Drives: 2012 Grey TRD GT86, 2015 VW Golf R
4.556 final drive with TRD gear ratio change - good or bad idea?
I'm thinking of doing the Toyota OEM final drive of 4.556:1 (same as Cusco but cheaper here).
I was wondering what it would be like with this AND the TRD cross gear set here http://www.trdparts.jp/release/2015_...ssmission.html I know the effect the final drive will have and am keen but figured if they were playing around with the transmission I could get them to do the cross gear set at the same time but will the combo be better or stuff up the ratios? And, yes, I did search but couldn't find out info about the combined effect.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#2 |
final drive changes the ratio about 10% shorter.
higher final drive makes 3,4,5 gears more usable on a track. trd gear set would make 1,2 usable on the track and closer gearing between 2nd and 3rd. |
| The Following User Says Thank You to swarb For This Useful Post: | nzer (10-05-2015) |
#3 |
Drives: Sterling BRZ Ltd
4.56 is a very nice upgrade for a NA car.
#4 |
Long Distance Driver
I Plan on it @nzer. I already have a 4.8!
I already envisioned the shorter change from 2nd to 3rd. Excited
| The Following User Says Thank You to Sargy For This Useful Post: | nzer (10-05-2015) |
#5 |
Thanks for the feedback all. I've decided to do final drive first and consider gearing later. cost of gearing option is pretty steep with parts then quite a lot of labour as can't do it myself.
#6 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
[ame="https://www.youtube.com/watch?v=occuNSTlkIo"]UEL E85, 4.56 FD swap 0-80MPH - YouTube[/ame]
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#7 |
The Fail Boat
Drives: CWP S.B.
Do it! TRD stuff is obviously very good..... + this is actually one of the upgrade option for 86 in Japan when you purchase the car from dealer.
| The Following User Says Thank You to chaoskaze For This Useful Post: | nzer (10-06-2015) |
#8 | |
Drives: GT86
You might be interested in my thread: http://www.ft86club.com/forums/showthread.php?t=94450 Today my car is in a shop switching 4.67 to 4.88. Then I will decide if I buy Cusco cross mission set or nothing. Edit: I dont think you need longer gears on 4.56 FD, I run autocross here in Europe with 4.67 and it is manageable, but for 4.88 it will be probably too short. I will know for sure next week. Last edited by GT86_PRAGUE; 10-06-2015 at 04:47 AM. |
| The Following User Says Thank You to GT86_PRAGUE For This Useful Post: | nzer (10-06-2015) |
#9 |
With the 5.125 ratio the second might become a long first and fifth could finally be used in a fast slalom. (But I think according to EU-law any change exceeding 8% needs to go through an individual approval procedure by a dedicated inspection agency = extremely expensive).
#10 | |
Drives: GT86
#11 |
That's a good point.
We have to get the car inspected every 2 years and usually they take it on a very short test drive and this is where they could notice it. But this really depends on the person who's driving it. |
#12 |
Use this tire/wheel size calculator before you select a rear gear ratio
http://tire-size-conversion.com/gear-ratio-calculator/
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | Metabrz (10-28-2015) |
#13 | |
it will be unless its a very VERY small course. majority of all of my autocross courses require 3rd gear with only 1 course that I can bang off the limiter in 2nd.
#14 |
Drives: GT86
| How-To: Change final drive ratio (relatively) cheaply | PantsDants | Engine, Exhaust, Transmission | 84 | 03-22-2020 04:58 PM |
| Change gear ratio? | Afdad120108 | Engine, Exhaust, Transmission | 61 | 08-17-2016 11:44 AM |
| taller final drive ratio | SuperDave | Engine, Exhaust, Transmission | 17 | 10-26-2014 04:37 PM |
| About track cars' final drive ratio | immo | Tracking / Autocross / HPDE / Drifting | 4 | 09-23-2014 10:04 AM |
| Gear Ratio Change | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 06-26-2014 11:20 PM |
