what ever you come up with. Good luck!
#18 |
Drives: 2014 GT86
@JazzleSAURUS: That's your brz? What parts have you used for lifting it?
| Where to Lift with Two Post Lift? | Don Ivey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 08-18-2022 08:51 AM |
| EZCarLift Easy car lift portable super easy car lift | bren5279 | Mechanical Maintenance and Tools | 16 | 09-11-2015 01:57 PM |
| Car talk | calis5nest | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 05-02-2013 02:04 PM |
| TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! | Lisa@TrueStreetIndustries | Exterior Parts - Lighting | 129 | 01-18-2013 08:57 PM |
