Old 09-30-2015, 11:20 PM   #1
dgerny
Drives: 2013 Scion FRS
FA20 Engine weight?
Anyone know the engine/trans weight of a stock FA20?
dgerny is offline   Reply With Quote
Old 09-30-2015, 11:36 PM   #2
Fastbrew
Drives: 2014 Pearl White BRZ
Take a peek at this
http://www.vorshlag.com/forums/showthread.php?t=8275
"Weight of 2.0L engine and 5-spd transmission is 493 pounds with a 13 pound dolly;"
So - 480 lbs according to their scale.
Fastbrew is offline   Reply With Quote
The Following 6 Users Say Thank You to Fastbrew For This Useful Post:
azian_advanced (10-08-2015), Calum (10-08-2015), CxG (10-30-2015), dgerny (10-01-2015), GhostOp86 (10-08-2015), scary alien (10-01-2015)
Old 10-08-2015, 12:36 PM   #3
350matt
Drives: toyota mr2/ Toyota GT86
so what does the transmission weigh?
350matt is offline   Reply With Quote
Old 10-08-2015, 01:34 PM   #4
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Transmission is around 90lbs
crazyfrenchbiker is offline   Reply With Quote
Old 10-09-2015, 01:40 PM   #5
350matt
so the engine is 390 lbs? / 177kg?
seems a bit heavy to me I'd say the trans is probably a bit heavier than that
most 4 cylinders are in the 140Kg 300lb area
Old 10-09-2015, 01:46 PM   #6
thunderlights
It would make sense that our boxer motors are a tad heavier than inline 4cyl motors considering we have two cylinder heads.
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
The Following User Says Thank You to thunderlights For This Useful Post:
CxG (10-30-2015)
Old 10-09-2015, 01:57 PM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Boxer engines have lower center of gravity, but they are heavier. You need double timing gears on each side etc.
Old 10-09-2015, 02:53 PM   #8
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
There are iron block inline 4's that share a comparable weight to this engine. It's a heavy b*tch
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
CxG (10-30-2015)
Old 10-09-2015, 05:12 PM   #9
celek
Resident Gear Head
celek's Avatar
My sleeved bare block is well over 100LBs I think the label from UPS was 150lb warning crank has to be around 40lbs
celek is offline   Reply With Quote
Old 10-30-2015, 03:55 PM   #10
CxG
Drives: Pearl White '13 ZN6
seeing how far back the shift lever assembly is extended and how far forward our engine sits in the engine bay makes me mad every damn time. sorry just
Originally Posted by Fastbrew View Post
Take a peek at this
CxG is offline   Reply With Quote
Old 02-10-2024, 08:15 PM   #11
Nick Dugdale
Nick Dugdale's Avatar
Drives: 2015 Subaru BRZ
*CONFIRMED* Here is the FA20 out of the 2015 BRZ sporting an 10lb aftermarket flywheel and OEM clutch still on the engine.
Weight excludes fluids, AC compressor (+10lb) , injector covers (+5lb) and exhaust manifold (+15lb), OEM flywheel (+10lb)
My FA20 weight: 315 pounds as shown
OEM FA20 weight ~355-360 pounds
Welcome!
"The vision manifests the reality." NASA TT5 Silver 2015 Subaru BRZ Limited
Nick Dugdale is offline   Reply With Quote
The Following 2 Users Say Thank You to Nick Dugdale For This Useful Post:
kevaughan (07-27-2024), RedReplicant (02-10-2024)
WTB OEM FA20 ENGINE PARTS Junique Want-To-Buy Requests 3 06-10-2015 09:52 AM
FA20 engine Manji Australia Classifieds 0 12-27-2014 10:44 PM
FA20 dimensions and weight 1697P Engine, Exhaust, Transmission 3 04-06-2014 07:02 PM
FA20 vs. Cayman engine? Need ur backup. qqzj BRZ First-Gen (2012+) — General Topics 13 11-07-2013 01:02 PM
FA20 + gearbox weight Vs Transplant setups.... FT-86GOD Engine, Exhaust, Transmission 2 08-21-2012 10:42 PM
