#169 |
Dismember
Drives: 2013 Red Scion FR-S
So anyway, got a release date on those Pesnkes?
#170 |
Drives: FR-S Whiteout
There is an excellent reason why "dude" over here is already on my ignore list. Although there are douches(singular) I'm not "allowed" by the system to add to ignore list.
Intent > Content
cowardice is the mother of cruelty. |
| The Following 3 Users Say Thank You to solidONE For This Useful Post: |
#171 |
Yeah man, enough with the suspense already. Let's hear the heart-wrenching truth.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 08-28-2015 at 10:08 PM. |
#172 |
Drives: Scion FR-S
I think the price is somewhere in the vicinity of If you gotta ask, you can't afford them.
#173 |
Drives: 2015 BRZ
It's probably going to be fairly close to a set of Penskes for any other car. I don't want to speculate on here, but prices are published... This shouldn't be a surprise. They're going to be expensive, but they're going to be worth it.
#174 |
Well, I recall seeing some rather "affordably priced" sets of Penskes for the Mustang before. I expect these to be on a different price bracket than those. Considering Raceng is also adding their pieces to the kit, I wouldn't doubt that will bring the price tag up even more.
My 3-way Penske shock cost me $1400, roughly. So multiply that by 4 were talking $5600. A similar 2-way shock will run for about $1000 a piece. So $4000 for a set of 4. I seriously doubt this set will be anywhere close to that. A set of 4 for the S2000 can be had for less than $5000, as reference. http://performanceshock.com/index.ph...oducts_id=1220
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 08-30-2015 at 04:33 PM. |
#175 |
Gents, thank you for your patience. Please see the pricing below:
Raceseng X Penske Pricing All packages come with front caster + camber plates and rear top mounts. 7500 Non Adjustable No adjustability $7,365.00 7500 Single Adjustable Single rebound adjustment $7,785.00 7565 Dual-Bleed Adjuster Independent rebound and compression bleed control $9,495.00 8300 Double Adjustable Single rebound bleed adjuster + Single high speed compression adjuster w/remote reservoir $8,583.33 8365 3 Way Adjustable w/Dual-Bleed Adjuster Independent adjustment of low speed rebound and compression + Single high speed compression adjuster w/ remote resevoir $10,300.00 8760 3 Way Adjustable Single rebound bleed adjuster + High and low speed compression adjuster w/remote reservoir $10,353.33 8765 4 Way w/ Dual-Bleed Adjuster Independent adjustment of low speed rebound and compression + Independent high and low speed compression adjuster w/ remote resevoir $12,060.00 |
#176 |
Time to start a GoFundMe campaign.
| The Following User Says Thank You to jvincent For This Useful Post: | wparsons (10-14-2015) |
#177 |
Drives: 2014 FR-S 6MT
Who exactly is dropping seven grand on non adjustable shocks?
#180 | |
Intent > Content
#181 |
Drives: S60R/Corvette
8365: For the proper race car with little to no rubber in their suspension, a dual-bleed adjuster can be a very powerful tuning tool as it only affects rebound or compression completely independently and only changes forces in the 0-3 in/sec range. This adjuster mechanism is on the majority of kits we sell from the Continental Tire series upto F1. Its the type of adjuster that adds to our reputation due to the feeling the drivers get from it and the consistency with each click. The remote reservoir has one ("low speed") bleed adjuster which can lead to increased hysteresis when set to full hard. Obviously once you're out to full hard you should rebuild the shock so you can be set to a softer setting and still have the force levels you want without the hysteresis.
The 8760 basically has 1/2 of the dual-bleed adjuster (cheaper) and an additional high speed adjuster in the remote head valve (more expensive). So the price balances out. You end up with 1 rebound bleed adjuster and 2 high/low speed compression adjusters.
Ryan M.
Strange Engineering Director of Suspension Development |
#182 | |
Intent > Content
| Ultimate Racing Turbo Kit | sweetfrs | Forced Induction | 34 | 12-17-2015 11:25 AM |
| More info on Penske shocks | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 156 | 04-28-2015 10:22 AM |
| Ultimate Racing Turbo Kit | ganz954 | Forced Induction | 19 | 11-13-2014 10:34 PM |
| Ultimate Racing Exhaust help | psyclone07 | Engine, Exhaust, Transmission | 0 | 07-06-2014 11:05 PM |
| Ultimate Racing, quality? | rhythmM | Engine, Exhaust, Transmission | 5 | 11-30-2013 05:46 PM |
