#351 | |
He's not going to be cornering faster with more power, but he sure will be accelerating faster and seeing higher speeds. That's why you see the same valleys, and the same acceleration points, but higher velocities exiting the corners and down the straights. |
#352 | |
Drives: 2014 FR-S 6MT Whiteout
Ace 4-2-1 Header
I feel like I'm missing something fundamental here. I appreciate you guys trying to help. But I'll let it go rather than clutter up this thread further. Serious question - competitive header trade up program?
#353 |
Drives: 2013 Black FR-S
It's around a 5-6 mph difference at the end of the straight (look at the #s on the y axis). Which means I have to start breaking earlier. That's why the peak is offset left. The valley will be the same because that's the cornering speed.
| The Following User Says Thank You to sw20kosh For This Useful Post: | wparsons (10-02-2015) |
#354 | |
Drives: 2014 BRZ
<~3% tariff didn't seem particularly unreasonable, although it was unexpected. |
#355 | |
Drives: 2013 FR-S, 2016 Miata Club
#356 | |
Drives: Subaru BRZ / Toyota 86 Experts
#357 |
Drives: '13 BRZ Ltd
#358 | |
Drives: 2013 WhiteOut FR-S
Bottom line is this header is unreal......
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
| The Following User Says Thank You to RehabJeff86 For This Useful Post: | wparsons (10-02-2015) |
#359 |
Drives: 2014 Toyota 86
Can you install the header and overpipe without lifting the engine?
#361 |
Some people have said they did, but it's really MUCH faster to just lift the engine. It's one 17mm nut for the passenger side engine mount, and a floor jack to lift the engine 10mm if you're working on the floor. Once the overpipe is in, lower engine, and re-torque that single nut for the engine mount.
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (10-02-2015) |
#362 |
Went under to check header bolts after heat cycling the header at the track. This is the view:
| The Following 11 Users Say Thank You to sw20kosh For This Useful Post: | AceHeader-MT (10-02-2015), BRZHarley (10-03-2015), civicdrivr (10-03-2015), Cop (10-03-2015), CSG Mike (10-02-2015), meWant (10-02-2015), mokinbird87 (10-14-2015), new2subaru (12-19-2015), ohmai18 (10-02-2015), PandaBRZ (10-02-2015), SuperDave (10-03-2015) |
#363 |
Drives: Subaru BRZ
That is simply beautiful. The different coloration from variations in exhaust temperatures on quality steel. Yes!
#364 |
Drives: Firestorm 86
Where is the jacking point if I we're to raise the engine alittle
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
