Old 10-01-2015, 10:11 PM   #1
celek
Resident Gear Head
celek's Avatar
Finally straight cut gears!
Found these surfing the net.
Does anyone know where I can sell a testicle?
http://www.forgedperformance.com.au/...-cut-gear-set/
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
chaoskaze (10-02-2015)
Old 10-01-2015, 10:23 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Good old forged performance. Can't even get the list of stock ratios correct.
Old 10-01-2015, 10:38 PM   #3
fika84
fika84's Avatar
They have the stock automatic gear ratios as the "standard" and then the straight cut gears they make have slightly longer ratios for 1-4, same 5th and slightly shorter 6th. Not bad... but $7K?!???
fika84 is offline   Reply With Quote
Old 10-02-2015, 04:27 AM   #4
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Well, if it's any consolation, that's in AUD, so more like $5k USD.
The Following User Says Thank You to BigFatFlip For This Useful Post:
fika84 (10-02-2015)
Old 10-02-2015, 10:11 AM   #5
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Precision Automation and Robotics? That big Indian company makes car parts?!
Old 10-02-2015, 02:26 PM   #6
thunderlights
Im curious as to what other components are needed to make the trans hold 500+ hp on top of this.
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
Old 10-02-2015, 04:24 PM   #7
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
The synchros are still crap.
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
GotBRZ1691 (10-03-2015)
Old 10-03-2015, 02:30 PM   #8
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
It's the PAR set that's been available for a while now
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 10-05-2015, 07:14 PM   #9
86drift
86drift's Avatar
Why would anyone buy a straight cut gear set without dog engagement?
Straight cut gears are hardly suitable for street duties.
86drift is offline   Reply With Quote
Old 10-05-2015, 09:20 PM   #10
djliquidsteele
Drives: Scion FR-S
Because race car?
djliquidsteele is offline   Reply With Quote
The Following User Says Thank You to djliquidsteele For This Useful Post:
celek (10-06-2015)
Old 10-06-2015, 09:49 AM   #11
celek
Resident Gear Head
celek's Avatar
If you require gears to hold 700+HP its really no longer a street duty car...
#becauseracecar
Old 10-07-2015, 02:25 AM   #12
matthewdesigns
Drives: '92 Miata (turbo)
See this thread for a little more info. They have already been installed in the Revvolutions car.
http://www.ft86club.com/forums/showthread.php?t=90057
matthewdesigns is offline   Reply With Quote
Old 10-07-2015, 03:39 AM   #13
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
#becauseracecar
Yeah that's his point. If you are using syncromesh in a high-speed race or drag situation, and are getting straight-cut gears, you would want to just go ahead and get dog engagement because it's far faster to shift than a synchromesh setup
It's kinda like getting a huge wing and saying #becauseracecar but then you don't have any mods that make it necessary so you're just slowing yourself down lol.
My guess is that they actually do drive it in situations where a dogbox would be really unpleasant.
fatalelement is offline   Reply With Quote
Old 10-07-2015, 11:00 AM   #14
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Did he ever get them installed? I didn't think it was done yet.
crazyfrenchbiker is offline   Reply With Quote
What grinds your gears? fika84 Off-Topic Lounge [WARNING: NO POLITICS] 99 05-14-2015 04:40 PM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 01:48 AM
Does the BRZ/FRS MT have straight cut gears? Zen_ben Engine, Exhaust, Transmission 15 04-05-2014 12:51 PM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 06:09 PM
