View Poll Results: Engine Failure Options
Rebuild for NA 3 3.75%
Rebuild for Boost 2 2.50%
Rebuild for Boost with Forged Internals 49 61.25%
2JZ 5 6.25%
LS V8 12 15.00%
Synergy V8 2 2.50%
Sell and Buy Prius 3 3.75%
Sell and Buy Other Car 3 3.75%
Other 1 1.25%
Voters: 80. You may not vote on this poll
Old 10-11-2015, 11:35 PM   #1
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question Boosted Blown Motor Options, Should it Happen
Nobody wants to blow their boosted engine, but should the unfortunate happen, what route would you take?
Chad86 is offline   Reply With Quote
Old 10-11-2015, 11:40 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I would weigh the costs of a built FA20 vs a high RPM LSX swap. And choose the easier route. Most likely a built FA20
Freeman is offline   Reply With Quote
Old 10-11-2015, 11:44 PM   #3
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
On word.
Transmission.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
Ultramaroon (10-12-2015), xxscaxx (10-13-2015)
Old 10-12-2015, 05:15 AM   #4
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
How does one rebuild for boost without forged internals?
Build Thread
Instagram
Old 10-12-2015, 12:15 PM   #5
Spartarus
...Just add nauseum
Spartarus's Avatar
Stock internals are more durable than they get credit for.**
High compression and e85 are friends when FI.
Some people don't like the turbo lag and narrow power band associated with low compression.
Stock internals are cheap.
Any decent FI build with forged internals is going to be hitting the max power the transmission can hold pretty quick.
That's all I can think of for now. Just playing devil's advocate.
**stock pistons are weak but they do fine with e85, stock rods are strong but they can't handle lots of low end torque.
-Spartarus
Old 10-12-2015, 07:25 PM   #6
Binary_fission
Binary_fission's Avatar
Drives: FRS
This
http://crawfordperformance.com/produ...3-brzfrsgt-86/
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 10-12-2015, 07:57 PM   #7
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by Binary_fission View Post
This
Please no, thanks.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following 7 Users Say Thank You to BRZoomTX For This Useful Post:
ATL BRZ (10-14-2015), calmtigers (10-13-2015), Creole (10-26-2015), Freeman (10-12-2015), GotBRZ1691 (10-14-2015), Spartarus (10-12-2015), The Racers Line (10-12-2015)
Old 10-12-2015, 08:06 PM   #8
raven1231
Sfr swap!
Old 10-12-2015, 08:19 PM   #9
Binary_fission
Drives: FRS
Originally Posted by BRZoomTX View Post
Please no, thanks.
Why not?
Old 10-12-2015, 08:48 PM   #10
kch
Senior Misanthrope
kch's Avatar
Why not?
Crawford, while successful with other subaru engines, does not have a good reputation with the FA20. Plus their stuff is crazy expensive. And really, who the hell thinks it's a good idea to sell a turbo kit without an intercooler? I question their decision-making skills.
The Following 2 Users Say Thank You to kch For This Useful Post:
GotBRZ1691 (10-14-2015), Sportsguy83 (10-14-2015)
Old 10-12-2015, 09:23 PM   #11
Binary_fission
Drives: FRS
Any sources or just outta top of your head?
How much are the internals of the engine that are forged? If you did your research you'd know it's ganna run you at about 3k and that's minimum. Add another 1k and you have a whole new block with forged internals already.
I'm not here to promote crawford or say they are the shit, but I see a good deal for reasonable price so if I do blow my engine I'm going with this route.
specifications)
Included items;
S3L – I FA Short Block:
– New 2.0-Liter Block
– New 86mm forged crankshaft
-New longer than stock Billet I beam connecting rods
– New Subaru main bearings
– New Subaru rod bearings
– New Subaru High Performance High Mileage Piston Rings
– CP-Designed low detonation Forged Pistons
– All new hardware
And where did you see their turbo kit doesn't come with intercooler?
Old 10-12-2015, 09:25 PM   #12
CSG Mike
CSG Mike's Avatar
specifications)
Included items;
– All new hardware
Basically a refreshed engine with "custom" rods and off-the-shelf CP pistons.
We can get you much better parts for that price, and you can re-use an existing engine.
Old 10-12-2015, 09:56 PM   #13
djliquidsteele
Drives: Scion FR-S
specifications)
Included items;
– All new hardware
There are horror stories on that other subaru performance forum about Crawford. There is a reason they are not a vendor here. Look elsewhere if you ever need a built engine. I have not looked into a built engine yet, but full blown seems to have a good rep. I'm sure any reputable vendor here could get you going.
djliquidsteele is offline   Reply With Quote
The Following User Says Thank You to djliquidsteele For This Useful Post:
ajcarson11 (10-13-2015)
Old 10-12-2015, 11:09 PM   #14
Spartarus
...Just add nauseum
Spartarus's Avatar
I fixed your post for you.
(NO. You can do forged internals at off-the-shelf prices for $1223.00. That's just one example. And it'll buy you the same pistons and rods Crawford uses.)
Who cares? There's nothing wrong with your block unless you windowed it breaking a rod
You haven't done your research at all.
These are copypasted specs from your post. Let me correct them and remove the marketing hype
Included items;
S3L – I FA Short Block: (marketing hype. Renamed an existing engine without re-engineering anything)
– New 2.0-Liter Block OEM parts, upcharged...
– New 86mm forged crankshaft STOCK CRANK IS FORGED. more OEM parts, upcharged...
-New longer than stock Billet I beam connecting rods Off-the-shelf from another manufacturer
– New Subaru main bearings MORE OEM parts, upcharged...
– New Subaru rod bearings MORE OEM parts, upcharged...
– New Subaru High Performance High Mileage Piston Rings MORE OEM parts, upcharged...
– CP-Designed low detonation Forged Pistons More off-the-shelf parts from other manufacturers?
– All new hardware MORE OEM parts, upcharged...
Of the 8 things on that list, only 2 aren't Subaru OEM... And both of them are off-the-shelf aftermarket parts from other companies. You forgot to paste in the bullsh*t weak-sauce justification for using so many OEM parts... "No cheap aftermarket parts here..." Except all the off-the-shelf aftermarket internals...? They're just using the long list and new engine "designation code" to talk up what amounts to a really simple build.
And where did you see their turbo kit doesn't come with intercooler? They used to market it without one. And without a blowoff valve.
They didn't build or engineer anything in that engine like they claim. They just hype it up so they can upcharge the sh*t out of it.
They're a shit shop that trades their entire reputation on a car they built in 2009 on an UNLIMITED BUDGET (talking about the Gymkhana car they ceaselessly brag about). Any f*ck hole with a wrench can do that. Any idea why Gymkhana 3 - 7 haven't been built there?
For a budget of $4099, Stripping down and building your own engine funds the internals as well as the valvetrain, clutch and flywheel, injectors, proper ARP studs, and most of a fuel pump. You know, all the real support for a boosted build.
-Spartarus
The Following 3 Users Say Thank You to Spartarus For This Useful Post:
86kahl (10-21-2015), ajcarson11 (10-13-2015), Sportsguy83 (10-14-2015)
Anyone blown a stock boosted motor yet? Guildjs Forced Induction 514 04-28-2020 12:33 PM
How reliable is the FA20 motor when boosted? Zoooom Forced Induction 50 06-08-2016 07:52 PM
Full blown turbo kit, boosted issue. Help please Xxdragn89xX Forced Induction 7 09-10-2015 09:37 AM
Boosted Twins and motor mounts FAER Forced Induction 42 03-07-2014 05:57 PM
