Old 09-30-2014, 12:30 PM   #43
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Great DIY!!
Ryaquinn is offline   Reply With Quote
Old 10-03-2014, 11:15 PM   #44
pantdino
Drives: Firestorm 2013 FR-S
rubber stopper works too
For those of you who shop at Home Depot and can't find the described plug, I used a rubber stopper. I got the 15/16 x 11/16" size but it is too big, so I ended up using a 13/16 x 9/16 plug I had.
It isn't mentioned on the posts I saw but when you look at the hole from the passenger side you see the end of the sound tube inside a rubber grommet with a flexible membrane between the outer and inner diameters. I pushed the sound tube thru the grommet and then inserted the stopper.
When viewed from the firewall side with a mirror the end of the stopper can be seen sealing off the inside of the grommet, insuring that water will not go in when driving in the rain. Just leaving an open hole in the firewall is not a good idea.
Haven't driven the car yet so I can't comment on the sound difference, but as I intend to change the exhaust a little quieter is probably a good thing.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 10-18-2014, 07:08 PM   #45
pantdino
Just an update-- the car sounds better to me with the tube disconnected.
The sound tube was kind of fake at low to medium revs and at high revs was very thrashy. Better off without it.
Old 08-17-2015, 01:18 PM   #46
Evil Rocky
Drives: FRS
Looking forward to doing this.
Evil Rocky is offline   Reply With Quote
Old 08-18-2015, 07:31 PM   #47
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Just plugged my hole.. after going turbo, so I didn't need the intake cap, just a way to plug up the cabin!
Anyway it was in the pipe section at my local Home Depot.
bryan767 is offline   Reply With Quote
Old 08-23-2015, 11:48 AM   #48
BRZHarley
Drives: 69 Firebird, 2015 BRZ
Hello everyone !!
I just did this on my 2015 and I'm very happy... The sound change is subjective and may not be for everyone... ��
I also found the cap from an empty gallon jug of coolant work as a perfect plug until I get a new inlet air tube... ��
Thanks for the tip!
Ed H
BRZHarley is offline   Reply With Quote
Old 08-23-2015, 12:13 PM   #49
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Great DIY. Used it to cap the sound tube intake hole.
Sideways is offline   Reply With Quote
Old 09-13-2015, 07:23 PM   #50
xsl27x
Drives: 2015 Scion FRS, Firestorm
Thanks for the DIY. Definitely a more natural sound. I ended up using a 1/2" hard plastic plug (Lowe's) inside the rubber grommet in the passenger footwell. Couldn't get the 3/4" to fit for some reason...
xsl27x is offline   Reply With Quote
Old 09-13-2015, 09:17 PM   #51
8R6
8R6's Avatar
Drives: FRS
when i did this "mod" back when my car was stock, i couldn't really tell a difference in sound. and then after i got my exhaust, it doesnt even matter cuz everything is so damn loud now lol
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
B-R-Z (10-13-2015)
Old 10-13-2015, 01:32 AM   #52
akidnamedguiza
akidnamedguiza's Avatar
Drives: 2013 Subaru BRZ
Thank you for this! Saved me well over 100 dollars on an intake tube. Now that money can be put towards other mods!
akidnamedguiza is offline   Reply With Quote
The Following User Says Thank You to akidnamedguiza For This Useful Post:
B-R-Z (10-13-2015)
Old 11-02-2015, 09:01 AM   #53
mattyd97
Drives: 2014 SSM BRZ
When I installed my K&N intake I took out this part of the sound gen, but not the entire tube. Would it be more beneficial/sound better with the rest taken out?
mattyd97 is offline   Reply With Quote
Old 11-02-2015, 11:02 AM   #54
churchx
churchx's Avatar
Drives: 2014 GT86
Beneficial in way of a bit more roomy and cleaner underbonnet space and slight weight savings when doing complete sound tube deletion. I wouldn't throw out it, but keep in some drawer for when in few years you are going to sell it. Buyers may have different sound preferences then you, so it doesn't hurt to keep stock parts around imho.
Old 11-02-2015, 11:16 AM   #55
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The weight savings is insignificant. It's a 100% aesthetic change, both visually and aurally.
Old 12-18-2015, 11:00 AM   #56
Worstenemy453
Drives: 2013 Argento FR-S
I hate looking at the stupid thing under the hood.
Sent from my SM-N900V using Tapatalk
Worstenemy453 is offline   Reply With Quote
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 01:26 AM
Sound generator delete for $1.06 PineappleFriedRice Engine, Exhaust, Transmission 13 11-10-2013 12:28 PM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 04:25 AM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 11:31 AM
