Old 10-05-2015, 10:32 AM   #1
onzippy
Drives: 2014 FRS
Injector Circuit Malfunction
After changing out stock injectors for Deatshwerks 700cc injectors for my flex fuel conversion about 4 months ago I just started getting injector Circuit malfunction P0201 code.
When the code comea up I can feel one cylinder is down. Restart the engine and the cylinder is running again and I was able to reproduce this several times.
They came with short wiring adapters to fit the stock harness so plug-n-play install was easy. I was thinking of swapping the adapter cable to another cylinder as a first step to rule out wiring problem, then move the injector to another cylinder and see if the code moves to something other than cylinder 1.
Anyone have any other suggestions?
Is this this correct cylinder arraignment?
front
3--1
4--2
rear
Thanks.
onzippy is offline   Reply With Quote
Old 10-05-2015, 10:48 AM   #2
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I had the same issue with the same injectors. Some dielectric grease in the connectors will probably help but I would try to swap the adapters to see if you can get the problem to move and then file a warranty claim with DW. They are pretty good about getting out new parts and I believe this is a known issue with them.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
onzippy (10-05-2015)
Old 10-05-2015, 12:55 PM   #3
onzippy
Drives: 2014 FRS
Any info on the cylinder numbers? I found one post that #1 is passenger side, front but I'm not sure if that was a US spec car.
Old 10-05-2015, 01:34 PM   #4
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
My ODB-II bluetooth adapter caused mine. Had to disable fast comm.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-05-2015, 02:01 PM   #5
CSG Mike
CSG Mike's Avatar
front
3--1
4--2
rear
Thanks.
That is correct.
We have hard adapters available that usually solve this issue. I like the DW injectors, but don't like their pigtail adapters. I usually recommend soldering injectors to get a hard connection.
The hard adaptors we have available are better, but will require you to cut your passenger side heat shield to clear the larger adapter.
dj2020 (10-06-2015)
Old 10-05-2015, 02:16 PM   #6
onzippy
Drives: 2014 FRS
That is correct.
Do you have them listed on your site? (couldn't find them) I want to move the pigtail around to confirm it's a wiring issue and not the injector but getting rid of the pigtail all together seems like a solid solution.
Old 10-05-2015, 02:20 PM   #7
CSG Mike
CSG Mike's Avatar
No, they're not listed. PM us if you want a set.
Old 10-05-2015, 02:24 PM   #8
onzippy
Drives: 2014 FRS
Good idea but not this time. Nothing was connected to the port.. But I can relate.... I had a misfire code a few times with my bluethooth adapter connected but never without it.
Old 10-05-2015, 02:43 PM   #9
CSG Mike
CSG Mike's Avatar
Some early cars had sketchy OBD2 ports that didn't connect well, and could cause issues, but you have a 2014, so it shouldn't be an issue.
Low quality electronics can introduce enough noise into the system that you can get odd behavior.
I've seen boosted cars just flat out not run right when cheap aftermarket headlights are installed.
Old 10-06-2015, 04:22 AM   #10
dj2020
That is correct.
I use the hard adapters as well for the DW700cc injectors. It did require trimming the metal shield that goes over the injectors. So far so good.
dj2020 is offline   Reply With Quote
Old 10-06-2015, 06:06 AM   #11
front
3--1
4--2
rear
Thanks.
onzippy (10-06-2015)
Old 10-06-2015, 11:05 AM   #12
onzippy
Drives: 2014 FRS
UPDATE: I swapped the pigtail from cylinder 1 to the one next to it and reassembled both with dielectric grease.
2 trips and 20 miles and good so far.
Thanks all for the input.
Old 12-08-2015, 01:48 PM   #13
onzippy
Drives: 2014 FRS
The injector circuit code problem came back. I called DeatschWerks and they acknowledge a design problem with the electrical connector that attaches to the factory harness.
The different style connector is being supplied since my purchase in April 2015. Change in the connector body and longer pins in the grey connector that attaches to the factory connector provides a more reliable electrical contact. Pics below.
Old 12-08-2015, 02:09 PM   #14
stugray
Drives: 2013 GBS BRZ Limited
My very first thought was: Bigger Injectors probably means bigger coil.
Bigger coil means bigger inductor.
Bigger Inductor means bigger reverse EMF (Electro-Motive-Force) when the ECU tries to turn off the injector.
The ECU will have a reverse EMF diode on the board that absorbs the energy left in the coil when the Injector is turned off.
As the field collapses it sends a big pulse back to the EMF diode.
With a larger coil the reverse EMF is larger and might overwhelm the diode allowing noise into the ECU.
So you could add an additional rev-EMF diode in the harness adapter and it might solve the problem.
So if you are interested in trying that, you would need a suitable diode, and solder it into the connector such that it does NOT conduct when the injector is firing.
Cruise Control Malfunction Wyattkb Issues | Warranty | Recalls / TSB 6 12-21-2014 05:37 PM
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 02:22 PM
Stock Radio Malfunction Re~Mix Electronics | Audio | NAV | Infotainment 7 01-02-2013 09:05 PM
First Malfunction? Ishii Motors Scion FR-S / Toyota 86 GT86 General Forum 6 06-09-2012 01:16 PM
