Old 10-06-2015, 03:17 PM   #1
flat4-86
flat4-86's Avatar
Drives: 2013 FR-S Whiteout
Full build forced induction
I am currently doing my homework on doing a full build on my engine to make the switch to forced induction. A lot of my research has lead me to Crawford Performance and there fully built short block. Goals on the build thus far are 400whp on 93 octane with boost set right around the 20psi mark. I still consider myself an amateur when it comes to a build of this magnitude. Money will not be an issue here so please keep that in mind. Any helpful advice and feedback will be greatly appreciated. Are my goals unreasonable? Is crawford reliable enough?
flat4-86 is offline   Reply With Quote
Old 10-06-2015, 03:26 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I too looked into Crawford. When I saw a customer was on his third built motor from them I stopped looking at them. Maybe you'll have better luck than that guy did
Freeman is offline   Reply With Quote
The Following 3 Users Say Thank You to Freeman For This Useful Post:
ajcarson11 (10-07-2015), flippy (10-08-2015), raven1231 (10-07-2015)
Old 10-06-2015, 04:29 PM   #3
flat4-86
flat4-86's Avatar
Were you able to find out what any of the issues were that he was having? Poor tune, bad turbo, driven too hard/pushed to far, etc..
Sent from my SM-G900V using Tapatalk
Old 10-06-2015, 04:58 PM   #4
Freeman
Freeman's Avatar
From what I remember it was engine assembly related.
I would also look at Full Blown Motorsports. I believe they offer engine building services.
The Following User Says Thank You to Freeman For This Useful Post:
Dream20b (10-07-2015)
Old 10-06-2015, 05:08 PM   #5
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Hi, we have tons of motors out there and have a vast knowledge on what these motors need to keep them together. Please feel free to contact us with any questions you may have.
FullBlown is offline   Reply With Quote
The Following 8 Users Say Thank You to FullBlown For This Useful Post:
BBDGriptonia (10-13-2015), cdrazic93 (10-06-2015), DustinS (10-07-2015), D_Thissen (10-06-2015), flippy (10-08-2015), Freeman (10-06-2015), SoCal80six (10-08-2015), Sportsguy83 (10-07-2015)
Old 10-06-2015, 05:27 PM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The transmission is a major concern at that power level. 400 is right on the line. Street guys have held that power for tens of thousands of miles. On the other hand, Element Tuning (390 whp racecar) goes through a transmission in 5 race days or less. It'll hold together at that power level, but it won't take a thrashing on wide grippy tires and/or an aggressive clutch. It'll take launches, but not clutch-dump crashbox launches. Anywhere above the low 400's seems to be the place where the transmission becomes a guaranteed time bomb regardless of the setup.
Crawford is a really bad idea. Horror stories abound
Full Blown does good work.
My .02
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
ajcarson11 (10-07-2015), Sportsguy83 (10-07-2015)
Old 10-06-2015, 06:21 PM   #7
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
If I can find a used block I will definitely send it to FBM to have them build it for me.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-06-2015, 08:07 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Lol product snipe. Nice job FBM, another one saved
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 10-07-2015, 06:31 AM   #9
flat4-86
flat4-86's Avatar
The car won't be abused too often, but I was going to look into local auto cross events and some track days here and there. Will the transmission so be in danger? Or is it still uncertain what the transmission will be able to take. ... and what kind of mods will need to be done to the transmission to get it to comfortably hold that amount of power?
Old 10-07-2015, 06:34 AM   #10
flat4-86
flat4-86's Avatar
My .02
What kind of horror stories have you heard about crawford? Do they just not know what they're doing or are they pushing they're blocks too hard??? I am going to be calling FBM today to get pricing and options
Old 10-07-2015, 12:52 PM   #11
Spartarus
...Just add nauseum
Spartarus's Avatar
I don't want to sling more sh*t at anyone. They're banned from this forum. You can find a few entertaining ones on that other Subaru tuner forum that I'm not going to mention, and make your own decision.
-Spartarus
Old 10-07-2015, 12:58 PM   #12
flat4-86
flat4-86's Avatar
Gotcha, appreciate the advice too. I already spoke with FBM and their prices were thousands cheaper, plus offering built heads to go along with the bottom end build. Looking good for FB right now
Old 10-07-2015, 01:00 PM   #13
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
My fbm block still takes a beating at 30psi. Should make 700ish with the new fueling and turbo
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 10-07-2015, 01:24 PM   #14
flat4-86
flat4-86's Avatar
Thanks for the heads up... full build top to bottom? Does the stock tranny hold the power well? How many miles have you put on it so far?
Forced Induction HELP! surfuxalot Forced Induction 22 06-20-2015 12:56 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
