Old 08-28-2015, 08:12 PM   #169
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
So anyway, got a release date on those Pesnkes?
Old 08-28-2015, 09:53 PM   #170
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
There is an excellent reason why "dude" over here is already on my ignore list. Although there are douches(singular) I'm not "allowed" by the system to add to ignore list.
Intent > Content
Old 08-28-2015, 09:54 PM   #171
solidONE
solidONE's Avatar
Originally Posted by jsimon7777 View Post
So anyway, got a price on those Pesnkes?
Yeah man, enough with the suspense already. Let's hear the heart-wrenching truth.
Intent > Content
Old 08-29-2015, 09:17 PM   #172
djliquidsteele
Drives: Scion FR-S
I think the price is somewhere in the vicinity of If you gotta ask, you can't afford them.
djliquidsteele is offline   Reply With Quote
Old 08-29-2015, 10:27 PM   #173
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
It's probably going to be fairly close to a set of Penskes for any other car. I don't want to speculate on here, but prices are published... This shouldn't be a surprise. They're going to be expensive, but they're going to be worth it.
GSpeed is offline   Reply With Quote
Old 08-30-2015, 04:22 PM   #174
solidONE
solidONE's Avatar
Well, I recall seeing some rather "affordably priced" sets of Penskes for the Mustang before. I expect these to be on a different price bracket than those. Considering Raceng is also adding their pieces to the kit, I wouldn't doubt that will bring the price tag up even more.
My 3-way Penske shock cost me $1400, roughly. So multiply that by 4 were talking $5600. A similar 2-way shock will run for about $1000 a piece. So $4000 for a set of 4. I seriously doubt this set will be anywhere close to that. A set of 4 for the S2000 can be had for less than $5000, as reference. http://performanceshock.com/index.ph...oducts_id=1220
Intent > Content
Old 10-02-2015, 12:27 PM   #175
Raceseng
Raceseng's Avatar
Gents, thank you for your patience. Please see the pricing below:
Raceseng X Penske Pricing
All packages come with front caster + camber plates and rear top mounts.
7500 Non Adjustable
No adjustability
$7,365.00
7500 Single Adjustable
Single rebound adjustment
$7,785.00
7565 Dual-Bleed Adjuster
Independent rebound and compression bleed control
$9,495.00
8300 Double Adjustable
Single rebound bleed adjuster + Single high speed compression adjuster w/remote reservoir
$8,583.33
8365 3 Way Adjustable w/Dual-Bleed Adjuster
Independent adjustment of low speed rebound and compression + Single high speed compression adjuster w/ remote resevoir
$10,300.00
8760 3 Way Adjustable
Single rebound bleed adjuster + High and low speed compression adjuster w/remote reservoir
$10,353.33
8765 4 Way w/ Dual-Bleed Adjuster
Independent adjustment of low speed rebound and compression + Independent high and low speed compression adjuster w/ remote resevoir
$12,060.00
Raceseng is offline   Reply With Quote
Old 10-02-2015, 01:06 PM   #176
jvincent
jvincent's Avatar
Time to start a GoFundMe campaign.
Old 10-02-2015, 09:45 PM   #177
ChrisV
Drives: 2014 FR-S 6MT
Who exactly is dropping seven grand on non adjustable shocks?
ChrisV is offline   Reply With Quote
Old 10-02-2015, 09:53 PM   #178
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I would imagine race teams would depending on the series they are running and what the requirements are for it.
Mike
AZP Installs is offline   Reply With Quote
Old 10-02-2015, 09:55 PM   #179
cjd
cjd's Avatar
Drives: 2017 BRZ
If they're perfect, who needs to adjust?
Old 10-03-2015, 12:10 AM   #180
solidONE
solidONE's Avatar
$10,300.00
$10,353.33
What's the main advantage or disadvantage of the dual-bleed adjuster in the 8365 compared to the 8760? It's only $13.33 difference between the 2 models.
Intent > Content
Old 10-03-2015, 12:01 PM   #181
RBbugBITme
Drives: S60R/Corvette
8365: For the proper race car with little to no rubber in their suspension, a dual-bleed adjuster can be a very powerful tuning tool as it only affects rebound or compression completely independently and only changes forces in the 0-3 in/sec range. This adjuster mechanism is on the majority of kits we sell from the Continental Tire series upto F1. Its the type of adjuster that adds to our reputation due to the feeling the drivers get from it and the consistency with each click. The remote reservoir has one ("low speed") bleed adjuster which can lead to increased hysteresis when set to full hard. Obviously once you're out to full hard you should rebuild the shock so you can be set to a softer setting and still have the force levels you want without the hysteresis.
The 8760 basically has 1/2 of the dual-bleed adjuster (cheaper) and an additional high speed adjuster in the remote head valve (more expensive). So the price balances out. You end up with 1 rebound bleed adjuster and 2 high/low speed compression adjusters.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 10-05-2015, 06:53 PM   #182
solidONE
solidONE's Avatar
So kind of like the TTX in performance?
Intent > Content
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
More info on Penske shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 04-28-2015 10:22 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
Ultimate Racing Exhaust help psyclone07 Engine, Exhaust, Transmission 0 07-06-2014 11:05 PM
Ultimate Racing, quality? rhythmM Engine, Exhaust, Transmission 5 11-30-2013 05:46 PM
