#57 |
Drives: 2JZ FRS
i built my car for drag/street primarily, so what i do might be different than what you are trying to do. so this is what i experience. being easy on shifts at the track is not an option for me. for the street, yes. i shift very fast going down the track, but i never had a grind, just stripped 3rd and 4th gears. hell, when i had my AVO kit my stock trans had synchro issues and i never even took the car to the track at that point. my last spare trans thats in my car right now (installed a stock clutch and sold my twin disk in anticipation of my auto swap) grinds going into 4th gear, even at low rpms and long shifts with no more than maybe half throttle so i don't burn up the clutch. this trans is from a 10k mile stock car.
overall, its just a trans thats not the greatest out there. there is a multi page thread about cars completely stock grinding/crunching going into gears. its not a rare issue
#58 | |
Drives: Asphalt frs
#59 |
Drives: 2JZ FRS
a LS2 swap we did, a 2JZ swap, then a total loss we parted out
| The Following User Says Thank You to spitfire481 For This Useful Post: | SoCal80six (10-09-2015) |
#60 |
Drives: Asphalt frs
#61 |
Drives: 2JZ FRS
i have a 10:1 fa20 with a precision 6466 right now
#62 |
Drives: Asphalt frs
#63 |
Drives: 2JZ FRS
built by full blown. stock heads with ferrea springs/retainers. 10:1 arias pistons, full blown rods, arp studs
#64 |
Senior Misanthrope
| The Following User Says Thank You to kch For This Useful Post: | SoCal80six (10-09-2015) |
#65 |
Drives: 2013 FR-S Whiteout
I'm not a gear banger by any means, shift quickly and smoothly yes, but do not force my gears by any means. Seems like, even for auto cross and daily driving use with occasional w.o.t. driving the gears themselves are at risk. Either way, I'm not concerned about the synchros, I'm more concerned with shearing gears off in 3rd and 4th from what I'm hearing on here. I'm not spending $15k on a full build top to bottom from FBM, to just baby this car, that's for sure. So perhaps I'll just pick up a spare transmission for when the one in it now inevitably goes. I will definitely be reporting on here how things go once the build is installed to let every one know how the stock transmission holds. It's honestly a shame that there aren't any rebuild kits on the market yet to make it stronger
Sent from my SM-G900V using Tapatalk |
#66 |
And feedback on where to get a hold of used transmissions for these cars?
#67 |
Drives: Asphalt frs
#68 |
Drives: 2JZ FRS
Maybe one day. I'll do ported heads with cams and sleeves in the block so I can run 40psi. I make about 600 right now, closer to 700 with my new turbo and injectors when I tune it again
#69 |
Drives: Asphalt frs
#70 |
...Just add nauseum
Drives: 2003 (AP1) S2000
Ebay, junkyards, craigs, salvage, copart
There are many ways to displace.
-Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | SoCal80six (10-09-2015) |
| Forced Induction HELP! | surfuxalot | Forced Induction | 22 | 06-20-2015 12:56 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 03:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 07:17 AM |
| 6AT (+) Forced Induction | RYU | Forced Induction | 18 | 09-09-2012 11:14 PM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 07:50 PM |
