Old 09-28-2015, 01:46 PM   #337
sw20kosh
Drives: 2013 Black FR-S
ACE header + ACE FP + stock cat back
https://instagram.com/p/8JOqvgG4G1/
Old 09-28-2015, 05:53 PM   #338
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Question for you guys that bought ACE headers in the USA (Counter Space Garage). Have any of you received a Customs Bill from FedEx? I just got a notice in the mail today for a $19.50 amount due. Just curious if this is common.
JimmyMac is offline   Reply With Quote
Old 09-28-2015, 07:21 PM   #339
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Please send that invoice to david@counterspacegarage.com. @CSG David will handle that inquiry for you. This may be a customs bill since we had these shipped directly to you from ACE (to cut shipping time).
CounterSpace Garage is offline   Reply With Quote
Old 09-28-2015, 07:57 PM   #340
JimmyMac
JimmyMac's Avatar
PM sent.
Old 09-28-2015, 09:13 PM   #341
07jazzrs5gt86
Drives: Firestorm 86
Having a dilemma on which op should I get.
My current setup is TRD catcack, mashimoto cai , phantom ESC 1.5 kit
My current setup give me tons of torque down low but once I hit 6k+ rpm range my ESC boost tamper off so my top end is not as aggressive even when I had a JDL prototype el header. Thats one thing with my phantom esc from 3-6k rpm i get 4-5 psi but once on the higher rpm it tamper of to 1-3 psi.So I'm looking at way to improve top end more. I don't track but I canyon drive a lot and stay a higher rpm on most drives.
I'm leaning towards type a w 250 op but 350 op is very tempting and can't decide
Any help is much appreciated
Thanks
07jazzrs5gt86 is offline   Reply With Quote
Old 09-28-2015, 11:06 PM   #342
Hawk77FT
Drives: GTS 86
Thanks
Sounds like you need 150 rather than the 350. Shorter runner will give you a higher top end power. The beauty with these header is you can exchange the 150 to 250 overpipe bit based on your application/drive. So it will be up to you, if you want to gain a higher top end with limited gain in torque low end (150) or gain a bit of both (250). Also, depends how those canyon runs are - higher rpm is between 5000-7000 (better go 150) or more 3-5000 (250 is more suitable). That is just my opinion however.
Hawk77FT is offline   Reply With Quote
Old 09-28-2015, 11:31 PM   #343
CSG Mike
CSG Mike's Avatar
Thanks
I would consider the 150 or 250. The 350 will give you a TON of torque from 3000-5000.
CSG Mike is online now   Reply With Quote
Old 09-29-2015, 01:11 PM   #344
CSG David
CSG David's Avatar
PM sent.
Sent you e-mail back.
Old 09-29-2015, 02:06 PM   #345
2000 lb-in?
Old 09-29-2015, 02:25 PM   #346
sw20kosh
Just got back from my favorite track. First time with the ACE type A 350.
Y axis is speed, x axis is position.
This is the acceleration out of a hair pin turn (T2) onto a straight:
Red is ACE + e85, green is stock header on 91:
Red is ACE + e85, blue is JDL + e85:
Ambient temps for the ACE trace were 99F deg.
Stock trace was in June and it was about 87F deg.
JDL trace was in apr and it was 80F deg.
Thank you CSG for convincing me to swap headers! I like this monstrous NA feeling!
Old 09-29-2015, 03:09 PM   #347
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
@sw20kosh thats some monsterous acceleration gain!!!! OmG!!
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 09-29-2015, 03:59 PM   #348
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
X is position and not time? Hm...I'm not sure that makes sense to me. If it's position shouldn't all the peaks and valleys be in the same spot on the same course, just offset vertically because it's faster with the new equipment?
What you're showing it's also offset to the left which suggests it's time, since you're going faster and getting to the same braking point sooner...Unless this is saying you're braking in a different spot, but I wouldn't expect there to be that much fidelity in the data (commercial GPS isn't that accurate)?
Somebody 'splain it to me please...
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 09-29-2015, 04:03 PM   #349
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
That means more speed at the same position on track.
Difference is amazing. Thanks for the graphs
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 09-29-2015, 04:15 PM   #350
phobos512
phobos512's Avatar
Speed is the vertical. He said that. I don't disagree with that. Are we saying he's having to brake that much sooner, and that's why it's offset so much in the horizontal? I mean we've got to be talking about a single digit MPH difference here, it's not 100 HP.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
